shubhamgupta
Hi everyone, i recently re-installed win 7 on my dell studio 1454 laptop which i purchased 1.5yrs ago. and today while listening to music via VLC a strange screen just like tv static came up with a long beep.
My Specs: (acc. to speccy)
Dell Studio 1545 Laptop
Windows 7 x64
Intel Core i3 350M @ 2.27GHz
4GB DDR3 RAM @ 532MHz
Motherboard - Dell Inc. 0133D9 (CPU 1)
GPU - ATI Mobility Radeon HD 5450
I have included(attached)Link Removed my system specs and SF diag data in the post
Please reply fast. Thanks in advance.
Hi shunham and Welcome to The Forum.
STOP 0x000000FE: BUGCODE_USB_DRIVER
Usual causes:
USB device driver.
Your latest dump file lists usbhub.sys as the probable cause. This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes. Random stop codes can often indicate hardware issues.
As a Priority:
Make sure your system is fully updated including SP1.
vsdatant.sys Mon May 03 18:44:42 2010 ZoneAlarm Firewall is known to be a cause of BSOD's on many Windows 7 systems. If you have the 2011 version of ZA then you can uninstall it through the...
Usual causes:
USB device driver.
As a Priority:
vsdatant.sys Mon May 03 18:44:42 2010 ZoneAlarm Firewall is known to be a cause of BSOD's on many Windows 7 systems. If you have the 2011 version of ZA then you can uninstall it through the Progams and Features and all should be well. Make sure that Windows Firewall is enabled.
If you have an earlier version of ZA (you do) you will have to download the Link Removed due to 404 Error to help you remove it. Uninstall ZoneAlarm through Programs and Features. Boot to safe mode and run the ZoneAlarm Remover. Reboot. Make sure that Windows Firewall is enabled.
Alternatively
Try this Microsoft hotfix if you wish to try and keep ZoneAlarm: Stop Error 0x07F when you run apps. that transfer data by the UDP protocol in Windows 7. I can neither verify or discount this fix. It may work, it may not.
Remove any and all USB attached devices, apart from the mouse and keyboard. Tell us what other USB devices you are using.
Drivers that pre-date Windows 7. Update:
BCM42RLY.sys Wed Jul 08 01:34:55 2009
bcmwl664.sys Wed Jul 08 01:45:04 2009
Broadcom
btwaudio.sys Wed Jul 01 14:54:56 2009
btwavdt.sys Thu Jun 25 06:50:13 2009
btwl2cap.sys Sat Apr 04 01:28:45 2009
btwrchid.sys Thu Jun 25 06:51:37 2009
Broadcom bluetooth drivers. or O.E.M.
Drivers with Updates:
RTKVHD64.sys Mon Aug 31 11:19:33 2009 Link Removed
Bugcheck Analysis:
BugCheck FE, {8, 6, 5, fffffa8004f94640}
Probably caused by : usbhub.sys ( usbhub!UsbhHubProcessChangeWorker+ec )
Followup: MachineOwner
1: kd> !analyze -v
BUGCODE_USB_DRIVER (fe)
USB Driver bugcheck, first parameter is USB bugcheck code.
