Hi Lars and Welcome to The Forum. I took the liberty of pinning your most relevant cpu-z shots. You may want to reformat your post
STOP 0x0000001A: MEMORY_MANAGEMENT
Usual causes: Device driver, memory, kernel.
Your latest dump file lists
ntkrnlmp.exe as the probable cause. This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes. Random stop codes can often indicate hardware issues.
As a Priority:
sptd.sys Sun Mar 22 12:35:35 2009 The
sptd.sys driver is notorious for causing BSOD's with Windows 7. It's a driver used and installed along with Daemon Tools and Alcohol 120 which you'll also have to uninstall.
Then use the correct (32bit or 64bit) download from
Link Removed to uninstall the SPTD.SYS driver.
Make sure to select the
uninstall button!
DO NOT SELECT INSTALL!!
Drivers with Updates:
nusb3hub.sys Fri Apr 23 02:34:35 2010
nusb3xhc.sys Fri Apr 23 02:34:36 2010 Go to your
Motherboard Mfr. Support website
(or Link Removed - Invalid URL) and update your
USB 3.0 drivers. A June 2011 set are available
Here.
RTKVHD64.sys Tue Oct 05 10:58:40 2010
Bugcheck Analysis:
Loading Dump File [D:\DOWNLOADS\ DUMPS\hansi342\112711-21091-01.dmp]
Symbol search path is: SRV*C:\Windows\WinDbgSym*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: 7601.17640.amd64fre.win7sp1_gdr.110622-1506
Machine Name:
Kernel base = 0xfffff800`0300b000 PsLoadedModuleList = 0xfffff800`03250670
Debug session time: Sun Nov 27 14:55:17.732 2011 (UTC + 0:00)
System Uptime: 0 days 2:38:16.950
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck 1A, {41790, fffffa8005d5c7f0, ffff, 0}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+36024 )
Followup: MachineOwner
Drivers:
fffff880`04795000 fffff880`047d7000 a0n4c7gg a0n4c7gg.SYS Tue Apr 07 17:07:00 2009 (49DB7A24)
fffff880`0102f000 fffff880`01086000 ACPI ACPI.sys Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`0175c000 fffff880`017e5000 afd afd.sys Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`04600000 fffff880`04616000 AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`013ad000 fffff880`013b8000 amdxata amdxata.sys Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`0135f000 fffff880`01368000 atapi atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`01368000 fffff880`01392000 ataport ataport.SYS Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`04200000 fffff880`0423e000 AtihdW76 AtihdW76.sys Tue Jun 07 11:34:39 2011 (4DEDFEBF)
fffff880`04ca9000 fffff880`056ff000 atikmdag atikmdag.sys Wed Oct 26 02:59:06 2011 (4EA7696A)
fffff880`0317e000 fffff880`031d3000 atikmpag atikmpag.sys Wed Oct 26 02:21:58 2011 (4EA760B6)
fffff880`07725000 fffff880`07774000 atksgt atksgt.sys Sun May 17 14:36:34 2009 (4A1012E2)
fffff880`00fb5000 fffff880`00fc1000 BATTC BATTC.SYS Tue Jul 14 00:31:01 2009 (4A5BC3B5)
fffff880`04433000 fffff880`0443a000 Beep Beep.SYS Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`03147000 fffff880`03158000 blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`07100000 fffff880`0711e000 bowser bowser.sys Wed Feb 23 04:55:04 2011 (4D649328)
fffff960`00790000 fffff960`007b7000 cdd cdd.dll unavailable (00000000)
fffff880`04400000 fffff880`0442a000 cdrom cdrom.sys Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00d0f000 fffff880`00dcf000 CI CI.dll Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`01d9e000 fffff880`01dce000 CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00cb1000 fffff880`00d0f000 CLFS CLFS.SYS Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`016cf000 fffff880`01741000 cng cng.sys Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`011f4000 fffff880`011fd000 compbatt compbatt.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`047ed000 fffff880`047fd000 CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`06333000 fffff880`06341000 crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`030a6000 fffff880`03129000 csc csc.sys Sat Nov 20 09:27:12 2010 (4CE79470)
fffff880`03129000 fffff880`03147000 dfsc dfsc.sys Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`03097000 fffff880`030a6000 discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`01d88000 fffff880`01d9e000 disk disk.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0427b000 fffff880`0429d000 drmk drmk.sys Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`06341000 fffff880`06354000 dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`04443000 fffff880`04597000 dump_iaStor dump_iaStor.sys Tue Sep 14 02:23:32 2010 (4C8ECE94)
