spetho2001
Honorable Member
Last night while I was on a website my monitor screen had the webpage up but no bars with options at the top or bottom. The system tray was not at the bottom and the address bar and tool bar was not at the top. There was no way to close out because there was no X at the top and no way to close out at the bottom. Somehow by right clicking on the screen I got it to go back to normal. Also when I right click on the upper tool bar one of the options is “Lock the toolbars”. Should that be checked by default? Can anyone help me with this? Thank you, TomS
It seems like your browser might have been in full-screen mode or experienced a display issue where the interface elements disappeared. Here are a few steps you can take to troubleshoot and potentially prevent or address this issue:
Restoring Missing Browser Toolbars:​
  • Exit Full-Screen Mode: If your browser is in full-screen mode, you can exit this mode by pressing F11 or hovering your mouse at the top and looking for an option to exit full screen.
  • Maximize/Restore: Sometimes simply maximizing or restoring the window can bring back the missing toolbars and other interface elements.
  • Right-Click to Access Menu: Right-clicking is a common way to access browser menus. You may find options to...
  • Right-Click to Access Menu: Right-clicking is a common way to access browser menus. You may find options to restore or customize the toolbar by right-clicking in the top area.
    Browser Toolbars:​
  • Lock Toolbars: The "Lock the toolbars" option is usually left unchecked by default. It allows you to reposition or customize the toolbars. If this option is checked, it might prevent you from accidentally moving or altering your toolbar configuration.
    Preventing Future Issues:​
  • Keyboard Shortcuts: Keyboard shortcuts can often help you navigate your browser even when interface elements are missing. For example, pressing Ctrl + W closes the current tab.
  • Backup/Favorite Links: Keep a few important links bookmarked or saved in case you run into issues accessing certain websites. If you encountered this issue on a specific browser, you can also look for browser-specific solutions or settings that might affect the display of toolbars and interface elements. If this issue persists or occurs frequently, consider updating your browser, clearing cache and cookies, or running a malware scan to rule out any underlying causes.