Arguments:
Arg1: 0000000000000008, USBBUGCODE_RESERVED_USBHUB
Arg2: 0000000000000006, USBHUB_TRAP_FATAL_TIMEOUT
Arg3: 0000000000000005, TimeoutCode: Timeout_PCE_Suspend_Action3 - PortData->PortSuspendEvent
Arg4: fffffa8004f94640, TimeoutContext - PortData
Debugging Details:
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xFE
PROCESS_NAME:  System
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff880050129ec to fffff80002e73f00
STACK_TEXT:
fffff880`031c4c18 fffff880`050129ec : 00000000`000000fe 00000000`00000008 00000000`00000006 00000000`00000005 : nt!KeBugCheckEx
fffff880`031c4c20 fffff800`0316d527 : fffffa80`04f8f050 fffffa80`050b0d20 ffffffff`dc3a58a0 fffff800`030175f8 : usbhub!UsbhHubProcessChangeWorker+0xec
fffff880`031c4c80 fffff800`02e81161 : fffff800`03017500 fffff800`0316d504 fffffa80`03ba6680 00000000`00000000 : nt!IopProcessWorkItem+0x23
fffff880`031c4cb0 fffff800`03117166 : 00000000`00000000 fffffa80`03ba6680 00000000`00000080 fffffa80`03b90890 : nt!ExpWorkerThread+0x111
fffff880`031c4d40 fffff800`02e52486 : fffff880`02fd3180 fffffa80`03ba6680 fffff880`02fddfc0 00000000`00000000 : nt!PspSystemThreadStartup+0x5a
fffff880`031c4d80 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff880`050129ec cc              int     3
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  usbhub!UsbhHubProcessChangeWorker+ec
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: usbhub
IMAGE_NAME:  usbhub.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bcc2d
FAILURE_BUCKET_ID:  X64_0xFE_usbhub!UsbhHubProcessChangeWorker+ec
Drivers:
fffff880`059e7000 fffff880`059f3000   Acceler  Acceler.sys  Fri Jun 26 21:56:34 2009 (4A453602)
fffff880`00f02000 fffff880`00f59000   ACPI     ACPI.sys     Tue Jul 14 00:19:34 2009 (4A5BC106)
fffff880`02cf5000 fffff880`02d7f000   afd      afd.sys      Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`0562f000 fffff880`05645000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`00de6000 fffff880`00df1000   amdxata  amdxata.sys  Tue May 19 18:56:59 2009 (4A12F2EB)
fffff880`081ef000 fffff880`081fa000   asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`00e1a000 fffff880`00e23000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00e23000 fffff880`00e4d000   ataport  ataport.SYS  Tue Jul 14 00:19:52 2009 (4A5BC118)
fffff880`0485b000 fffff880`0487d000   AtiHdmi  AtiHdmi.sys  Wed Nov 18 23:25:33 2009 (4B04826D)
fffff880`0488a000 fffff880`04ec1000   atikmdag atikmdag.sys Thu Dec 17 23:24:40 2009 (4B2ABDB8)
fffff880`00fca000 fffff880`00fd6000   BATTC    BATTC.SYS    Tue Jul 14 00:31:01 2009 (4A5BC3B5)
fffff880`08149000 fffff880`08152000   BCM42RLY BCM42RLY.sys Wed Jul 08 01:34:55 2009 (4A53E9AF)
fffff880`056a7000 fffff880`0594f000   bcmwl664 bcmwl664.sys Wed Jul 08 01:45:04 2009 (4A53EC10)
fffff880`019b3000 fffff880`019ba000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`045d0000 fffff880`045e1000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`02bb3000 fffff880`02bd1000   bowser   bowser.sys   Tue Jul 14 00:23:50 2009 (4A5BC206)
fffff880`07d35000 fffff880`07d45000   BthEnum  BthEnum.sys  Tue Jul 14 01:06:52 2009 (4A5BCC1C)
fffff880`07d65000 fffff880`07d7c000   bthmodem bthmodem.sys Tue Jul 14 01:06:52 2009 (4A5BCC1C)
fffff880`07d45000 fffff880`07d65000   bthpan   bthpan.sys   Tue Jul 14 01:07:00 2009 (4A5BCC24)
fffff880`07a00000 fffff880`07a8c000   bthport  bthport.sys  Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`07b61000 fffff880`07b79000   BTHUSB   BTHUSB.sys   Tue Jul 14 01:06:52 2009 (4A5BCC1C)
fffff880`080b3000 fffff880`08139000   btwaudio btwaudio.sys Wed Jul 01 14:54:56 2009 (4A4B6AB0)
fffff880`08038000 fffff880`080b3000   btwavdt  btwavdt.sys  Thu Jun 25 06:50:13 2009 (4A431015)
fffff880`08139000 fffff880`08145000   btwl2cap btwl2cap.sys Sat Apr 04 01:28:45 2009 (49D6A9BD)
fffff880`08145000 fffff880`08148880   btwrchid btwrchid.sys Thu Jun 25 06:51:37 2009 (4A431069)
