AMOCO
1st off I can install Win7 x64 via SATA Mode,But when I try to install Win7 x64 via RAID0.When it Win7 restarts for the 1st time,I get either a BSOD or I get just a part of the screen(But still see cursor & I can move it).It shows only upper left of screen.So,I was wondering if there is a way to disable Win7 driver signing during Win7 installation?,So I can get the ULi SATA/RAID (M1575/M1697) Vista x64 driver installed.Also I was using a flash driver to install the sata/raid driver instead of a floppy drive,Does that matter?
Now if I press F8 after the 1st restart during Win7 installation,Then can I disable the Win7 driver signatures?BTW,I hope all this is in the right section.
Yes I believe so, but after the next reboot it reverts back to normal
so that would mean i would have to press F8 at every boot or get software to disable it permanently?
