Windows 10 Having troble with WindowsApps
Odnaits
Hey!
I have a laptop with 2 drives. I recently restored windows on my c drive but didn't delete/change any flile on my D: drive. Now I cant download apps on de D: drive becouse. Any ideas, I suspect is becouse I don't have permissions but idk.
Any advice would be appreciated.
Reset Microsoft Store : Press Windows key + I to open Settings and click Apps. Scroll the list and click Microsoft Store. Then click Advanced options > Reset. It will show a warning that the app’s data will be deleted, so click Reset again.
Neemobeer
Windows Forum Team
There shouldn't be any permission problems as they generally set to allowed for <local computer>\users. Can you give us an example? Do you get an error when trying to save to the D drive?
Odnaits
Yes and no, I can't install any apps from the M Store to de D drive, but I can add any other file.
Neemobeer
Windows Forum Team
  • Press [Windows key + i]
  • Click on Settings
  • Click on Storage
  • Click 'Change where new content is saved'
  • Change the setting to D drive for apps
Neemobeer
Windows Forum Team
That would be an access denied error. Verify you have permissions to the location you're trying to set the storage location to.
samK
Member
