How to install an UEFI-based ISO (bootable with DVD) on an USB flash?
pstein
I have an UEFI-based ISO file for a tool on windows (This tool is NOT a WinOS but a separate utility tool).
If I burn this ISO onto a DVD and boot it on an UEFI computer (without Secure Boot) everything works.
However If I put this ISO with e.g. Rufus onto an USB flash drive then the USB flash drive does not boot and show an error message:
"Could not locate 'EFI\boot\bootx64.efi': Not found
Yes, the file and the directory is missing.
After a long search I found a hint:
Surprisingly a DVD-bootable ISO is NOT automatically bootable from USB flash drive due to different handling of Bootmanager.
Interesting. I have not expected that.
Now my problem is:
Can I convert this only-on-DVD-bootable ISO to a bootable-from-USB-flash-drive ISO?
Alternatively it would be acceptable to create at first an UEFI-bootable USB flash drive and extract (which?) tool files out of the ISO onto this USB flash drive. I guess I have to declare (where?) what program should be started during USB flash drive boot.
Any suggestions?
E.g.Ventoy does not help.
It must be a solution which prepares the USB flash drive for simple UEFI boot and let me add (before or afterwards) an additional tool.
Peter
pstein
Now my problem is:
Any suggestions?
Peter
pstein
Now my problem is:
Any suggestions?
Peter
pstein
Now my problem is:
Any suggestions?
Peter
Guyiss
Why not download a Windows iso file and make a bootable USB for Windows computer,just like this,in this way, the problem will be solved easily.
I don’t think that using DVD is more suitable than USB, but from a security point of view, it’s better to use USB to make a bootable drive.
Guyiss
Why not download a Windows iso file and make a bootable USB for Windows computer,in this way, the problem will be solved easily.
mizzchic
Well-Known Member
im not sure if i get usb and flash drive ? I found my old fone i didt no how or why thats on FC255EE7-234D-4EE2-B58A-DC261739C2F8.jpeg
