- Thread Author
- #1
I can't connect to the internet.
In device manager there is a exclamation on intel gigabit network connection & Under device status it says windows cannot initialize the device driver for this hardware (code 37).
I tried disable device, Uninstall then restart pc, the sfc scannow and changing ethernet cable. It's not the cable cause I can connect my laptop and the internet works. Command prompt found a corrupt file but couldn't fix it.
How can I fix the intel 1211 gigabit network connection?
