help with display driver...
no matter what i do i cant get the display driver for the ati radeon 200m in my toshiba satellite l25-1196 to work. ive tried to install the vista drivers, which didnt work. i also tried to install the windows 7 drivers from the microsoft update catalog, but windows keeps saying that the standard VGA drivers are the most up to date
any ideas?
nvm i figured it out
How did you resolve the issue?
He probably had to change some settings within the Catalyst Control Center id imagine.
101610-18860-01.dmp
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state
Stack: nt! nt! nt! nt! nt! nt! nt! nt!
X64_0x9F_3_Rt64win7_IMAGE_pci.sys
The culprit here is Realtek 8136/8168/8169. Please update it as already mentioned above.
Update:
Rt64win7.sys Fri May 22 17:52:30 2009
TuneUpUtilitiesDriver64.sys Thu Sep 17 14:54:52 2009
TuneUpUtilities
RTL8187B.sys Thu Nov 05 07:51:31 2009
Realtek RTL8187B Wireless USB 2.0 Adapter
igdkmd64.sys Thu Aug 27 18:07:00 2009
Intel GMA
iaStor.sys Fri Jun 05 04:53:40 2009
Intel Matrix Storage
Check your notebook support for updates:
tos_sps64.sys Wed Jun 24 08:31:09 2009
Toshiba
PxHlpa64.sys Wed Jun 24 02:16:35 2009
Sonic Solutions
LPCFilter.sys Tue Jul 28 20:26:44 2009
COMPAL ELECTRONIC INC.
Loading Dump File [F:\a\Minidump\D M P\101610-18860-01.dmp]
DbsSplayTreeRangeMap::Add: ignoring zero-sized range at ?fffff800`00b9c4c0?
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02e1b000 PsLoadedModuleList = 0xfffff800`03058e50
Debug session time: Sat Oct 16 05:49:17.598 2010 (UTC - 5:00)
System Uptime: 0 days 0:13:08.548
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 9F, {3, fffffa8004729a20, fffff80000b9c4d8, fffffa8007861820}
Probably caused by : pci.sys
Followup: MachineOwner
0: kd> !analyze -v
A driver is causing an inconsistent power state.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: fffffa8004729a20, Physical Device Object of the stack
Arg3: fffff80000b9c4d8, Functional Device Object of the stack
Arg4: fffffa8007861820, The blocked IRP
Debugging Details:
DRVPOWERSTATE_SUBCODE:  3
IMAGE_NAME:  pci.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bc117
MODULE_NAME: pci
FAULTING_MODULE: fffff88000fb3000 pci
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x9F
PROCESS_NAME:  System
CURRENT_IRQL:  2
STACK_TEXT:
fffff800`00b9c488 fffff800`02efa273 : 00000000`0000009f 00000000`00000003 fffffa80`04729a20 fffff800`00b9c4d8 : nt!KeBugCheckEx
fffff800`00b9c490 fffff800`02e9729e : fffff800`00b9c5c0 fffff800`00b9c5c0 00000000`00000001 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x292b0
fffff800`00b9c530 fffff800`02e96dd6 : fffff800`0303b700 00000000`0000c573 00000000`00000000 00000000`00000000 : nt!KiProcessTimerDpcTable+0x66
fffff800`00b9c5a0 fffff800`02e974be : 00000001`d60301b4 fffff800`00b9cc18 00000000`0000c573 fffff800`030090e8 : nt!KiProcessExpiredTimerList+0xc6
fffff800`00b9cbf0 fffff800`02e96cb7 : 00000000`64c754c1 00000000`0000c573 00000000`64c7548e 00000000`00000073 : nt!KiTimerExpiration+0x1be
fffff800`00b9cc90 fffff800`02e93eea : fffff800`03005e80 fffff800`03013c40 00000000`00000001 fffff880`00000000 : nt!KiRetireDpcList+0x277
