Windows 7 I have a blue screen problem ks.sys
engEL3OMDA
Hello ...
How are your conditions??
I have a big problem and very stubborn and difficult to resolve tried to solve all the roads and in many forums did not know a solution so far ..
The problem in detail ...
I kind of card Satellite Twinhan Issue No. 1027 color red ...
Specifications device is very good and fast ..
Go into the details of the problem ..On the move between channels from one channel to another show me the problem suddenly without giving any reasons, and each time the problem in ks.sys file and tried a lot of programs, including progdvb, dreamdvb and dvbviewer and every time the same problem ..
If moved between channels fast or slow whatever the problem appears ..
Of course I tried on all operating systems from XP to Seven and the same problem ...
In file attachments compressed file original ks.sys and blue screen ....
I hope I find you have a solution to this problem ...
Thanks in advance and waiting / / /
Satellite card is the biggest problem. Un-install it to see if it fixes the BSOD's. I have no idea on how to find Win7 compatible drivers since it's been closed since 2009.
I have seen numerous problems with Comodo. Un-install to test - then reinstall if you think it's not causing problems.
I have the screening program Memtest86 + by Hirens BootCD ...
Now these are the images the process .. :
Remove (un-install) RivaTuner. DO NOT use Riva Tuner, MSI Afterburner, or EVGA Precision - all have BSOD problems in Windows 7
You do so and deleted all of these programs ..Queries I've used MSI Afterburner program in the detection process to heat VGA card constantly inside and outside games ..Do you still harmful to my computer?
Remove (un-install) Satellite software. DO NOT reinstall until we have fixed the BSOD problem.
Blue Screen BSOD problem with me, but do not appear during my card use Satellite ...
I have a problem during the Setup program Zemana AntiLogger ,So that I can delete the entire program .
Thank you for watching my problem ..
Do you recommend programs important in the maintenance of the device?
MemTest86+ screenshots look good.
Here is screenshot of bad MemTest86+: http://upload.wikimedia.org/wikipedia/commons/0/0c/Memtest86+_2-errors-found.jpg
Riva Tuner (and MSI Afterburner and EVGA Precision) MAY be causing BSOD.
When the system is fixed, then try one new program at a time to see if it causes problems.
Try Speedfan (free here: Download SpeedFan - Access temperature sensor in your computer )
It is not as easy to use, but it does allow you to control fan speed.
Does not have to be use of Satellite card that causes BSOD.
It may be interaction between different components or drivers that causes the problem.
We remove things that are known problems when trying to fix.
Eventually we stop the BSOD's. Then you can add things back - one at a time - while seeing which one causes BSOD.
Do not try to fix more at this time.
Wait until we see results from previous post (BSOD), then we move on to next steps.
We will fix the Zemana AntiLogger later.
Here is screenshot of bad MemTest86+: http://upload.wikimedia.org/wikipedia/commons/0/0c/Memtest86%2B_2-errors-found.jpg
Now I have a good news ..Two days and I pressure on Satellite TV ..And a good score does not exist BOSD ..
Searched the Internet for the latest version came down from the company ..
Old omitted Driver and new proven Driver ..
My recent work is maintenance for the windows version I have ..
I have a problem in installing the definition nivida example not satisfied proves nvidia physx ..
All I want to do the work of comprehensive maintenance of the device .. I do not want to setup a new Windows ...
Thank you very much for following up good ...
Wow .. New blue screen ..BOSD ..
Note you have a new setup windows ..
I have got a problem in the Internet in the old windows .. I got up installing new windows ...
Note have installed MSI Afterburner .. I think the problem completely dissolved ..
Do you know the program fraps? .. Work such as that of the MSI program within games ...
Are there problems on this program fraps ...
In file attachments BOSD ..
No problems that I know about.
Look at the stack text below.
It is read from the bottom to the top (that is the sequence of events).
Notice that "" is the only non-Microsoft driver mentioned.
It belongs to the Satellite software.