fffff960`00760000 fffff960`00787000   cdd      cdd.dll      unavailable (00000000)
fffff880`081d2000 fffff880`081ef000   cdfs     cdfs.sys     Tue Jul 14 00:19:46 2009 (4A5BC112)
fffff880`01924000 fffff880`0194e000   cdrom    cdrom.sys    Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00cba000 fffff880`00d7a000   CI       CI.dll       Tue Jul 14 02:32:13 2009 (4A5BE01D)
fffff880`018bc000 fffff880`018ec000   CLASSPNP CLASSPNP.SYS Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00c5c000 fffff880`00cba000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`059f3000 fffff880`059f7500   CmBatt   CmBatt.sys   Tue Jul 14 00:31:03 2009 (4A5BC3B7)
fffff880`0110f000 fffff880`01182000   cng      cng.sys      Tue Jul 14 00:49:40 2009 (4A5BC814)
fffff880`02cd6000 fffff880`02ce0000   cnnctfy2 cnnctfy2.sys Fri Jun 24 16:29:01 2011 (4E04AD3D)
fffff880`00fc1000 fffff880`00fca000   compbatt compbatt.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`0561f000 fffff880`0562f000   CompositeBus CompositeBus.sys Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`05c00000 fffff880`05c0e000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`0452f000 fffff880`045b2000   csc      csc.sys      Tue Jul 14 00:24:26 2009 (4A5BC22A)
fffff880`045b2000 fffff880`045d0000   dfsc     dfsc.sys     Tue Jul 14 00:23:44 2009 (4A5BC200)
fffff880`04520000 fffff880`0452f000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`018a6000 fffff880`018bc000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0447c000 fffff880`0449e000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`05c0e000 fffff880`05c1a000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`0449e000 fffff880`044b1000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`051ed000 fffff880`051f8000   dump_msahci dump_msahci.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`0487d000 fffff880`04889000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`04ec1000 fffff880`04fb5000   dxgkrnl  dxgkrnl.sys  Tue Jul 14 00:38:56 2009 (4A5BC590)
fffff880`04fb5000 fffff880`04ffb000   dxgmms1  dxgmms1.sys  Tue Jul 14 00:38:32 2009 (4A5BC578)
fffff880`0516a000 fffff880`05185000   ew_jubusenum ew_jubusenum.sys Sun Jan 30 10:19:33 2011 (4D453B35)
fffff880`08000000 fffff880`08036080   ewusbmdm ewusbmdm.sys Fri Dec 24 03:48:36 2010 (4D141814)
fffff880`08162000 fffff880`08198000   fastfat  fastfat.SYS  Tue Jul 14 00:23:28 2009 (4A5BC1F0)
fffff880`0109d000 fffff880`010b1000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`01051000 fffff880`0109d000   fltmgr   fltmgr.sys   Tue Jul 14 00:19:59 2009 (4A5BC11F)
fffff880`0122b000 fffff880`01235000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`0186c000 fffff880`018a6000   fvevol   fvevol.sys   Tue Jul 14 00:22:15 2009 (4A5BC1A7)
fffff880`01400000 fffff880`0144a000   fwpkclnt fwpkclnt.sys Tue Jul 14 00:21:08 2009 (4A5BC164)
fffff800`033df000 fffff800`03428000   hal      hal.dll      Tue Jul 14 02:27:36 2009 (4A5BDF08)
fffff880`04800000 fffff880`04824000   HDAudBus HDAudBus.sys Tue Jul 14 01:06:13 2009 (4A5BCBF5)
fffff880`04824000 fffff880`04835000   HECIx64  HECIx64.sys  Thu Sep 17 20:54:16 2009 (4AB293E8)
fffff880`018ec000 fffff880`01905000   HIDCLASS HIDCLASS.SYS Tue Jul 14 01:06:21 2009 (4A5BCBFD)
fffff880`0505a000 fffff880`05062080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`045e1000 fffff880`045ef000   hidusb   hidusb.sys   Tue Jul 14 01:06:22 2009 (4A5BCBFE)
fffff880`02a00000 fffff880`02ac8000   HTTP     HTTP.sys     Tue Jul 14 00:22:16 2009 (4A5BC1A8)
fffff880`0146a000 fffff880`01473000   hwpolicy hwpolicy.sys Tue Jul 14 00:19:22 2009 (4A5BC0FA)
fffff880`0595c000 fffff880`0597a000   i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`08152000 fffff880`08162000   icsak    icsak.sys    Fri Aug 27 10:11:49 2010 (4C778155)
fffff880`0737b000 fffff880`073a2000   idmwfp   idmwfp.sys   Wed Jul 06 15:37:41 2011 (4E147335)