fffff800`00b9cd40 00000000`00000000 : fffff800`00b9d000 fffff800`00b97000 fffff800`00b9cd00 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
FAILURE_BUCKET_ID:  X64_0x9F_3_Rt64win7_IMAGE_pci.sys
fffff800`00bb6000 fffff800`00bc0000   kdcom    kdcom.dll    Tue Jul 14 04:31:07 2009 (4A5BDFDB)
fffff800`02e1b000 fffff800`033f7000   nt       ntkrnlmp.exe Sat Jun 19 07:16:41 2010 (4C1C44A9)
fffff800`033f7000 fffff800`03440000   hal      hal.dll      Tue Jul 14 04:27:36 2009 (4A5BDF08)
fffff880`00c00000 fffff880`00c43000   ks       ks.sys       Thu Mar 04 06:32:25 2010 (4B8F37D9)
fffff880`00c48000 fffff880`00c8c000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Tue Jul 14 04:29:10 2009 (4A5BDF66)
fffff880`00c8c000 fffff880`00ca0000   PSHED    PSHED.dll    Tue Jul 14 04:32:23 2009 (4A5BE027)
fffff880`00ca0000 fffff880`00cfe000   CLFS     CLFS.SYS     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00cfe000 fffff880`00dbe000   CI       CI.dll       Tue Jul 14 04:32:13 2009 (4A5BE01D)
fffff880`00dbe000 fffff880`00ddf000   raspptp  raspptp.sys  Tue Jul 14 03:10:18 2009 (4A5BCCEA)
fffff880`00e00000 fffff880`00e0f000   LPCFilter LPCFilter.sys Tue Jul 28 20:26:44 2009 (4A6F34D4)
fffff880`00e0f000 fffff880`00e24000   partmgr  partmgr.sys  Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`00e24000 fffff880`00e2d000   compbatt compbatt.sys Tue Jul 14 02:31:02 2009 (4A5BC3B6)
fffff880`00e2d000 fffff880`00e39000   BATTC    BATTC.SYS    Tue Jul 14 02:31:01 2009 (4A5BC3B5)
fffff880`00e39000 fffff880`00e4e000   volmgr   volmgr.sys   Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00e4e000 fffff880`00e93000   netbt    netbt.sys    Tue Jul 14 02:21:28 2009 (4A5BC178)
fffff880`00e96000 fffff880`00f3a000   Wdf01000 Wdf01000.sys Tue Jul 14 02:22:07 2009 (4A5BC19F)
fffff880`00f3a000 fffff880`00f49000   WDFLDR   WDFLDR.SYS   Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00f49000 fffff880`00fa0000   ACPI     ACPI.sys     Tue Jul 14 02:19:34 2009 (4A5BC106)
fffff880`00fa0000 fffff880`00fa9000   WMILIB   WMILIB.SYS   Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00fa9000 fffff880`00fb3000   msisadrv msisadrv.sys Tue Jul 14 02:19:26 2009 (4A5BC0FE)
fffff880`00fb3000 fffff880`00fe6000   pci      pci.sys      Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00fe6000 fffff880`00ff3000   vdrvroot vdrvroot.sys Tue Jul 14 03:01:31 2009 (4A5BCADB)
fffff880`01000000 fffff880`01073000   cng      cng.sys      Tue Jul 14 02:49:40 2009 (4A5BC814)
fffff880`01073000 fffff880`010a2000   ndiswan  ndiswan.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`010ae000 fffff880`0110a000   volmgrx  volmgrx.sys  Tue Jul 14 02:20:33 2009 (4A5BC141)
fffff880`0110a000 fffff880`01124000   mountmgr mountmgr.sys Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`01124000 fffff880`0112b000   pciide   pciide.sys   Tue Jul 14 02:19:49 2009 (4A5BC115)
fffff880`0112b000 fffff880`0113b000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`0113b000 fffff880`01199000   msrpc    msrpc.sys    Tue Jul 14 02:21:32 2009 (4A5BC17C)
fffff880`01199000 fffff880`011e5000   volsnap  volsnap.sys  Tue Jul 14 02:20:08 2009 (4A5BC128)
fffff880`01200000 fffff880`0124c000   fltmgr   fltmgr.sys   Tue Jul 14 02:19:59 2009 (4A5BC11F)
