Windows 7 IRQL NOT LESS OR EQUAL!
Your latest crash dumps look like this:
Caused by DirectX driver dxgkrnl.sys
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
PROCESS_NAME:  csrss.exe
DEFAULT_BUCKET_ID:  NULL_CLASS_PTR_DEREFERENCE
Stack text: nt dxgmms1 dxgkrnl
NVIDIA drivers look good now:
nvlddmkm.sys Fri Jan 07 21:03:58 2011
nvmf6232.sys Thu Aug 12 07:45:46 2010
You mentioned overheating:
Ok BTW i got a problem with overheating CPU so i lowered voltage for 0.050 on BIOS but its 80% slower :S
Run it at stock frequency and voltage.
Stress test the card with Furmak, stop the test if the temperatures get near critical:
FurMark: VGA Stress Test, Graphics Card and GPU Stability Test, Burn-in Test, OpenGL Benchmark and GPU Temperature | oZone3D.Net
See if your system crashes during the test.
Stress test the CPU and memory with Prime95:
Prime95 - Overclock.net - Overclocking.net
And also, see if your system crashes during this test.
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\012711-16567-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x86 compatible
Built by: 7600.16617.x86fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0x82a1a000 PsLoadedModuleList = 0x82b62810
Debug session time: Thu Jan 27 05:02:03.694 2011 (UTC - 5:00)
System Uptime: 0 days 0:00:16.364
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Unable to load image \SystemRoot\System32\drivers\dxgkrnl.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for dxgkrnl.sys
*** ERROR: Module load completed but symbols could not be loaded for dxgkrnl.sys
BugCheck 1000007E, {c0000005, 820a134b, 8dddbf8c, 8dddbb70}
Probably caused by : dxgkrnl.sys ( dxgkrnl+2334b )
Followup: MachineOwner
0: kd> !analyze -v
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003.  This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG.  This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG.  This will let us see why this breakpoint is
happening.
Arguments:
Arg1: c0000005, The exception code that was not handled
Arg2: 820a134b, The address that the exception occurred at
Arg3: 8dddbf8c, Exception Record Address
Arg4: 8dddbb70, Context Record Address
Debugging Details:
FAULTING_IP:
dxgkrnl+2334b
820a134b 89480c          mov     dword ptr [eax+0Ch],ecx
EXCEPTION_RECORD:  8dddbf8c -- (.exr 0xffffffff8dddbf8c)
ExceptionAddress: 820a134b (dxgkrnl+0x0002334b)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 00000001
   Parameter[1]: 0000000c
Attempt to write to address 0000000c
CONTEXT:  8dddbb70 -- (.cxr 0xffffffff8dddbb70)
eax=00000000 ebx=8d8641b0 ecx=00000000 edx=00800001 esi=8dddc0a4 edi=82e2f6ee
eip=820a134b esp=8dddc054 ebp=8dddc070 iopl=0         nv up ei pl zr na pe nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00010246
dxgkrnl+0x2334b:
820a134b 89480c          mov     dword ptr [eax+0Ch],ecx ds:0023:0000000c=????????
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
CURRENT_IRQL:  0
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_PARAMETER1:  00000001
EXCEPTION_PARAMETER2:  0000000c
WRITE_ADDRESS: GetPointerFromAddress: unable to read from 82b82718
Unable to read MiSystemVaType memory at 82b62160
 0000000c
FOLLOWUP_IP:
dxgkrnl+2334b
BUGCHECK_STR:  0x7E
LAST_CONTROL_TRANSFER:  from 8207f097 to 820a134b
STACK_TEXT:
WARNING: Stack unwind information not available. Following frames may be wrong.
