IOI 007 First Light PC Specs: 32 GB RAM for 1080p 60
IO Interactive’s first PC hardware breakdown for 007 First Light makes one thing immediately clear: you can get into the game at a modest 1080p/30 target, but to hit the studio’s recommended 1080p/60 target you’ll need a surprisingly large system memory pool — IOI lists 32 GB of system RAM in the recommended column, a specification that will reshape upgrade priorities for many PC owners.
Blue-lit PC setup with a glowing monitor displaying '101 007 FIRST LIGHT'.Background / Overview​
IO Interactive’s James Bond origin story, 007 First Light, is positioned as the studio’s most ambitious single‑player project to date: a cinematic, third‑person action‑adventure that blends stealth, driving, gadgets, and scripted spectacle. The title runs on IOI’s proprietary Glacier engine and will launch on PC alongside PlayStation 5, Xbox Series X/S, and Nintendo Switch 2. IO Interactive delayed the release from late March to May 27, 2026, citing additional time for polish; the Steam storefront lists the May 27 release and pre‑purchase options. This hardware reveal is a developer’s first formal, consolidated set of PC tiers and focuses on two primary performance targets: Minimum (1080p / 30 FPS) and Recommended (1080p / 60 FPS). Multiple outlets reproduced IOI’s published table verbatim, and IO Interactive’s own announcement reiterates the same CPU, GPU, RAM, VRAM, and storage callouts.
Official PC specifications — distilled​
Below is a concise, verified distillation of IO Interactive’s published PC tiers. These are the numbers the studio published in its PC announcement and which storefronts and outlets have reproduced. Treat them as the developer’s guidance at the time of the reveal; final launch day patches or driver updates can still alter recommended drivers or install size.
Minimum (Performance Target: 1080p @ 30 FPS)​
  • Processor: Intel Core i5‑9500K or AMD Ryzen 5 3500.
  • Graphics card: NVIDIA GTX 1660, AMD RX 5700, or equivalent Intel discrete GPU (approx. 8 GB VRAM class).
  • System RAM: 16 GB.
  • Video RAM (VRAM): 8 GB.
  • Storage: ~80 GB minimum (SSD strongly recommended).
  • OS: Microsoft Windows 10 / 11 (64‑bit).
Recommended (Performance Target: 1080p @ 60 FPS)​
  • Processor: Intel Core i5‑13500 or AMD Ryzen 5 7600.
  • Graphics card: NVIDIA RTX 3060 Ti, AMD RX 6700 XT, or equivalent Intel discrete GPU.
  • System RAM: 32 GB (this is the standout, unusual call).
  • Video RAM (VRAM): 12 GB.
These tables are reproduced across the developer update and the Steam product fields; independent reporting confirms the numbers shown above. The notable, load‑bearing claim is the 32 GB recommended system memory for a 1080p/60 target — an unusual recommendation for a game that foregrounds midrange GPUs in its recommended column.
What the 32 GB RAM recommendation actually means​
Why IOI might require 32 GB for the recommended tier​
There are several technical reasons a developer would set a high system RAM target even while listing midrange GPU models for a 1080p/60 target:
  • Modern engines stream large texture pools, physics states, and world data into RAM as well as VRAM; if the CPU or memory bandwidth is the bottleneck, extra system RAM can reduce hitching and improve frame‑time stability in complex scenes.
  • IOI’s Glacier engine could be buffering numerous high‑resolution assets and simulation data concurrently, especially with large set pieces, active NPCs, and persistent world elements.
  • The studio may be targeting a comfortable 60 FPS experience that includes background tasks (streaming capture, voice chat, overlays) which inflate working memory demands in real play.
Practical implications for PC builders and buyers​
  • Users on 16 GB can still run the game at the minimum 1080p/30 target, but they should expect lowered presets and reduced view distances in demanding areas.
  • If you plan to play at the developer’s recommended target (1080p/60) while multitasking, streaming, or using capture software, 32 GB is now the more future‑proof choice. This is particularly relevant for creators who record or stream gameplay.