fffff880`0124c000 fffff880`01260000   fileinfo fileinfo.sys Tue Jul 14 02:34:25 2009 (4A5BC481)
fffff880`01260000 fffff880`0126be00   PxHlpa64 PxHlpa64.sys Wed Jun 24 02:16:35 2009 (4A416253)
fffff880`01273000 fffff880`0138f000   iaStor   iaStor.sys   Fri Jun 05 04:53:40 2009 (4A287AA4)
fffff880`0138f000 fffff880`01398000   atapi    atapi.sys    Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`01398000 fffff880`013c2000   ataport  ataport.SYS  Tue Jul 14 02:19:52 2009 (4A5BC118)
fffff880`013c2000 fffff880`013cd000   msahci   msahci.sys   Tue Jul 14 03:01:01 2009 (4A5BCABD)
fffff880`013cd000 fffff880`013d8000   amdxata  amdxata.sys  Tue May 19 20:56:59 2009 (4A12F2EB)
fffff880`013d8000 fffff880`013f3000   raspppoe raspppoe.sys Tue Jul 14 03:10:17 2009 (4A5BCCE9)
fffff880`01400000 fffff880`01411000   pcw      pcw.sys      Tue Jul 14 02:19:27 2009 (4A5BC0FF)
fffff880`01411000 fffff880`0141b000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 02:19:45 2009 (4A5BC111)
fffff880`0141b000 fffff880`0142d000   umbus    umbus.sys    Tue Jul 14 03:06:56 2009 (4A5BCC20)
fffff880`01434000 fffff880`015d7000   Ntfs     Ntfs.sys     Tue Jul 14 02:20:47 2009 (4A5BC14F)
fffff880`015d7000 fffff880`015f1000   ksecdd   ksecdd.sys   Tue Jul 14 02:20:54 2009 (4A5BC156)
fffff880`01600000 fffff880`0164a000   fwpkclnt fwpkclnt.sys Tue Jul 14 02:21:08 2009 (4A5BC164)
fffff880`0164a000 fffff880`0164ee00   TVALZ_O  TVALZ_O.SYS  Tue Jul 14 05:19:26 2009 (4A5BEB2E)
fffff880`0164f000 fffff880`01673000   rasl2tp  rasl2tp.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`0167f000 fffff880`01771000   ndis     ndis.sys     Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`01771000 fffff880`017d1000   NETIO    NETIO.SYS    Tue Jul 14 02:21:46 2009 (4A5BC18A)
fffff880`017d1000 fffff880`017fc000   ksecpkg  ksecpkg.sys  Fri Dec 11 08:03:32 2009 (4B21E0B4)
fffff880`01800000 fffff880`019fd000   tcpip    tcpip.sys    Mon Jun 14 06:39:04 2010 (4C15A458)
fffff880`01a00000 fffff880`01a1a000   rassstp  rassstp.sys  Tue Jul 14 03:10:25 2009 (4A5BCCF1)
fffff880`01a1a000 fffff880`01a94000   tos_sps64 tos_sps64.sys Wed Jun 24 08:31:09 2009 (4A41BA1D)
fffff880`01a94000 fffff880`01a9c000   spldr    spldr.sys    Mon May 11 19:56:27 2009 (4A0858BB)
fffff880`01a9c000 fffff880`01ad6000   rdyboost rdyboost.sys Tue Jul 14 02:34:34 2009 (4A5BC48A)
fffff880`01ad6000 fffff880`01ae8000   mup      mup.sys      Tue Jul 14 02:23:45 2009 (4A5BC201)
fffff880`01ae8000 fffff880`01af1000   hwpolicy hwpolicy.sys Tue Jul 14 02:19:22 2009 (4A5BC0FA)
fffff880`01af1000 fffff880`01b2b000   fvevol   fvevol.sys   Sat Sep 26 05:34:26 2009 (4ABD7DB2)
fffff880`01b2b000 fffff880`01b41000   disk     disk.sys     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`01b41000 fffff880`01b71000   CLASSPNP CLASSPNP.SYS Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`01b7f000 fffff880`01b8a000   Msfs     Msfs.SYS     Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`01b8a000 fffff880`01b9b000   Npfs     Npfs.SYS     Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`01b9b000 fffff880`01bb9000   tdx      tdx.sys      Tue Jul 14 02:21:15 2009 (4A5BC16B)
fffff880`01bb9000 fffff880`01bc6000   TDI      TDI.SYS      Tue Jul 14 02:21:18 2009 (4A5BC16E)