8dddc070 8207f097 00000000 8dddc08c 82136123 dxgkrnl+0x2334b
8dddc07c 82136123 86ae1000 8dddc0a4 8dddc178 dxgkrnl+0x1097
8dddc08c 82149f03 8dddc0a4 86af2958 86af2000 dxgmms1!DXGADAPTER::DdiPatch+0x11
8dddc178 8214eed0 86af2224 8dddc2ec 00000001 dxgmms1!VIDMM_GLOBAL::FlushPagingBufferInternal+0x201
8dddc1b0 82150874 00000000 8dddc2ec 86ad9438 dxgmms1!VIDMM_GLOBAL::EndPreparation+0xda
8dddc21c 82150eaa 60000481 8dddc2ec 8dddc318 dxgmms1!VIDMM_GLOBAL::ProcessDeferredCommand+0x7b6
8dddc234 8216636f 8dddc310 86ad9438 86ad9438 dxgmms1!VidMmiProcessSystemCommand+0x20
8dddc250 82167249 86abc200 86adc788 8dddc290 dxgmms1!VidSchiSubmitSystemCommand+0x33
8dddc260 821426dc 86ad9438 86ad9438 86adc2f0 dxgmms1!VidSchiSubmitQueueCommand+0x7b
8dddc290 8216741c 86ae4000 8dddc2b4 86adc2f0 dxgmms1!VidSchiSubmitQueueCommandDirect+0x1ae
8dddc2b8 82162775 01ad9438 86af2000 89b794f8 dxgmms1!VidSchiSubmitCommandPacketToQueue+0x180
8dddc2d0 82150f11 86adc788 82150e8a 8dddc310 dxgmms1!VidSchSubmitSystemCommand+0xab
8dddc2fc 82150f86 8dddc310 89b461e0 86b259e0 dxgmms1!VIDMM_GLOBAL::QueueSystemCommandAndWait+0x41
8dddc334 8215222e 8dddc35c 89b47828 89b47810 dxgmms1!VIDMM_GLOBAL::QueueDeferredCommandAndWait+0x3c
8dddc384 82152e99 89b79898 00b461e0 89b794f8 dxgmms1!VIDMM_GLOBAL::OpenOneAllocation+0x240
8dddc3b0 821362db 89b79898 00000000 00000020 dxgmms1!VIDMM_GLOBAL::OpenAllocation+0x9f
8dddc3d0 82080f80 86af2000 89b79898 898ee1f8 dxgmms1!VidMmOpenAllocation+0x1f
8dddc3f4 820a566a 85a32e50 86af2000 89b79898 dxgkrnl+0x2f80
8dddc440 820a452a 8dddc848 8dddc5f0 8dddc470 dxgkrnl+0x2766a
8dddc7dc 820a8377 8dddc848 00000000 00000000 dxgkrnl+0x2652a
8dddc89c 820e1d37 00000000 00000000 ffb89010 dxgkrnl+0x2a377
8dddca78 96f42611 40000000 00000000 8dddcd28 dxgkrnl+0x63d37
8dddcac0 96f45151 ffb89010 8dddccd0 8dddcd28 cdd!CreateAndEnableDevice+0x171
8dddcd50 82c286d3 ffb89010 a9cf8873 00000000 cdd!PresentWorkerThread+0x81d
8dddcd90 82ada0f9 96f44934 ffb89010 00000000 nt!PspSystemThreadStartup+0x9e
00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x19
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  dxgkrnl+2334b
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: dxgkrnl
IMAGE_NAME:  dxgkrnl.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4ac54de1
STACK_COMMAND:  .cxr 0xffffffff8dddbb70 ; kb
FAILURE_BUCKET_ID:  0x7E_dxgkrnl+2334b
Drivers:
start    end        module name
887b4000 887fc000   ACPI     ACPI.sys     Mon Jul 13 19:11:11 2009 (4A5BBF0F)
8d8c3000 8d91d000   afd      afd.sys      Mon Jul 13 19:12:34 2009 (4A5BBF62)
8217b000 8218d000   AgileVpn AgileVpn.sys Mon Jul 13 19:55:00 2009 (4A5BC954)
9072f000 90740000   amdppm   amdppm.sys   Mon Jul 13 19:11:03 2009 (4A5BBF07)
889ab000 889b4000   amdxata  amdxata.sys  Tue May 19 13:57:35 2009 (4A12F30F)
888dc000 888e5000   atapi    atapi.sys    Mon Jul 13 19:11:15 2009 (4A5BBF13)
888e5000 88908000   ataport  ataport.SYS  Mon Jul 13 19:11:18 2009 (4A5BBF16)
8d82f000 8d836000   Beep     Beep.SYS     Mon Jul 13 19:45:00 2009 (4A5BC6FC)
90700000 9070e000   blbdrive blbdrive.sys Mon Jul 13 19:23:04 2009 (4A5BC1D8)
88640000 88648000   BOOTVID  BOOTVID.dll  Mon Jul 13 21:04:34 2009 (4A5BD9A2)
96f40000 96f5e000   cdd      cdd.dll      Mon Jul 13 21:04:18 2009 (4A5BD992)
8d809000 8d828000   cdrom    cdrom.sys    Mon Jul 13 19:11:24 2009 (4A5BBF1C)
