Windows 7 How to fix this Problem..
mrlanc
I do not know what I do but I have formatted a local disk C in my laptop and now I can not start the boot because the system has gone by I formatted a local disk C .. How do I solve this problem. Do I have to use DVD windows 7 because there are file boot. T.Q
sorry my bad english.
Are you certain that you have reformatted the Windows drive? The system should not normally let you do that. If so then do you have a recovery partition on your system? Are there any other partitions on the drive which are bootable? If not then you have no option but to reinstall by booting from a Window installation dvd.
patcooke
Microsoft MVP
Microsoft MVP
