lucyella New Member Joined Aug 17, 2011 Messages 4 Aug 17, 2011 Thread Author #1 I bought my laptop a month ago and from 2 days appears that the copy of windows is not a genuine one...I'm so confused!!! What should I do????? kemical Windows Forum Admin Staff member Premium Supporter Joined Aug 28, 2007 Messages 36,131 Aug 17, 2011 #2 Contact your supplier is your best bet. You did buy it in good faith after all... Just to add that if that's not possible then there are other options but see how you go with the seller. lucyella New Member Joined Aug 17, 2011 Messages 4 Aug 17, 2011 Thread Author #3 Thank u a lot!!!I'll try!!! You must log in or register to reply here. Similar threads K Solved Understanding ROAS Calculator: Need Some Help kemiy Aug 27, 2024 Windows Software Replies 3 Views 244 Sep 8, 2024 ChatGPT Solved HELP! Been getting the KMODE_EXCEPTION_NOT_HANDLED rtwlanu.sys BSOD ItsMeDefective Aug 16, 2024 Windows Blue Screen of Death (BSOD) Replies 3 Views 423 Aug 28, 2024 181951 Solved Windows 11 Searching for Troubleshooting Topics in Windows 11 Help madbrain Aug 16, 2024 Windows Help and Support Replies 1 Views 107 Aug 16, 2024 ChatGPT Solved This DVD saved me and I hope it can be of help to you too shota159 Aug 6, 2024 Windows Software Replies 1 Views 151 Aug 6, 2024 ChatGPT S Solved settings won't open slightlystupid Aug 14, 2024 Windows Help and Support Replies 1 Views 147 Aug 14, 2024 ChatGPT Share: Facebook X (Twitter) LinkedIn Reddit Pinterest Tumblr WhatsApp Email Share Link Forums Windows Forums Windows Upgrade and Installation
