Windows 7 I have a problem when I used Virtual PC to open a VHD file
Starr
Hi every guys,
I have installed a new computer with WIN7, and I wanted to restore the old computer's hard disk to the new one. Because the new computer dosen't has IDE port, so I couldn't installed the old hard disk(it has IDE port) to it. The following steps were what I had done, but it didn't work.
1. I have created a VHD file by Winimage software on the old one and copied it to new one.
2. I intalled Windows Virtual PC and XP module;
3. when I created a vitual machine on the VHD file that I copied from the old computer, it showed me there wasn't boot file;
4. Also, I have succeded to creat a winxp virtual machine on the new VHD file (it is created by the system), and I added the Virtual disk to it with the old VHD file, but I cann't open it in the Vitrual XP system.
So, is there anyone know what is wrong with my work, or how to finish it. Thanks.
Starr;
Don't know how or what you used to create the Virtual Hard Disk, but perhaps take a look at this article, I've used it before, and it worked for me. Make sure you follow the steps. Hope this helps
Is there any solution to fix it or achieve the goal as using the old hard disk on windows 7?
I think, before throwing in the towel, you might want to look at something like Virutal Box which also supports the .VHD format and see if it works any better although I haven't used it, so I wouldn't be of much help. I also don't understand why you couldn't install Virtual PC 2007 and run the microsoft updates twice, could it be that your current hardware is stopping you from using a software virtualization environment. Like I said earlier, I'm running it fine on Windows 7 Ultimate 64bit, with a dual core processor and 4 gigs of ram, but again I don't have the option to use hardware virtualization.