fffff880`06354000 fffff880`06395000 dump_truecrypt dump_truecrypt.sys Thu Sep 01 13:42:30 2011 (4E5F7DB6)
fffff880`06395000 fffff880`063a1000 Dxapi Dxapi.sys Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`056ff000 fffff880`057f3000 dxgkrnl dxgkrnl.sys Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`04c00000 fffff880`04c46000 dxgmms1 dxgmms1.sys Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`046a0000 fffff880`046ef000 e1c62x64 e1c62x64.sys Tue Sep 21 22:34:15 2010 (4C9924D7)
fffff880`0308b000 fffff880`03097000 ElbyCDIO ElbyCDIO.sys Thu Dec 16 22:58:13 2010 (4D0A9985)
fffff880`013b8000 fffff880`013cc000 fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`00c00000 fffff880`00c4c000 fltmgr fltmgr.sys Sat Jul 09 03:30:49 2011 (4E17BD59)
fffff880`01752000 fffff880`0175c000 Fs_Rec Fs_Rec.sys Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01d4e000 fffff880`01d88000 fvevol fvevol.sys Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01c4b000 fffff880`01c95000 fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff880`04788000 fffff880`04795000 GEARAspiWDM GEARAspiWDM.sys Mon May 18 13:17:04 2009 (4A1151C0)
fffff800`035f4000 fffff800`0363d000 hal hal.dll Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`071d5000 fffff880`071e1000 hcmon hcmon.sys Tue Sep 21 08:56:08 2010 (4C986518)
fffff880`04c46000 fffff880`04c6a000 HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`04c6a000 fffff880`04c7b000 HECIx64 HECIx64.sys Wed Oct 20 00:33:43 2010 (4CBE2AD7)
fffff880`063da000 fffff880`063f3000 HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`063f3000 fffff880`063fb080 HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`063cc000 fffff880`063da000 hidusb hidusb.sys Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`07037000 fffff880`07100000 HTTP HTTP.sys Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`01d45000 fffff880`01d4e000 hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`0120b000 fffff880`0135f000 iaStor iaStor.sys Tue Sep 14 02:23:32 2010 (4C8ECE94)
fffff880`047d7000 fffff880`047ed000 intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`0b206000 fffff880`0b7da000 iqvw64e iqvw64e.sys Thu Sep 02 06:02:32 2010 (4C7F2FE8)
fffff880`0606a000 fffff880`0608d000 irda irda.sys Tue Jul 14 01:09:01 2009 (4A5BCC9D)
fffff880`031ed000 fffff880`031fc000 kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`06000000 fffff880`0600e000 kbdhid kbdhid.sys Sat Nov 20 10:33:25 2010 (4CE7A3F5)
fffff800`00ba8000 fffff800`00bb2000 kdcom kdcom.dll Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`042e2000 fffff880`04325000 ks ks.sys Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`016b4000 fffff880`016cf000 ksecdd ksecdd.sys Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`01984000 fffff880`019af000 ksecpkg ksecpkg.sys Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`0429d000 fffff880`042a2200 ksthunk ksthunk.sys Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`07774000 fffff880`07781000 lirsgt lirsgt.sys Sun May 17 14:06:57 2009 (4A100BF1)
fffff880`0609d000 fffff880`060b2000 lltdio lltdio.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`06026000 fffff880`06049000 luafv luafv.sys Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00c4e000 fffff880`00c9d000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`063a1000 fffff880`063af000 monitor monitor.sys Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`03000000 fffff880`0300f000 mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`06019000 fffff880`06026000 mouhid mouhid.sys Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00e5c000 fffff880`00e76000 mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`01a00000 fffff880`01a31000 MpFilter MpFilter.sys Wed Apr 06 21:07:29 2011 (4D9CC801)
fffff880`0711e000 fffff880`07136000 mpsdrv mpsdrv.sys Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`07136000 fffff880`07163000 mrxsmb mrxsmb.sys Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`07163000 fffff880`071b1000 mrxsmb10 mrxsmb10.sys Sat Jul 09 03:46:28 2011 (4E17C104)