  • Memory upgrades are often the most cost‑effective strategy to gain stability. For older desktops with free DIMM slots, adding a matched stick to enable dual‑channel operation and reach 32 GB may be cheaper than a new GPU.
Flag: While IOI’s published table lists 12 GB VRAM for the recommended tier, some of the GPUs shown (for example, the NVIDIA RTX 3060 Ti) commonly ship with 8 GB of VRAM depending on the SKU. That juxtaposition suggests IOI is signaling both GPU class and an ideal VRAM pool separately — buyers should confirm both the GPU model and its VRAM capacity when planning purchases.
GPU, VRAM and the performance envelope: mismatches to watch for​
The recommended GPU pairings (RTX 3060 Ti / RX 6700 XT) are sensible midrange choices for 1080p/60 play, but the 12 GB VRAM callout raises immediate questions.
  • Many RTX 3060 Ti cards have 8 GB of VRAM, while some RX 6700 XT SKUs ship with 12 GB. That means a CPU/GPU pairing might meet the compute profile but still fall short of IOI’s ideal VRAM budget for higher texture pools. Verify VRAM alongside model numbers.
  • If you own an RTX 3060 Ti with 8 GB VRAM and you plan to run high texture presets or large view distances, you may need to lower texture detail or leverage vendor upscaling to avoid VRAM thrashing.
Vendor upscalers (DLSS, FSR, XeSS) can dramatically reduce native resolution load and VRAM pressure while preserving perceived fidelity — but they are not a replacement for adequate VRAM when the engine demands high texture residency. Treat upscalers as a performance lever, not a cure‑all.
NVIDIA collaboration and DLSS 4: what IOI is promising​
IO Interactive has confirmed a collaboration with NVIDIA to integrate DLSS, specifically the DLSS generation and multi‑frame features that multiply frame throughput on RTX hardware. NVIDIA’s announcements highlight DLSS 4 support for 007 First Light and the use of frame generation features to elevate framerates without purely relying on raw GPU compute. This integration helps explain how IOI expects midrange GPUs to deliver higher‑frame experiences when paired with advanced upscaling and frame generation. Key takeaways:
  • DLSS support should give NVIDIA RTX owners a tangible performance boost and a path to higher refresh‑rate play with less hardware churn.
  • DLSS frame generation technologies introduce tradeoffs in latency and visual artifacts; players sensitive to input lag should test the feature when it becomes available.
Caveat: DLSS benefits are specific to NVIDIA RTX users and depend on driver maturity at launch. AMD and Intel upscalers will remain important for non‑NVIDIA rigs; IOI’s announced tiers do not lock performance expectations to NVIDIA alone.
Storage and install size — plan for breathing room​
IO Interactive lists ~80 GB as the headline install size for 007 First Light. However, modern releases frequently expand their on‑disk footprint with preloads, day‑one patches, and optional content. Plan for extra headroom:
  • Recommended free space during preload and patch windows: 120–160 GB.
  • Use an SSD (NVMe preferred) to minimize streaming hitching and load‑time penalties; SSDs improve texture streaming and reduce stutter on asset heavy scenes.
If your system drive is near capacity, move or add space before preloading to avoid installer failures and long composition times.
Preparing your PC: prioritized upgrade checklist​
If you want to be launch‑ready for 007 First Light at the recommended 1080p/60 target, here’s a pragmatic ordering of upgrade priorities based on IOI’s published guidance.
  • Storage: Move the game to an SSD (NVMe preferred) and reserve 120+ GB free to handle preloads and patches.
  • System RAM: If you currently have 16 GB and you multitask, upgrade to 32 GB — this is the single most consequential change IOI’s guidance suggests.
  • GPU: For native 1080p/60 on higher presets, target the RTX 3060 Ti / RX 6700 XT class or better; consider higher‑VRAM SKUs if you run max textures.
  • CPU: The recommended CPUs (i5‑13500 / Ryzen 5 7600) are midrange modern chips; upgrade your CPU if your current processor is several generations old.
  • Drivers & OS: Keep Windows and GPU drivers updated to the versions IOI and vendors recommend at launch. IOI lists Windows 10/11 as supported, leaving a broad install base, but OS updates and driver recommendations can materially affect stability.
