george walker
gtwalkeriii
Well-Known Member
so i am trying to upgrade from VISTA to Window7. I have a compatibility issue. Window7 will not install with Microsoft OneCare installed. So I removed it using Add and Remove Programs. Well no luck. So I downloaded the OneCare Cleanup Utility. NO LUCK. I tried the clean up twice with shutdown between each try. I am lost. Can you recommend something to do.....
Regards
George