fffff880`01bc6000 fffff880`01bec000   tunnel   tunnel.sys   Tue Jul 14 03:09:37 2009 (4A5BCCC1)
fffff880`01bec000 fffff880`01bf7000   connctfy connctfy.sys Thu May 27 12:19:35 2010 (4BFE3927)
fffff880`02800000 fffff880`0282d000   mrxsmb   mrxsmb.sys   Sat Feb 27 09:52:19 2010 (4B88CF33)
fffff880`0282d000 fffff880`0287b000   mrxsmb10 mrxsmb10.sys Sat Feb 27 09:52:28 2010 (4B88CF3C)
fffff880`0287b000 fffff880`0289e000   mrxsmb20 mrxsmb20.sys Sat Feb 27 09:52:26 2010 (4B88CF3A)
fffff880`0289e000 fffff880`028a8000   vwifimp  vwifimp.sys  Tue Jul 14 03:07:28 2009 (4A5BCC40)
fffff880`028a8000 fffff880`028c0000   adfs     adfs.SYS     Mon Nov 03 18:48:14 2008 (490F2B4E)
fffff880`028c0000 fffff880`028cc000   npf      npf.sys      Fri Jun 25 19:50:58 2010 (4C24DE72)
fffff880`028cc000 fffff880`028d6000   mbam     mbam.sys     Thu Apr 29 20:16:04 2010 (4BD9BED4)
fffff880`028f2000 fffff880`029ba000   HTTP     HTTP.sys     Tue Jul 14 02:22:16 2009 (4A5BC1A8)
fffff880`029ba000 fffff880`029d8000   bowser   bowser.sys   Tue Jul 14 02:23:50 2009 (4A5BC206)
fffff880`029d8000 fffff880`029f0000   mpsdrv   mpsdrv.sys   Tue Jul 14 03:08:25 2009 (4A5BCC79)
fffff880`02e00000 fffff880`02e25000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 02:38:51 2009 (4A5BC58B)
fffff880`02e25000 fffff880`02e35000   watchdog watchdog.sys Tue Jul 14 02:37:35 2009 (4A5BC53F)
fffff880`02e35000 fffff880`02e3e000   RDPCDD   RDPCDD.sys   Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`02e3e000 fffff880`02e47000   rdpencdd rdpencdd.sys Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`02e47000 fffff880`02f63000   dump_iaStor dump_iaStor.sys Fri Jun 05 04:53:40 2009 (4A287AA4)
fffff880`02f78000 fffff880`02fa2000   cdrom    cdrom.sys    Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`02fa2000 fffff880`02fcf000   MpFilter MpFilter.sys Sat Mar 20 07:58:08 2010 (4BA463F0)
fffff880`02fcf000 fffff880`02fd8000   Null     Null.SYS     Tue Jul 14 02:19:37 2009 (4A5BC109)
fffff880`02fd8000 fffff880`02fdf000   Beep     Beep.SYS     Tue Jul 14 03:00:13 2009 (4A5BCA8D)
fffff880`02fdf000 fffff880`02fed000   vga      vga.sys      Tue Jul 14 02:38:47 2009 (4A5BC587)
fffff880`02fed000 fffff880`02ff6000   rdprefmp rdprefmp.sys Tue Jul 14 03:16:35 2009 (4A5BCE63)
fffff880`03c00000 fffff880`03c1e000   dfsc     dfsc.sys     Tue Jul 14 02:23:44 2009 (4A5BC200)
fffff880`03c1e000 fffff880`03c2f000   blbdrive blbdrive.sys Tue Jul 14 02:35:59 2009 (4A5BC4DF)
fffff880`03c2f000 fffff880`03c45000   AgileVpn AgileVpn.sys Tue Jul 14 03:10:24 2009 (4A5BCCF0)
fffff880`03c45000 fffff880`03ccf000   afd      afd.sys      Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`03ccf000 fffff880`03cd8000   wfplwf   wfplwf.sys   Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`03cd8000 fffff880`03cfe000   pacer    pacer.sys    Tue Jul 14 03:09:41 2009 (4A5BCCC5)
fffff880`03cfe000 fffff880`03d14000   vwififlt vwififlt.sys Tue Jul 14 03:07:22 2009 (4A5BCC3A)
fffff880`03d14000 fffff880`03d23000   netbios  netbios.sys  Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`03d23000 fffff880`03d3e000   wanarp   wanarp.sys   Tue Jul 14 03:10:21 2009 (4A5BCCED)