8868a000 88735000   CI       CI.dll       Mon Jul 13 21:09:28 2009 (4A5BDAC8)
88d84000 88da9000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:11:20 2009 (4A5BBF18)
88648000 8868a000   CLFS     CLFS.SYS     Mon Jul 13 19:11:10 2009 (4A5BBF0E)
88b7e000 88bdb000   cng      cng.sys      Mon Jul 13 19:32:55 2009 (4A5BC427)
8216e000 8217b000   CompositeBus CompositeBus.sys Mon Jul 13 19:45:26 2009 (4A5BC716)
82563000 82570000   crashdmp crashdmp.sys Mon Jul 13 19:45:50 2009 (4A5BC72E)
90684000 906e8000   csc      csc.sys      Mon Jul 13 19:15:08 2009 (4A5BBFFC)
906e8000 90700000   dfsc     dfsc.sys     Mon Jul 13 19:14:16 2009 (4A5BBFC8)
90678000 90684000   discache discache.sys Mon Jul 13 19:24:04 2009 (4A5BC214)
88d73000 88d84000   disk     disk.sys     Mon Jul 13 19:11:28 2009 (4A5BBF20)
8254a000 82563000   drmk     drmk.sys     Mon Jul 13 20:36:05 2009 (4A5BD2F5)
8d99d000 8d9d8000   dtsoftbus01 dtsoftbus01.sys Wed Dec 22 05:19:35 2010 (4D11D0B7)
82570000 8257a000   dump_diskdump dump_diskdump.sys Mon Jul 12 23:24:27 2010 (4C3BDC6B)
825b1000 825c2000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:12:47 2009 (4A5BBF6F)
8257a000 825b1000   dump_nvstor32 dump_nvstor32.sys Tue Aug 04 20:27:05 2009 (4A78D1D9)
825c2000 825cc000   Dxapi    Dxapi.sys    Mon Jul 13 19:25:25 2009 (4A5BC265)
8207e000 82135000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 20:48:33 2009 (4AC54DE1)
82135000 8216e000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:25:25 2009 (4A5BC265)
90740000 9074b000   fdc      fdc.sys      Mon Jul 13 19:45:45 2009 (4A5BC729)
889e8000 889f9000   fileinfo fileinfo.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
8246c000 82476000   flpydisk flpydisk.sys Mon Jul 13 19:45:45 2009 (4A5BC729)
889b4000 889e8000   fltmgr   fltmgr.sys   Mon Jul 13 19:11:13 2009 (4A5BBF11)
88be9000 88bf2000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:11:14 2009 (4A5BBF12)
88d41000 88d73000   fvevol   fvevol.sys   Fri Sep 25 22:24:21 2009 (4ABD7B55)
88f52000 88f83000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:12:03 2009 (4A5BBF43)
82e2a000 82e61000   hal      halmacpi.dll Mon Jul 13 19:11:03 2009 (4A5BBF07)
82017000 82036000   HDAudBus HDAudBus.sys Mon Jul 13 19:50:55 2009 (4A5BC85F)
824cb000 8251b000   HdAudio  HdAudio.sys  Mon Jul 13 19:51:46 2009 (4A5BC892)
88e00000 88e08000   hwpolicy hwpolicy.sys Mon Jul 13 19:11:01 2009 (4A5BBF05)
9076d000 90785000   i8042prt i8042prt.sys Mon Jul 13 19:11:23 2009 (4A5BBF1B)
90792000 9079f000   kbdclass kbdclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
80ba2000 80baa000   kdcom    kdcom.dll    Mon Jul 13 21:08:58 2009 (4A5BDAAA)
8242a000 8245e000   ks       ks.sys       Wed Mar 03 22:57:52 2010 (4B8F2FC0)
88b6b000 88b7e000   ksecdd   ksecdd.sys   Mon Jul 13 19:11:56 2009 (4A5BBF3C)
88d0c000 88d31000   ksecpkg  ksecpkg.sys  Thu Dec 10 23:04:22 2009 (4B21C4C6)
88624000 8862f000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 19:13:13 2009 (4A5BBF89)
825d9000 825e4000   monitor  monitor.sys  Mon Jul 13 19:25:58 2009 (4A5BC286)
90785000 90792000   mouclass mouclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
888c6000 888dc000   mountmgr mountmgr.sys Mon Jul 13 19:11:27 2009 (4A5BBF1F)
8d888000 8d893000   Msfs     Msfs.SYS     Mon Jul 13 19:11:26 2009 (4A5BBF1E)
