Hi Everyone,
I am trying to install the ODBC
drivers for v9.1 on a new Windows 7, 64bit, IBM Levono laptop for a client. I have been
able to do the install and make the connection on other Windows 7 machines with
no problems. This new laptop is a problem! I can launch the install software and
select install new instance. When the procedure starts, the Windows Installer
screen appears and the procedure hangs. I worked for several hours with the firm
who's database we are trying to access. They finally gave up. Almost to the
point of setting the machine back to factory specs and start all over. What am I
missing? (As you probably can guess, I'm new to the db2 arena...)
Thanks
for the help!
Thanks
for the help!