fffff880`05609000 fffff880`0561f000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`02ba7000 fffff880`02bb3000   ISWKL    ISWKL.sys    Fri Aug 27 10:11:44 2010 (4C778150)
fffff880`05063000 fffff880`050b4000   k57nd60a k57nd60a.sys Thu Aug 06 12:44:32 2009 (4A7AC220)
fffff880`0597a000 fffff880`05989000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`02afc000 fffff880`02b0a000   kbdhid   kbdhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff800`00bca000 fffff800`00bd4000   kdcom    kdcom.dll    Tue Jul 14 02:31:07 2009 (4A5BDFDB)
fffff880`03e71000 fffff880`0439a000   kl1      kl1.sys      Fri Sep 25 14:59:13 2009 (4ABCCCB1)
fffff880`0194e000 fffff880`019aa000   klif     klif.sys     Tue Sep 22 11:31:19 2009 (4AB8A777)
fffff880`05115000 fffff880`05158000   ks       ks.sys       Tue Jul 14 01:00:31 2009 (4A5BCA9F)
fffff880`01200000 fffff880`0121a000   ksecdd   ksecdd.sys   Tue Jul 14 00:20:54 2009 (4A5BC156)
fffff880`015c9000 fffff880`015f4000   ksecpkg  ksecpkg.sys  Tue Jul 14 00:50:34 2009 (4A5BC84A)
fffff880`059f8000 fffff880`059fd200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`02b0a000 fffff880`02b1f000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`011ce000 fffff880`011f1000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00c04000 fffff880`00c48000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Tue Jul 14 02:29:10 2009 (4A5BDF66)
fffff880`07d7c000 fffff880`07d8b000   modem    modem.sys    Tue Jul 14 01:10:48 2009 (4A5BCD08)
fffff880`059d8000 fffff880`059e7000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`045ef000 fffff880`045fc000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00e00000 fffff880`00e1a000   mountmgr mountmgr.sys Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`02bd1000 fffff880`02be9000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`072df000 fffff880`0730b000   mrxsmb   mrxsmb.sys   Tue Jul 14 00:23:59 2009 (4A5BC20F)
fffff880`0730b000 fffff880`07358000   mrxsmb10 mrxsmb10.sys Tue Jul 14 00:24:08 2009 (4A5BC218)
fffff880`07358000 fffff880`0737b000   mrxsmb20 mrxsmb20.sys Tue Jul 14 00:24:05 2009 (4A5BC215)
fffff880`00feb000 fffff880`00ff6000   msahci   msahci.sys   Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`0181b000 fffff880`01826000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00f62000 fffff880`00f6c000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`010b1000 fffff880`0110f000   msrpc    msrpc.sys    Tue Jul 14 00:21:32 2009 (4A5BC17C)
fffff880`04515000 fffff880`04520000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`01235000 fffff880`01247000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`01477000 fffff880`01569000   ndis     ndis.sys     Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`05669000 fffff880`05675000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`02b72000 fffff880`02b85000   ndisuio  ndisuio.sys  Tue Jul 14 01:09:25 2009 (4A5BCCB5)
fffff880`05675000 fffff880`056a4000   ndiswan  ndiswan.sys  Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`04846000 fffff880`0485b000   NDProxy  NDProxy.SYS  Tue Jul 14 01:10:05 2009 (4A5BCCDD)
fffff880`02dda000 fffff880`02de9000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`02d7f000 fffff880`02dc4000   netbt    netbt.sys    Tue Jul 14 00:21:28 2009 (4A5BC178)
fffff880`01569000 fffff880`015c9000   NETIO    NETIO.SYS    Fri Apr 09 03:43:59 2010 (4BBE946F)
fffff880`01826000 fffff880`01837000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`04509000 fffff880`04515000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`02e02000 fffff800`033df000   nt       ntkrnlmp.exe Tue Jul 14 00:40:48 2009 (4A5BC600)
fffff880`01258000 fffff880`013fb000   Ntfs     Ntfs.sys     Tue Jul 14 00:20:47 2009 (4A5BC14F)
fffff880`019aa000 fffff880`019b3000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`02b1f000 fffff880`02b72000   nwifi    nwifi.sys    Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`02c9c000 fffff880`02cc2000   pacer    pacer.sys    Tue Jul 14 01:09:41 2009 (4A5BCCC5)