88609000 88611000   msisadrv msisadrv.sys Mon Jul 13 19:11:09 2009 (4A5BBF0D)
88b40000 88b6b000   msrpc    msrpc.sys    Mon Jul 13 19:11:59 2009 (4A5BBF3F)
9066e000 90678000   mssmbios mssmbios.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
88d31000 88d41000   mup      mup.sys      Mon Jul 13 19:14:14 2009 (4A5BBFC6)
88c17000 88cce000   ndis     ndis.sys     Mon Jul 13 19:12:24 2009 (4A5BBF58)
821a5000 821b0000   ndistapi ndistapi.sys Mon Jul 13 19:54:24 2009 (4A5BC930)
821b0000 821d2000   ndiswan  ndiswan.sys  Mon Jul 13 19:54:34 2009 (4A5BC93A)
824ba000 824cb000   NDProxy  NDProxy.SYS  Mon Jul 13 19:54:27 2009 (4A5BC933)
8d975000 8d983000   netbios  netbios.sys  Mon Jul 13 19:53:54 2009 (4A5BC912)
8d91d000 8d94f000   netbt    netbt.sys    Mon Jul 13 19:12:18 2009 (4A5BBF52)
88cce000 88d0c000   NETIO    NETIO.SYS    Mon Jul 13 19:12:35 2009 (4A5BBF63)
8d893000 8d8a1000   Npfs     Npfs.SYS     Mon Jul 13 19:11:31 2009 (4A5BBF23)
90664000 9066e000   nsiproxy nsiproxy.sys Mon Jul 13 19:12:08 2009 (4A5BBF48)
82a1a000 82e2a000   nt       ntkrpamp.exe Fri Jun 18 23:55:24 2010 (4C1C3FAC)
88a11000 88b40000   Ntfs     Ntfs.sys     Mon Jul 13 19:12:05 2009 (4A5BBF45)
8d828000 8d82f000   Null     Null.SYS     Mon Jul 13 19:11:12 2009 (4A5BBF10)
95e00000 95e01040   nvBridge nvBridge.kmd Fri Jan 07 20:57:19 2011 (4D27C47F)
95e05000 967feee0   nvlddmkm nvlddmkm.sys Fri Jan 07 21:03:58 2011 (4D27C60E)
82036000 8207d280   nvmf6232 nvmf6232.sys Thu Aug 12 07:45:46 2010 (4C63DEEA)
88908000 8892d000   nvstor   nvstor.sys   Wed May 20 02:44:09 2009 (4A13A6B9)
88974000 889ab000   nvstor32 nvstor32.sys Tue Aug 04 20:27:05 2009 (4A78D1D9)
8d956000 8d975000   pacer    pacer.sys    Mon Jul 13 19:53:58 2009 (4A5BC916)
90755000 9076d000   parport  parport.sys  Mon Jul 13 19:45:34 2009 (4A5BC71E)
88845000 88856000   partmgr  partmgr.sys  Mon Jul 13 19:11:35 2009 (4A5BBF27)
88810000 8883a000   pci      pci.sys      Mon Jul 13 19:11:16 2009 (4A5BBF14)
888b1000 888b8000   pciide   pciide.sys   Mon Jul 13 19:11:19 2009 (4A5BBF17)
888b8000 888c6000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:11:15 2009 (4A5BBF13)
88bdb000 88be9000   pcw      pcw.sys      Mon Jul 13 19:11:10 2009 (4A5BBF0E)
8251b000 8254a000   portcls  portcls.sys  Mon Jul 13 19:51:00 2009 (4A5BC864)
8862f000 88640000   PSHED    PSHED.dll    Mon Jul 13 21:09:36 2009 (4A5BDAD0)
8218d000 821a5000   rasl2tp  rasl2tp.sys  Mon Jul 13 19:54:33 2009 (4A5BC939)
821d2000 821ea000   raspppoe raspppoe.sys Mon Jul 13 19:54:53 2009 (4A5BC94D)
82000000 82017000   raspptp  raspptp.sys  Mon Jul 13 19:54:47 2009 (4A5BC947)
82407000 8241e000   rassstp  rassstp.sys  Mon Jul 13 19:54:57 2009 (4A5BC951)
90623000 90664000   rdbss    rdbss.sys    Mon Jul 13 19:14:26 2009 (4A5BBFD2)
8241e000 82428000   rdpbus   rdpbus.sys   Mon Jul 13 20:02:40 2009 (4A5BCB20)
8d870000 8d878000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:01:40 2009 (4A5BCAE4)
8d878000 8d880000   rdpencdd rdpencdd.sys Mon Jul 13 20:01:39 2009 (4A5BCAE3)
8d880000 8d888000   rdprefmp rdprefmp.sys Mon Jul 13 20:01:41 2009 (4A5BCAE5)
88fd3000 89000000   rdyboost rdyboost.sys Mon Jul 13 19:22:02 2009 (4A5BC19A)
9074b000 90755000   serenum  serenum.sys  Mon Jul 13 19:45:27 2009 (4A5BC717)