fffff880`071b1000 fffff880`071d5000 mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`01392000 fffff880`0139d000 msahci msahci.sys Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`01dee000 fffff880`01df9000 Msfs Msfs.SYS Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`01086000 fffff880`01090000 msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`01656000 fffff880`016b4000 msrpc msrpc.sys Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`03080000 fffff880`0308b000 mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`01d33000 fffff880`01d45000 mup mup.sys Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`01831000 fffff880`01924000 ndis ndis.sys Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`0463a000 fffff880`04646000 ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`04646000 fffff880`04675000 ndiswan ndiswan.sys Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`043bb000 fffff880`043d0000 NDProxy NDProxy.SYS Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`01645000 fffff880`01654000 netbios netbios.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`01600000 fffff880`01645000 netbt netbt.sys Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`01924000 fffff880`01984000 NETIO NETIO.SYS Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`07781000 fffff880`077c2000 nfsrdr nfsrdr.sys Sat Nov 20 09:26:56 2010 (4CE79460)
fffff880`07f21000 fffff880`07f39000 NisDrvWFP NisDrvWFP.sys Wed Apr 06 21:08:53 2011 (4D9CC855)
fffff880`019d4000 fffff880`019e5000 Npfs Npfs.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`03074000 fffff880`03080000 nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`0300b000 fffff800`035f4000 nt ntkrnlmp.exe Thu Jun 23 03:53:23 2011 (4E02AAA3)
fffff880`01444000 fffff880`015e7000 Ntfs Ntfs.sys Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`0442a000 fffff880`04433000 Null Null.SYS Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`043a3000 fffff880`043bb000 nusb3hub nusb3hub.sys Fri Apr 23 02:34:35 2010 (4BD0F92B)
fffff880`04756000 fffff880`04786000 nusb3xhc nusb3xhc.sys Fri Apr 23 02:34:36 2010 (4BD0F92C)
fffff880`013cc000 fffff880`013f2000 pacer pacer.sys Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`011df000 fffff880`011f4000 partmgr partmgr.sys Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00f82000 fffff880`00fb5000 pci pci.sys Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`0139d000 fffff880`013ad000 PCIIDEX PCIIDEX.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`01741000 fffff880`01752000 pcw pcw.sys Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`0786f000 fffff880`07915000 peauth peauth.sys Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`0423e000 fffff880`0427b000 portcls portcls.sys Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00c9d000 fffff880`00cb1000 PSHED PSHED.dll Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`04616000 fffff880`0463a000 rasl2tp rasl2tp.sys Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`04675000 fffff880`04690000 raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`04c7b000 fffff880`04c9c000 raspptp raspptp.sys Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`031d3000 fffff880`031ed000 rassstp rassstp.sys Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`03023000 fffff880`03074000 rdbss rdbss.sys Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`04690000 fffff880`0469b000 rdpbus rdpbus.sys Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`0443a000 fffff880`04443000 RDPCDD RDPCDD.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01ddc000 fffff880`01de5000 rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01de5000 fffff880`01dee000 rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01cf9000 fffff880`01d33000 rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`07915000 fffff880`07934000 rpcxdr rpcxdr.sys Sat Nov 20 09:27:12 2010 (4CE79470)
fffff880`060b2000 fffff880`060ca000 rspndr rspndr.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`060cf000 fffff880`06332800 RTKVHD64 RTKVHD64.sys Tue Oct 05 10:58:40 2010 (4CAAF6D0)
fffff880`01000000 fffff880`0102f000 SCSIPORT SCSIPORT.SYS Sat Nov 20 10:34:01 2010 (4CE7A419)
fffff880`07934000 fffff880`0793f000 secdrv secdrv.SYS Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`01cf1000 fffff880`01cf9000 spldr spldr.sys Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`010a2000 fffff880`011d6000 sptd sptd.sys Sun Mar 22 12:35:35 2009 (49C63097)
fffff880`07e89000 fffff880`07f21000 srv srv.sys Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`07e20000 fffff880`07e89000 srv2 srv2.sys Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`0793f000 fffff880`07970000 srvnet srvnet.sys Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`0469b000 fffff880`0469c480 swenum swenum.sys Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`01a47000 fffff880`01c4b000 tcpip tcpip.sys Thu Sep 29 04:43:04 2011 (4E83E948)