fffff880`03d3e000 fffff880`03d52000   termdd   termdd.sys   Tue Jul 14 03:16:36 2009 (4A5BCE64)
fffff880`03d52000 fffff880`03d6c000   SCDEmu   SCDEmu.SYS   Mon Apr 12 11:52:25 2010 (4BC2DF49)
fffff880`03d6c000 fffff880`03dbd000   rdbss    rdbss.sys    Tue Jul 14 02:24:09 2009 (4A5BC219)
fffff880`03dbd000 fffff880`03dc9000   nsiproxy nsiproxy.sys Tue Jul 14 02:21:02 2009 (4A5BC15E)
fffff880`03dc9000 fffff880`03dd4000   mssmbios mssmbios.sys Tue Jul 14 02:31:10 2009 (4A5BC3BE)
fffff880`03dd4000 fffff880`03de3000   discache discache.sys Tue Jul 14 02:37:18 2009 (4A5BC52E)
fffff880`03de3000 fffff880`03def000   ndistapi ndistapi.sys Tue Jul 14 03:10:00 2009 (4A5BCCD8)
fffff880`03def000 fffff880`03dfc000   taphss   taphss.sys   Tue Sep 15 22:58:23 2009 (4AAFF1DF)
fffff880`03e00000 fffff880`03e52000   SynTP    SynTP.sys    Fri Feb 19 05:36:15 2010 (4B7E072F)
fffff880`03e52000 fffff880`03e61000   mouclass mouclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`03e61000 fffff880`03e6b000   tdcmdpst tdcmdpst.sys Thu Jul 30 11:39:35 2009 (4A715C47)
fffff880`03e73000 fffff880`0457a380   igdkmd64 igdkmd64.sys Thu Aug 27 18:07:00 2009 (4A96A114)
fffff880`0457b000 fffff880`045b4000   Rt64win7 Rt64win7.sys Fri May 22 17:52:30 2009 (4A16BC2E)
fffff880`045b4000 fffff880`045c3000   kbdclass kbdclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`045c3000 fffff880`045d0000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 15:17:04 2009 (4A1151C0)
fffff880`045d0000 fffff880`045e6000   intelppm intelppm.sys Tue Jul 14 02:19:25 2009 (4A5BC0FD)
fffff880`045e6000 fffff880`045f6000   CompositeBus CompositeBus.sys Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`04600000 fffff880`04611000   usbehci  usbehci.sys  Tue Jul 14 03:06:30 2009 (4A5BCC06)
fffff880`04611000 fffff880`04635000   HDAudBus HDAudBus.sys Tue Jul 14 03:06:13 2009 (4A5BCBF5)
fffff880`04635000 fffff880`04639500   CmBatt   CmBatt.sys   Tue Jul 14 02:31:03 2009 (4A5BC3B7)
fffff880`0463a000 fffff880`04658000   i8042prt i8042prt.sys Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`04658000 fffff880`04659f00   USBD     USBD.SYS     Tue Jul 14 03:06:23 2009 (4A5BCBFF)
fffff880`0465a000 fffff880`0465b480   swenum   swenum.sys   Tue Jul 14 03:00:18 2009 (4A5BCA92)
fffff880`0465c000 fffff880`04750000   dxgkrnl  dxgkrnl.sys  Fri Oct 02 04:00:14 2009 (4AC5509E)
fffff880`04750000 fffff880`04796000   dxgmms1  dxgmms1.sys  Tue Jul 14 02:38:32 2009 (4A5BC578)
fffff880`04796000 fffff880`047a3000   usbuhci  usbuhci.sys  Tue Jul 14 03:06:27 2009 (4A5BCC03)
fffff880`047a3000 fffff880`047f9000   USBPORT  USBPORT.SYS  Tue Jul 14 03:06:31 2009 (4A5BCC07)
fffff880`04c00000 fffff880`04c53000   nwifi    nwifi.sys    Tue Jul 14 03:07:23 2009 (4A5BCC3B)
fffff880`04c53000 fffff880`04c66000   ndisuio  ndisuio.sys  Tue Jul 14 03:09:25 2009 (4A5BCCB5)
fffff880`04c66000 fffff880`04c7e000   rspndr   rspndr.sys   Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`04cf5000 fffff880`04d4f000   usbhub   usbhub.sys   Tue Jul 14 03:07:09 2009 (4A5BCC2D)
fffff880`04d4f000 fffff880`04d64000   NDProxy  NDProxy.SYS  Tue Jul 14 03:10:05 2009 (4A5BCCDD)
fffff880`04d64000 fffff880`04d87000   luafv    luafv.sys    Tue Jul 14 02:26:13 2009 (4A5BC295)