8d983000 8d99d000   serial   serial.sys   Mon Jul 13 19:45:33 2009 (4A5BC71D)
88fcb000 88fd3000   spldr    spldr.sys    Mon May 11 12:13:47 2009 (4A084EBB)
8892d000 88974000   storport storport.sys Mon Jul 13 19:45:58 2009 (4A5BC736)
82428000 82429380   swenum   swenum.sys   Mon Jul 13 19:45:08 2009 (4A5BC704)
88e09000 88f52000   tcpip    tcpip.sys    Sun Jun 13 23:36:59 2010 (4C15A3DB)
8d8b8000 8d8c3000   TDI      TDI.SYS      Mon Jul 13 19:12:12 2009 (4A5BBF4C)
8d8a1000 8d8b8000   tdx      tdx.sys      Mon Jul 13 19:12:10 2009 (4A5BBF4A)
8d9eb000 8d9fb000   termdd   termdd.sys   Mon Jul 13 20:01:35 2009 (4A5BCADF)
96f10000 96f19000   TSDDD    TSDDD.dll    unavailable (00000000)
9070e000 9072f000   tunnel   tunnel.sys   Mon Jul 13 19:54:03 2009 (4A5BC91B)
8245e000 8246c000   umbus    umbus.sys    Mon Jul 13 19:51:38 2009 (4A5BC88A)
825d7000 825d8700   USBD     USBD.SYS     Mon Jul 13 19:51:05 2009 (4A5BC869)
90600000 9060f000   usbehci  usbehci.sys  Fri Oct 23 23:58:55 2009 (4AE27B7F)
82476000 824ba000   usbhub   usbhub.sys   Sat Oct 24 00:00:05 2009 (4AE27BC5)
9079f000 907a9000   usbohci  usbohci.sys  Mon Jul 13 19:51:14 2009 (4A5BC872)
907a9000 907f4000   USBPORT  USBPORT.SYS  Mon Jul 13 19:51:13 2009 (4A5BC871)
825cc000 825d7000   usbprint usbprint.sys Mon Jul 13 20:17:06 2009 (4A5BCE82)
8883a000 88845000   vdrvroot vdrvroot.sys Mon Jul 13 19:46:19 2009 (4A5BC74B)
8d836000 8d842000   vga      vga.sys      Mon Jul 13 19:25:50 2009 (4A5BC27E)
8d842000 8d863000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:25:49 2009 (4A5BC27D)
88f83000 88f8b380   vmstorfl vmstorfl.sys Mon Jul 13 19:28:44 2009 (4A5BC32C)
88856000 88866000   volmgr   volmgr.sys   Mon Jul 13 19:11:25 2009 (4A5BBF1D)
88866000 888b1000   volmgrx  volmgrx.sys  Mon Jul 13 19:11:41 2009 (4A5BBF2D)
88f8c000 88fcb000   volsnap  volsnap.sys  Mon Jul 13 19:11:34 2009 (4A5BBF26)
8d9d8000 8d9eb000   wanarp   wanarp.sys   Mon Jul 13 19:55:02 2009 (4A5BC956)
8d863000 8d870000   watchdog watchdog.sys Mon Jul 13 19:24:10 2009 (4A5BC21A)
88735000 887a6000   Wdf01000 Wdf01000.sys Mon Jul 13 19:11:36 2009 (4A5BBF28)
887a6000 887b4000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:11:25 2009 (4A5BBF1D)
8d94f000 8d956000   wfplwf   wfplwf.sys   Mon Jul 13 19:53:51 2009 (4A5BC90F)
96cb0000 96efb000   win32k   win32k.sys   Tue Oct 19 23:00:01 2010 (4CBE5B31)
88600000 88609000   WMILIB   WMILIB.SYS   Mon Jul 13 19:11:22 2009 (4A5BBF1A)
Unloaded modules:
88da9000 88db6000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000D000
88db6000 88dc0000   dump_storpor
    Checksum:  00000000
    ImageSize:  0000A000
88dc0000 88df7000   dump_nvstor3
    Checksum:  00000000
    ImageSize:  00037000
88c00000 88c11000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00011000
I get now new errors with Directx every time i start PC for 5 times lol its updated and still i got errors WTF !!!!!!!!!!!!!!!!!!!!!!!
Should i reinstall my windows / do something else ?
here dumps
BTW i runned stress tests and my cpu got to 82 C so i stopped it :S it simply passed every 30 secs for 1 degree C
  • Seven Forums.rar
82 degrees - that's overheating for sure. With Prime95 you should be going near 70 but not 82.
Did Furmark pass without errors too?
Load setup defaults in the bios. Do not OC anything, and provide proper cooling.
Top Bottom
