VIDEO How Much Water Cooling is Enough?? - RTX 3090
whoosh
Cooler King
:cool:
Water Cooling the RTX 3090 is... More Complicated In this captivating video, we delve into the intricate world of water cooling for NVIDIA's powerhouse, the RTX 3090. The video's host explores why traditional cooling methods may not suffice for this particularly demanding graphics card, outlining a detailed approach to developing an effective water cooling solution. The video begins by acknowledging that previous water cooling setups followed a simple rule: one 120mm radiator per heat-generating component. However, for the RTX 3090, which is both power-hungry and physically large, this guideline might not hold. The host reveals the intent to test various radiator configurations to determine the actual cooling needs of the card.
Key Insights from the Video​
  1. Testing Process: Initially, the team focuses on air cooling, setting up an Asus Strix RTX 3090 with an extensive fan configuration (nine fans in total). The setup is subjected to rigorous testing, which indicates that thermal throttling should not be an issue. This establishes a baseline before implementing water cooling.
  2. Water Block Installation: They proceed with the installation of an EK-Quantum Vector water block. This step proves somewhat challenging due to design oversights involving capacitor clearance, but eventually, they manage to fit the block securely.
  3. Initial Cooling Results: The preliminary findings from a single radiator are less than promising, revealing similar temperatures to air cooling. This outcome emphasizes the need for a shift in approach — transitioning to a dual radiator dramatically drops temperatures by almost 20 degrees, indicating more effective cooling.
  4. Dual vs. Triple Radiators: The video concludes the comparison with a dual radiator setup, suggesting it as the sweet spot for performance, while also evaluating a triple radiator option. Although the triple radiator provides slightly enhanced cooling, the increase is deemed modest and may not be necessary for all setups.
  5. Future-Proofing Needs: The presenter discusses the importance of considering future upgrades in any cooling system design, advocating for larger radiators if users plan to add components later.
    Community Engagement​
    As fans of PC building and cooling techniques, this video invites us to ponder our own systems. Have you tried water cooling your GPU? What setups have you found most effective for managing temperatures? Share your experiences, tips, and any recommended products based on this video. Feel free to check out related discussions in our forum on water cooling strategies, or explore other threads that dive into the hardware setup for building powerful gaming rigs!​
    This analysis captures the essence of the content while ensuring that WindowsForum users find it informative and relatable. Let's discuss this further! What are your thoughts on the complexities of cooling high-performance GPUs like the RTX 3090?
Support hub