fffff880`079e1000 fffff880`079f3000 tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`01822000 fffff880`0182f000 TDI TDI.SYS Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`01800000 fffff880`01822000 tdx tdx.sys Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`015e7000 fffff880`015fb000 termdd termdd.sys Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff880`01403000 fffff880`01444000 truecrypt truecrypt.sys Thu Sep 01 13:42:30 2011 (4E5F7DB6)
fffff960`00540000 fffff960`0054a000 TSDDD TSDDD.dll unavailable (00000000)
fffff880`03158000 fffff880`0317e000 tunnel tunnel.sys Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`04325000 fffff880`04337000 umbus umbus.sys Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`063af000 fffff880`063cc000 usbccgp usbccgp.sys Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`04786000 fffff880`04787f00 USBD USBD.SYS Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`046ef000 fffff880`04700000 usbehci usbehci.sys Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`04349000 fffff880`043a3000 usbhub usbhub.sys Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`04700000 fffff880`04756000 USBPORT USBPORT.SYS Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`0300f000 fffff880`0301e000 VClone VClone.sys Sat Jan 15 16:21:04 2011 (4D31C970)
fffff880`01090000 fffff880`0109d000 vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`045ed000 fffff880`045fb000 vga vga.sys Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`019af000 fffff880`019d4000 VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`00e76000 fffff880`00eb2000 vmbus vmbus.sys Sat Nov 20 09:57:29 2010 (4CE79B89)
fffff880`071e1000 fffff880`071f9000 vmci vmci.sys Tue Sep 21 08:24:22 2010 (4C985DA6)
fffff880`0600e000 fffff880`06019000 VMkbd VMkbd.sys Tue Sep 21 09:46:23 2010 (4C9870DF)
fffff880`0433f000 fffff880`04349000 VMNET VMNET.SYS Mon Aug 10 13:04:50 2009 (4A800CE2)
fffff880`04337000 fffff880`0433f000 vmnetadapter vmnetadapter.sys Mon Aug 10 13:04:53 2009 (4A800CE5)
fffff880`0608d000 fffff880`0609d000 vmnetbridge vmnetbridge.sys Mon Aug 10 13:05:58 2009 (4A800D26)
fffff880`079f3000 fffff880`079fd000 vmnetuserif vmnetuserif.sys Tue Sep 21 09:10:42 2010 (4C986882)
fffff880`01c95000 fffff880`01ca5000 vmstorfl vmstorfl.sys Sat Nov 20 09:57:30 2010 (4CE79B8A)
fffff880`0764f000 fffff880`07725000 vmx86 vmx86.sys Tue Sep 21 10:33:47 2010 (4C987BFB)
fffff880`00fc1000 fffff880`00fd6000 volmgr volmgr.sys Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00e00000 fffff880`00e5c000 volmgrx volmgrx.sys Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`01ca5000 fffff880`01cf1000 volsnap volsnap.sys Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`07800000 fffff880`0780c000 vstor2_ws60 vstor2-ws60.sys Thu Aug 19 21:28:39 2010 (4C6D93F7)
fffff880`017e5000 fffff880`01800000 wanarp wanarp.sys Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`01a31000 fffff880`01a41000 watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00ecf000 fffff880`00f73000 Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f73000 fffff880`00f82000 WDFLDR WDFLDR.SYS Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`0780c000 fffff880`0784e000 wdfsd wdfsd.sys Thu Jun 02 23:20:01 2011 (4DE80C91)
fffff880`019f0000 fffff880`019f9000 wfplwf wfplwf.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00000000 fffff960`00314000 win32k win32k.sys unavailable (00000000)
fffff880`00eb2000 fffff880`00ec6000 winhv winhv.sys Sat Nov 20 09:20:02 2010 (4CE792C2)
fffff880`011d6000 fffff880`011df000 WMILIB WMILIB.SYS Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`019e5000 fffff880`019f0000 ws2ifsl ws2ifsl.sys Tue Jul 14 01:10:33 2009 (4A5BCCF9)
fffff880`06049000 fffff880`0606a000 WudfPf WudfPf.sys Sat Nov 20 10:42:44 2010 (4CE7A624)
Unloaded modules:
fffff880`0b2a6000 fffff880`0b3fa000 hiber_iaStor
Checksum: 00000000
ImageSize: 00154000
fffff880`0b200000 fffff880`0b213000 hiber_dumpfv
Checksum: 00000000
ImageSize: 00013000
fffff880`0b213000 fffff880`0b254000 hiber_truecr
Checksum: 00000000
ImageSize: 00041000
fffff880`07970000 fffff880`079e1000 spsys.sys
Checksum: 00000000
ImageSize: 00071000
fffff880`01dce000 fffff880`01ddc000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000E000
fffff880`04445000 fffff880`04599000 dump_iaStor.
Checksum: 00000000
ImageSize: 00154000
fffff880`04599000 fffff880`045ac000 dump_dumpfve
Checksum: 00000000
ImageSize: 00013000
fffff880`045ac000 fffff880`045ed000 dump_truecry
Checksum: 00000000
ImageSize: 00041000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