fffff880`04d87000 fffff880`04da8000   WudfPf   WudfPf.sys   Tue Jul 14 03:05:37 2009 (4A5BCBD1)
fffff880`04da8000 fffff880`04dbd000   lltdio   lltdio.sys   Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`05c06000 fffff880`05e69800   RTKVHD64 RTKVHD64.sys Tue Oct 05 12:58:40 2010 (4CAAF6D0)
fffff880`05e6a000 fffff880`05ea7000   portcls  portcls.sys  Tue Jul 14 03:06:27 2009 (4A5BCC03)
fffff880`05ea7000 fffff880`05ec9000   drmk     drmk.sys     Tue Jul 14 04:01:25 2009 (4A5BD8E5)
fffff880`05ec9000 fffff880`05ece200   ksthunk  ksthunk.sys  Tue Jul 14 03:00:19 2009 (4A5BCA93)
fffff880`05ecf000 fffff880`05f47000   RTL8187B RTL8187B.sys Thu Nov 05 07:51:31 2009 (4AF267E3)
fffff880`05f47000 fffff880`05f54000   vwifibus vwifibus.sys Tue Jul 14 03:07:21 2009 (4A5BCC39)
fffff880`05f54000 fffff880`05f66000   dc3d     dc3d.sys     Thu Jul 01 13:07:45 2010 (4C2C68F1)
fffff880`05f66000 fffff880`05f6e080   HIDPARSE HIDPARSE.SYS Tue Jul 14 03:06:17 2009 (4A5BCBF9)
fffff880`05f6f000 fffff880`05f7d000   hidusb   hidusb.sys   Tue Jul 14 03:06:22 2009 (4A5BCBFE)
fffff880`05f7d000 fffff880`05f96000   HIDCLASS HIDCLASS.SYS Tue Jul 14 03:06:21 2009 (4A5BCBFD)
fffff880`05f96000 fffff880`05fa2000   NuidFltr NuidFltr.sys Tue Jun 29 11:54:32 2010 (4C29B4C8)
fffff880`05fa2000 fffff880`05faf000   mouhid   mouhid.sys   Tue Jul 14 03:00:20 2009 (4A5BCA94)
fffff880`05faf000 fffff880`05fbf000   point64  point64.sys  Tue Jun 29 11:54:31 2010 (4C29B4C7)
fffff880`05fbf000 fffff880`05fcd000   crashdmp crashdmp.sys Tue Jul 14 03:01:01 2009 (4A5BCABD)
fffff880`05fcd000 fffff880`05fe0000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 02:21:51 2009 (4A5BC18F)
fffff880`05fe0000 fffff880`05fec000   Dxapi    Dxapi.sys    Tue Jul 14 02:38:28 2009 (4A5BC574)
fffff880`05fec000 fffff880`05ffa000   monitor  monitor.sys  Tue Jul 14 02:38:52 2009 (4A5BC58C)
fffff880`07800000 fffff880`07896000   srv      srv.sys      Fri Aug 27 06:38:00 2010 (4C773318)
fffff880`07896000 fffff880`0789e000   TuneUpUtilitiesDriver64 TuneUpUtilitiesDriver64.sys Thu Sep 17 14:54:52 2009 (4AB2238C)
fffff880`078a2000 fffff880`07948000   peauth   peauth.sys   Tue Jul 14 04:01:19 2009 (4A5BD8DF)
fffff880`07948000 fffff880`07975000   srvnet   srvnet.sys   Fri Aug 27 06:37:24 2010 (4C7732F4)
fffff880`07975000 fffff880`07987000   tcpipreg tcpipreg.sys Tue Jul 14 03:09:49 2009 (4A5BCCCD)
fffff880`07987000 fffff880`079ee000   srv2     srv2.sys     Fri Aug 27 06:37:46 2010 (4C77330A)
fffff880`079ee000 fffff880`079fe000   MpNWMon  MpNWMon.sys  Sat Mar 20 07:58:00 2010 (4BA463E8)
fffff960`000a0000 fffff960`003af000   win32k   win32k.sys   unavailable (00000000)
fffff960`005f0000 fffff960`005fa000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff960`006f0000 fffff960`00717000   cdd      cdd.dll      unavailable (00000000)
fffff960`00970000 fffff960`009d1000   ATMFD    ATMFD.DLL    unavailable (00000000)
Unloaded modules:
fffff880`04c7e000 fffff880`04cef000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01b71000 fffff880`01b7f000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`02e49000 fffff880`02f65000   dump_iaStor.
    Checksum:  00000000
    ImageSize:  0011C000
fffff880`02f65000 fffff880`02f78000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