You must uninstall the Satellite software and test to see if it stops the BSOD's
STACK_TEXT:
fffff880`08a41308 fffff800`02fb7be9 : 00000000`000000c2 00000000`00000007 00000000`0000109b 00000000`040b0010 : nt!KeBugCheckEx
fffff880`08a41310 fffff880`04a45a57 : fffffa80`0703e170 00000000`00000000 00000000`00000000 fffffa80`0703e170 : nt!ExDeferredFreePool+0x1201
fffff880`08a413c0 fffff880`04a45997 : fffffa80`0713b810 00000000`00000000 fffffa80`06edf010 fffffa80`0713b810 : ks!CKsQueue::FreeStreamPointer+0x6b
fffff880`08a413f0 fffff880`04a8e898 : fffffa80`09e22438 fffffa80`09e22480 fffffa80`08b87510 fffffa80`0703e170 : ks!CKsQueue::DeleteStreamPointer+0x147
fffff880`08a41430 fffffa80`09e22438 : fffffa80`09e22480 fffffa80`08b87510 fffffa80`0703e170 fffffa80`0713b870 : [COLOR=#ff0000]88xBDACap[/COLOR]+0x2898
fffff880`08a41438 fffffa80`09e22480 : fffffa80`08b87510 fffffa80`0703e170 fffffa80`0713b870 fffffa80`0744c9d0 : 0xfffffa80`09e22438
fffff880`08a41440 fffffa80`08b87510 : fffffa80`0703e170 fffffa80`0713b870 fffffa80`0744c9d0 00000000`00000286 : 0xfffffa80`09e22480
fffff880`08a41448 fffffa80`0703e170 : fffffa80`0713b870 fffffa80`0744c9d0 00000000`00000286 fffff880`04a8fa15 : 0xfffffa80`08b87510
fffff880`08a41450 fffffa80`0713b870 : fffffa80`0744c9d0 00000000`00000286 fffff880`04a8fa15 fffffa80`09c02980 : 0xfffffa80`0703e170
fffff880`08a41458 fffffa80`0744c9d0 : 00000000`00000286 fffff880`04a8fa15 fffffa80`09c02980 00000000`0033c040 : 0xfffffa80`0713b870
fffff880`08a41460 00000000`00000286 : fffff880`04a8fa15 fffffa80`09c02980 00000000`0033c040 fffffa80`09e22438 : 0xfffffa80`0744c9d0
fffff880`08a41468 fffff880`04a8fa15 : fffffa80`09c02980 00000000`0033c040 fffffa80`09e22438 fffffa80`09e22480 : 0x286
fffff880`08a41470 fffffa80`09c02980 : 00000000`0033c040 fffffa80`09e22438 fffffa80`09e22480 fffff880`08a41c20 : [COLOR=#ff0000]88xBDACap[/COLOR]+0x3a15
fffff880`08a41478 00000000`0033c040 : fffffa80`09e22438 fffffa80`09e22480 fffff880`08a41c20 fffff880`04a8d0dd : 0xfffffa80`09c02980
fffff880`08a41480 fffffa80`09e22438 : fffffa80`09e22480 fffff880`08a41c20 fffff880`04a8d0dd fffffa80`08fa8740 : 0x33c040
fffff880`08a41488 fffffa80`09e22480 : fffff880`08a41c20 fffff880`04a8d0dd fffffa80`08fa8740 fffff880`04a913f0 : 0xfffffa80`09e22438
fffff880`08a41490 fffff880`08a41c20 : fffff880`04a8d0dd fffffa80`08fa8740 fffff880`04a913f0 fffff880`08a41a00 : 0xfffffa80`09e22480