fffff880`00fac000 fffff880`00fc1000   partmgr  partmgr.sys  Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00f6c000 fffff880`00f9f000   pci      pci.sys      Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00dd6000 fffff880`00de6000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`0121a000 fffff880`0122b000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`07200000 fffff880`072a6000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`043b5000 fffff880`043f2000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00c48000 fffff880`00c5c000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`05645000 fffff880`05669000   rasl2tp  rasl2tp.sys  Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`050b4000 fffff880`050cf000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`050cf000 fffff880`050f0000   raspptp  raspptp.sys  Tue Jul 14 01:10:18 2009 (4A5BCCEA)
fffff880`050f0000 fffff880`0510a000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`044b8000 fffff880`04509000   rdbss    rdbss.sys    Tue Jul 14 00:24:09 2009 (4A5BC219)
fffff880`0510a000 fffff880`05115000   rdpbus   rdpbus.sys   Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`01800000 fffff880`01809000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01809000 fffff880`01812000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01812000 fffff880`0181b000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01000000 fffff880`0103a000   rdyboost rdyboost.sys Tue Jul 14 00:34:34 2009 (4A5BC48A)
fffff880`07d09000 fffff880`07d35000   rfcomm   rfcomm.sys   Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`02b85000 fffff880`02b9d000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`05c1a000 fffff880`05dfec80   RTKVHD64 RTKVHD64.sys Mon Aug 31 11:19:33 2009 (4A9BA3B5)
fffff880`03e57000 fffff880`03e71000   SCDEmu   SCDEmu.SYS   Mon Nov 09 03:27:29 2009 (4AF78C21)
fffff880`072a6000 fffff880`072b1000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`01462000 fffff880`0146a000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`07c71000 fffff880`07d09000   srv      srv.sys      Tue Jul 14 00:25:11 2009 (4A5BC257)
fffff880`07b79000 fffff880`07be2000   srv2     srv2.sys     Tue Jul 14 00:25:02 2009 (4A5BC24E)
fffff880`072b1000 fffff880`072de000   srvnet   srvnet.sys   Tue Jul 14 00:24:58 2009 (4A5BC24A)
fffff880`0145a000 fffff880`01462000   stdflt   stdflt.sys   Thu Jul 16 16:36:50 2009 (4A5F4912)
fffff880`056a4000 fffff880`056a5480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`05989000 fffff880`059d6000   SynTP    SynTP.sys    Fri Sep 04 01:33:28 2009 (4AA06058)
fffff880`01603000 fffff880`01800000   tcpip    tcpip.sys    Fri Apr 09 03:45:54 2010 (4BBE94E2)
fffff880`073a2000 fffff880`073b4000   tcpipreg tcpipreg.sys Tue Jul 14 01:09:49 2009 (4A5BCCCD)
fffff880`01855000 fffff880`01862000   TDI      TDI.SYS      Tue Jul 14 00:21:18 2009 (4A5BC16E)
fffff880`01837000 fffff880`01855000   tdx      tdx.sys      Tue Jul 14 00:21:15 2009 (4A5BC16B)
fffff880`02de9000 fffff880`02dfd000   termdd   termdd.sys   Tue Jul 14 01:16:36 2009 (4A5BCE64)
fffff960`00480000 fffff960`0048a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`04400000 fffff880`04426000   tunnel   tunnel.sys   Tue Jul 14 01:09:37 2009 (4A5BCCC1)
fffff880`05158000 fffff880`0516a000   umbus    umbus.sys    Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`08198000 fffff880`081b5000   usbccgp  usbccgp.sys  Tue Jul 14 01:06:45 2009 (4A5BCC15)
fffff880`059d6000 fffff880`059d7f00   USBD     USBD.SYS     Tue Jul 14 01:06:23 2009 (4A5BCBFF)
fffff880`04835000 fffff880`04846000   usbehci  usbehci.sys  Tue Jul 14 01:06:30 2009 (4A5BCC06)
fffff880`05000000 fffff880`0505a000   usbhub   usbhub.sys   Tue Jul 14 01:07:09 2009 (4A5BCC2D)
fffff880`04426000 fffff880`0447c000   USBPORT  USBPORT.SYS  Tue Jul 14 01:06:31 2009 (4A5BCC07)
