Windows 7 Help! 0x124 error.
Jared44
I don't know what's caused this, my pc is less than a year old and I haven't changed any hardware except the ram but the new ram was faulty so I swapped it back, I've had many blue screens indicating drivers but yesterday while I was playing a game I got a BSOD, I'd be very surprised if it was actually hardware related because this PC is quite new. The only thing I can think of that might be Is drivers because I've had loads of driver issues in the past and it wouldn't surprise me if it caused this one. And I only ever get BSODs when playing games. Any help is appreciated thanks.
I don't think so. This is a WHEA BSOD, which means a piece of hardware (in this case, your CPU) has notified Windows that it has experienced a hardware problem. The issue is that an unspecified error occurred when the L2 cache inside the CPU was working with some other part of the system. It may very well be a mobo bug like nmsuk mentioned, or a memory timing issue. So first thing should be to update that BIOS!
This can also be caused by bugs in motherboard software, which I've seen happen before a number of times. If this is a custom system, I recommend looking at the manufacturer's website for your motherboard for the list of software associated with it, and go through your system and un install all of it. They are...
Vir Gnarus
Active Member
So you were getting two kinds of BSODs, but only one type was manifesting with the new RAM?
As for the type of BSOD, a 0xC4 just means a specialized embedded Driver Verifier check for Windows discovered a driver doing something bad, and caught it in its tracks. Of course, hardware can manifest these crashes too, since hardware problems can alter driver operations, which can end up having Windows point finger at the driver, not the hardware. That's what gets tricky about analyzing crashdumps; Windows almost always crashes blaming drivers/software as responsible, because that's all it can really see. It's up to the analyst to scrutinize the data and figure, "Ok, the software meant to do one thing but the hardware had it do something else. That's a hardware problem." Only exceptions are specialized crashes like the WHEA crashes, and sometimes TDR crashes and 0xF4 crashes, and that's only because the hardware reports to Windows that it actually discovered a problem.
Anyways, pardon the rant. Go ahead and send it to the shop. Lord willing if the system isn't that old they'll be lenient with ya.
Jared44
Well I've had at least 4 types of BSODs, ever since I've had the PC. The first ones I got were 0x0000003D INTERUPT_EXCEPTION_NOT_HANDLED. I can't remember how that got fixed, then there was the 0x000000C4 ones. Then I got a 0x0000001E pointing at Nvidia drivers. Then about 1 week later I got the 0x00000124 BSOD twice. That was a few days ago.
Jared44
Sorry for the late reply but he fixes all BSOD errors. It was driver issues, he said my PC was a mess with drivers. Everything had been fine up to yesterday when my PC froze, I thought nothing of it, then earlier it froze again. I know it's not driver related, I know it's not heat related, and I know it's not hardware related. Now this really is strange. I have only downloaded a game and a mod since he fixed it which was way before the freezing so I don't know.
Vir Gnarus
Active Member
It has to be one of those things. Even though he may of cleaned up your drivers, that doesn't resolve the problem if the hardware is the underlying issue.
I say the guy at the shop just looked at your system, saw the driver mess, and immediately assumed that was the problem. Personally, I wouldn't blame him. Nevertheless, I recommend taking it back to him and telling him there's more to it than that and he needs to delve deeper or start swapping hardware.
Jared44
Yeah well I just got another BSOD. I got a 0x00000d1 DRIVER_IRQL_NOT_LESS_OR_EQUAL. It points at dxgmms1.sys. Although I know it's not a graphics card driver because the PC guy fixed that a month ago and I've had no problems since. But 3 days before I got the BSOD I updated about 9 or 11 I think windows important updates.
Vir Gnarus
Active Member
I'm not entirely sure the Windows updates are responsible. I know sometimes they can release buggy updates that cause BSODs, which you'll want to update your system again to ensure that those bugs are taken care of.
If you want, turn on Link Removed then restart system and let it crash the system a few times, then send us the resulting crashdumps. If it causes a boot loop, the article will explain how to get out of it (just go into Safe Mode and disable DV from there).
Pauli
Fantastic Member
dxgmms1.sys is a video driver file connected to DirectX. One way to try to solve the problem could be, uninstall all video drivers you have, reboot if requested BUT DO NOT ALLOW WINDOWS TO INSTALL DRIVERS, then preferably run CCleaner to check your registry, reboot, then install the original drivers you got with your video card / motherboard CD or DVD = start from start.
You could also uninstall any codec packs you have, Windows covers almost all.
Then, go from step one forward. Having several sets of drivers and codecs may be lethal. You may and can install anything later, after wish, but do it one by one.
Best wishes. :)
Jared44
I've not replied for ages so sorry about that. I've had it formatted multiple times and it works for while then the problem comes back. I've had it sent off to the manufacturer and they said it's not hardware but the upgraded my power supply from a 400 watt to a 700 watt. They also replaced the graphics card because the fan was making a noise, in fact they upgraded it from a GTX 650 to a GTX 650 Ti. Now it's something i'm installing but I can't figure out what it is. I can give you all my specs through Dxdiag here:Link Removed If you need anymore information then ask. Any help is appreciated. Thanks.
Pauli
Fantastic Member
I have to agree with Vir, I do have problems in understanding what the issue is. Anyways, it has to be something fundamental, it can't be related to PSU or graphics card, since upgrading them didn't do it. In fact, getting new ones was probably just a waste of money.
All I can say right now is, BE SURE to have your BIOS at Default. Mobos have a tendency to have automatic overclocking, even if one didn't want it - I've had my 3.1GHz processor running at 4GHz, and I never meant it. The best way to nullify it all is to take off your CMOS battery, wait for perhaps 30 seconds, then re-install it OR replace it with a new battery, batteries also have failures, and start your computer. Your computer should ask "Do you want to start with safe defaults", or something, and then go with it.
The root of the problem seems to be something not yet touched or solved.
nmsuk
I wouldn't recommend that, I'd double check memory timings in the bios and cpu mem voltages and set them to their correct values and not on auto.
nmsuk
One thing I would try is changing the command rat of the memory from 1T to 2T and after checking your cpu-z the cpu is overclocked
Jared44
My computer is freezing when playing games. I formatted it yesterday and it hasn't solved the problem. I installed the motherboard drivers from the disc and I installed the graphics drivers from www.geforce.co.uk version 332.21. I sent it off to the manufacturer a few weeks ago and they said it was a software fault, they found nothing wrong with the hardware.