fffff880`08a41498 fffff880`04a8d0dd : fffffa80`08fa8740 fffff880`04a913f0 fffff880`08a41a00 fffff880`08a41a00 : 0xfffff880`08a41c20
fffff880`08a414a0 fffffa80`08fa8740 : fffff880`04a913f0 fffff880`08a41a00 fffff880`08a41a00 fffffa80`09e22438 : [COLOR=#ff0000]88xBDACap[/COLOR]+0x10dd
fffff880`08a414a8 fffff880`04a913f0 : fffff880`08a41a00 fffff880`08a41a00 fffffa80`09e22438 fffff880`08a41660 : 0xfffffa80`08fa8740
fffff880`08a414b0 fffff880`08a41a00 : fffff880`08a41a00 fffffa80`09e22438 fffff880`08a41660 00000000`00000001 : [COLOR=#ff0000]88xBDACap[/COLOR]+0x53f0
fffff880`08a414b8 fffff880`08a41a00 : fffffa80`09e22438 fffff880`08a41660 00000000`00000001 fffff880`04a8c3c1 : 0xfffff880`08a41a00
fffff880`08a414c0 fffffa80`09e22438 : fffff880`08a41660 00000000`00000001 fffff880`04a8c3c1 00000000`00000000 : 0xfffff880`08a41a00
fffff880`08a414c8 fffff880`08a41660 : 00000000`00000001 fffff880`04a8c3c1 00000000`00000000 fffff880`04a8ca1b : 0xfffffa80`09e22438
fffff880`08a414d0 00000000`00000001 : fffff880`04a8c3c1 00000000`00000000 fffff880`04a8ca1b fffffa80`08d98e70 : 0xfffff880`08a41660
fffff880`08a414d8 fffff880`04a8c3c1 : 00000000`00000000 fffff880`04a8ca1b fffffa80`08d98e70 fffffa80`09e22200 : 0x1
fffff880`08a414e0 00000000`00000000 : fffff880`04a8ca1b fffffa80`08d98e70 fffffa80`09e22200 00000000`00000004 : [COLOR=#ff0000]88xBDACap[/COLOR]+0x3c1
Analysis:
[font=lucida console]**************************Mon Aug 27 07:35:59.463 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082712-21496-01.dmp]
Windows 7 Kernel Version [B]7601 [/B](Service Pack 1) MP (8 procs) Free x64
Built by: [B]7601[/B].17835.amd64fre.win7sp1_gdr.120503-2030
System Uptime:[B]0 days 0:23:54.572[/B]
BugCheck Code: [B]BugCheck C2, {7, 109b, 40b0010, fffffa800713b810}[/B]
*** WARNING: Unable to verify timestamp for 88xBDACap.sys
*** ERROR: Module load completed but symbols could not be loaded for 88xBDACap.sys
Probably caused by :[B]ks.sys ( ks!CKsQueue::FreeStreamPointer+6b )[/B]
BugCheck Info: [B]BAD_POOL_CALLER (c2)[/B]
BUGCHECK_STR:  0xc2_7_KSsp
PROCESS_NAME: [B]dvbviewer.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0xc2_7_KSsp_ks!CKsQueue::FreeStreamPointer+6b[/B]
CPUID:        "Intel(R) Core(TM) i7 CPU         930  @ 2.80GHz"
MaxSpeed:     2800
CurrentSpeed:[B]2806[/B]
  BIOS Version                  0701
  BIOS Release Date             05/10/2011
[/font]
3rd Party Drivers:
The following is for information purposes only. Any drivers in red should be updated.