What to expect at non‑1080p targets (1440p / 4K / high refresh)​
At present IO Interactive’s published hardware tiers cover only 1080p at 30 and 60 FPS. The studio has not released official 1440p or 4K target tables, nor any higher‑FPS presets like 120 Hz+ for PC. Until IOI publishes those tiers and launch benchmarks, the practical path for higher resolutions is:
  • Use vendor upscalers and frame generation to reach higher refresh rates on weaker hardware, or
  • Step up to higher GPU classes (for example, RTX 4070/4080 or RX 7900 series) for native 1440p/4K play with high presets.
Flag: The lack of native 1440p/4K guidance at reveal is normal but worth noting — wait for IOI’s launch benchmarks and third‑party testing before making large GPU purchases specifically for higher resolutions.
Risks, caveats and what to watch before buying or upgrading​
  • VRAM vs GPU model mismatch: The recommended 12 GB VRAM figure does not map cleanly to every recommended GPU model. Verify VRAM capacity on any GPU SKU you plan to buy.
  • Storage growth: Headline install sizes are often conservative. Expect day‑one patches and plan for extra disk space.
  • Anti‑cheat or firmware checks: IOI currently lists Windows 10/11 support only; it has not announced any Windows‑only OS lock or TPM / Secure Boot mandates at the time of the spec release. Still, publishers sometimes add anti‑cheat firmware checks near launch — monitor IOI’s support notes closely.
  • Driver maturity: DLSS frame generation and other advanced features depend heavily on vendor driver updates. Expect iterative driver updates around launch.
Launch weekend checklist (concise)​
  • Update Windows and GPU drivers to IOI and vendor‑recommended versions.
  • Free 120–160 GB on your SSD for preload and patches.
  • If you want a smooth 1080p/60 experience while multitasking, move to 32 GB of RAM.
  • Test vendor upscaler and frame generation settings to balance latency vs. framerate.
Final analysis: strengths and risks​
Strengths​
  • IO Interactive’s tiered table is clear and pragmatic: a reasonable minimum target ensures broad accessibility while the recommended target sets a high bar for stability. The explicit callout of VRAM, CPU class, and storage gives players concrete upgrade signals.
  • The NVIDIA collaboration and DLSS frame generation support provide a tangible path for RTX owners to multiply framerates without a linear hardware upgrade. This can meaningfully extend the life of midrange cards for higher refresh‑rate play.
Risks and open questions​
  • The 32 GB recommended RAM is the single most disruptive specification for many players. It will nudge budget‑conscious PC owners toward memory upgrades and could create confusion for those who read GPU model lists but ignore the RAM callout.
  • The juxtaposition of GPU models and VRAM targets (e.g., 12 GB VRAM vs. RTX 3060 Ti SKUs often shipping with 8 GB) is a potential source of buyer confusion. Buyers must check exact SKU VRAM numbers rather than assuming a model’s memory budget.
  • No official 1440p/4K or multi‑FPS tiers yet: purchasers chasing higher resolutions should wait for IOI’s additional guidance and third‑party benchmarks before making high‑end GPU purchases.
IO Interactive’s PC system requirements for 007 First Light are straightforward and, in several ways, conservative: the minimum column keeps the game accessible to midrange rigs, and IOI still lists mainstream GPUs in the recommended column. The standout call — 32 GB system RAM for a recommended 1080p/60 experience — is an unusual but defensible move that signals a focus on stable frame‑times, large asset streaming, and creator workflows. Players with 16 GB rigs can still play at the minimum target, but anyone aiming to match IOI’s recommended experience — particularly streamers and multitaskers — should budget for a memory upgrade and confirm GPU VRAM capacity before purchase.
Watch IO Interactive’s support channels and the Steam/Epic storefront for any last‑minute adjustments (driver recommendations, expanded resolution tiers, or updates to install size) as launch approaches on May 27, 2026. Plan upgrades in order of impact — SSD, RAM, GPU, CPU — and test vendor upscalers and frame generation at launch to squeeze the best possible performance from your system.
Source: Game Informer 007 First Light PC Specs And System Requirements Revealed By IO Interactive
Support hub