fffff880`051a2000 fffff880`051b1000   usbrpm   usbrpm.sys   Tue Jul 14 01:35:14 2009 (4A5BD2C2)
fffff880`081b5000 fffff880`081d0000   USBSTOR  USBSTOR.SYS  Tue Jul 14 01:06:34 2009 (4A5BCC0A)
fffff880`07c31000 fffff880`07c5e100   usbvideo usbvideo.sys Tue Jul 14 01:07:00 2009 (4A5BCC24)
fffff880`00f9f000 fffff880`00fac000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`019ba000 fffff880`019c8000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`019c8000 fffff880`019ed000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`0144a000 fffff880`0145a000   vmstorfl vmstorfl.sys Tue Jul 14 00:42:54 2009 (4A5BC67E)
fffff880`00fd6000 fffff880`00feb000   volmgr   volmgr.sys   Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00d7a000 fffff880`00dd6000   volmgrx  volmgrx.sys  Tue Jul 14 00:20:33 2009 (4A5BC141)
fffff880`01182000 fffff880`011ce000   volsnap  volsnap.sys  Tue Jul 14 00:20:08 2009 (4A5BC128)
fffff880`051b1000 fffff880`051ed000   vpchbus  vpchbus.sys  Wed Sep 23 02:32:32 2009 (4AB97AB0)
fffff880`02cc2000 fffff880`02cd6000   vpcnfltr vpcnfltr.sys Wed Sep 23 02:32:30 2009 (4AB97AAE)
fffff880`05185000 fffff880`051a2000   vpcusb   vpcusb.sys   Wed Sep 23 02:32:39 2009 (4AB97AB7)
fffff880`03e00000 fffff880`03e56180   vpcvmm   vpcvmm.sys   Wed Sep 23 02:32:38 2009 (4AB97AB6)
fffff880`02c00000 fffff880`02c93000   vsdatant vsdatant.sys Mon May 03 18:44:42 2010 (4BDF0B8A)
fffff880`0594f000 fffff880`0595c000   vwifibus vwifibus.sys Tue Jul 14 01:07:21 2009 (4A5BCC39)
fffff880`02dc4000 fffff880`02dda000   vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`02b9d000 fffff880`02ba7000   vwifimp  vwifimp.sys  Tue Jul 14 01:07:28 2009 (4A5BCC40)
fffff880`0439a000 fffff880`043b5000   wanarp   wanarp.sys   Tue Jul 14 01:10:21 2009 (4A5BCCED)
fffff880`019ed000 fffff880`019fd000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e4f000 fffff880`00ef3000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00ef3000 fffff880`00f02000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`02c93000 fffff880`02c9c000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`000e0000 fffff960`003ef000   win32k   win32k.sys   unavailable (00000000)
fffff880`05600000 fffff880`05609000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00f59000 fffff880`00f62000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`02adb000 fffff880`02afc000   WudfPf   WudfPf.sys   Tue Jul 14 01:05:37 2009 (4A5BCBD1)
fffff880`07c00000 fffff880`07c31000   WUDFRd   WUDFRd.sys   Tue Jul 14 01:06:06 2009 (4A5BCBEE)
Unloaded modules:
fffff880`07dea000 fffff880`07df8000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`07dbc000 fffff880`07dea000   usbvideo.sys
    Checksum:  00000000
    ImageSize:  0002E000
fffff880`081b5000 fffff880`081d2000   ew_hwusbdev.
    Checksum:  00000000
    ImageSize:  0001D000
fffff880`02ce0000 fffff880`02cee000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`07d8b000 fffff880`07dbc000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`08198000 fffff880`081b3000   USBSTOR.SYS
    Checksum:  00000000
    ImageSize:  0001B000
fffff880`081b5000 fffff880`081d2000   usbccgp.sys
    Checksum:  00000000
    ImageSize:  0001D000
fffff880`08198000 fffff880`081b5000   ew_hwusbdev.
    Checksum:  00000000
    ImageSize:  0001D000
fffff880`01905000 fffff880`01920000   USBSTOR.SYS
    Checksum:  00000000
    ImageSize:  0001B000
fffff880`07af0000 fffff880`07b61000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`018ec000 fffff880`018fa000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`018fa000 fffff880`01906000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01906000 fffff880`01911000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`01911000 fffff880`01924000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
Please note that we are all volunteers here. Although glad to help you, it all depends on who is on line at the time. But we do try to answer all queries a.s.a.p.