[COLOR=RED][B]88XBDAIR.sys                Thu Jan 18 04:38:56 2007 (45AF4030)[/B][/COLOR]
[COLOR=RED][B]88xBDACap.sys               Thu Jan 18 04:41:54 2007 (45AF40E2)[/B][/COLOR]
[COLOR=RED][B]88XAxbar.sys                Thu Jan 18 04:50:46 2007 (45AF42F6)[/B][/COLOR]
[COLOR=RED][B]88xAStream.sys              Thu Jan 18 04:57:25 2007 (45AF4485)[/B][/COLOR]
[COLOR=RED][B]88xBDATune.sys              Mon Apr 28 02:06:39 2008 (4815696F)[/B][/COLOR]
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
ASACPI.sys                  Wed Jul 15 23:31:29 2009 (4A5E9F11)
a2util64.sys                Fri Oct 16 06:26:21 2009 (4AD84A4D)
mvxxmm.sys                  Fri Dec 25 01:45:15 2009 (4B345F7B)
mv91xx.sys                  Fri Dec 25 01:45:39 2009 (4B345F93)
nusb3hub.sys                Thu Jan 21 22:22:18 2010 (4B5919EA)
nusb3xhc.sys                Thu Jan 21 22:22:21 2010 (4B5919ED)
ISODrv64.sys                Thu Jan 28 22:39:02 2010 (4B625856)
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
a2ddax64.sys                Thu May 19 08:09:43 2011 (4DD50887)
RTCore64.sys                Tue Sep  6 08:24:50 2011 (4E661112)
a2dix64.sys                 Mon Apr 30 12:43:27 2012 (4F9EC12F)
a2accx64.sys                Mon Apr 30 12:44:30 2012 (4F9EC16E)
nvlddmkm.sys                Tue May 15 03:35:36 2012 (4FB20748)
RTKVHD64.sys                Tue Jun 19 04:50:56 2012 (4FE03D70)
idmwfp.sys                  Wed Aug  1 10:23:05 2012 (50193BC9)
[/font]
Link Removed - Invalid URL
BSOD's problem ... Don't come unless you use satellite only.
And this compression on the device in every way the latest games and the latest ... Wemavish any problems arise.
Problem only when using satellite rise ...
Generally you have deleted immediately when you see the MSI program BOSD ....
And I would try if my problem again ...
Mesh display problem anywhere in the device only during my use of satellites ...
Thank you for your continued persistent and good ...
I do not understand your reply.
I say - un-install Satellite program
If no BSOD, then you cannot use Satellite program.
Problem BOSD .. Show only ..When I use ..Satellite TV ..Does not appear in any place or use another ..
After screening for MSI and not my use of comodo, I think the problem did not come again ...
Thanks ...
I do not fully understand.
I assume that you are saying that the problem is fixed?
The problem is not resolved and I have a screen appeared BOSD again ..
If the problem again in the Satellite Card ...
Buy another card ..What do you think about types tevii ..
Tevii
I'll buy one of them:
TeVii S464 DVB-S2 PCI
OR
TeVii S471 DVB-S2 PCIe
Are there any problems in the cards TeVii?Screen BOSD?Or older devices?
I am a bit reluctant to get involved in this thread as there seems to be some inherent issues with a language barrier which is often the case.
So I will make this as clear as possible
usama has patiently addressed your issue, he has identified the likely cause of your issue DTV-DVB 1027 AVStream TS Driver.
The physical device, the associated software and drivers
[TABLE="width: 206"]
[TR]
[TD]88xAStream.sys[/TD]
[TD="align: right"]1/18/2007[/TD]
[/TR]
[TR]
[TD]88XAxbar.sys[/TD]
[/TR]
[TR]
[TD]88xBDACap.sys[/TD]
[/TR]
[TR]
[TD]88XBDAIR.sys[/TD]
[/TR]
[TR]
[TD]88xBDATune.sys[/TD]
[TD="align: right"]4/28/2008[/TD]
[/TR]
[/TABLE]
So please physically remove the device from your system. Completely uninstall any and all associated software and then double check your computer by performing a search for the above drivers and confirm that they are not longer present on your computer.
If the Blue Screens then cease I would expect that you will have confirmed that usama was in fact correct in his analysis and your solution is at hand.
In respect to replacing the problem device with an alternative, your job is to do the research on the product you are considering and confirm through whatever means possible that the new card is 100% Windows 7 compatible and will not likely cause similar issues. Communicate with the vendor / manufacturer, confirm that the drivers and software support Windows 7, check Google for potential resources of customer feedback regarding the device(s).
So simply...
1.) Remove the problem device that has been identified
2.) Remove any associated software
3.) Confirm that the previously identified drivers are no longer present on your system (if they are rename the file extension from .sys to .OLD and break them)
4.) Confirm that your machine is now stable and BSOD free.
If Blue screens then persist, please attach any newer dump files that reflect the above steps have been addressed and completed.
Regards
Randy
