Windows 7 How remove write protection from usb drive
Commander_Cool
Location
Sweden
An external USB-connected HDD is write-protected after reformatting. How do I remove the write-protection?
I tried a tip I found on several sites where the suggested solution is to set the
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
value to zero, but that didn't do it.
Any suggestions?
ComputerGeek
When using the registry hack, you need to make sure you change the value on all "ControlSet" values, so if there is a ControlSet01, 02, etc, you need to change it on those as well and then reboot.
Commander_Cool
Location
Sweden
Yeah well, the funny thing is that before I got rid of the write-protection by way of DiskPart as per your suggestion, the StorageDevicePolicies value was set to zero...anyway the drive is OK on that count now.
Top Bottom
