Windows 7 Help with Interent Browser display
Fulton2874
Not sure if this is the right place to post this.
I just upgraded to windows 7, and am really enjoying it.
I have one issue however. I want my web pages to spread out across my widescreen monitor.
The background of the website stretches across the screen, but the part of the website that would normally be viewed is crunched together and centered.
Link Removed due to 404 Error
Thanks
I was going to add an image but it cant seem to find it on my computer.
Thanks
Try pushing the "Control" and the "+" button simultaneously.
To take a screen shot push the "Print Screen" button then open "Paint" and click on Paste. You can edit and save it from there.
Got to 'All Programs > Accesories', there you will find the 'Snipping Tool' which you can use to take a screenshot. It would be a big help :)
Thanks
