- Thread Author
- #1
Hi all,
for days i could not get the microphone on my headset running, i finally took some time aside to today to get it right, with strange results.
first of no program did recognize my headsets microphone. from the w7 sound options to skype .
w7 only listed sound-blaster devices, no matter what i connected.
strangely i do hear myself in the microphone and not just faintly.
in the end i disabled all devices, then enabled all device one after the other, to see, which one might be what. in the end it did not matter, because the microphone started working and had been recognized by w7 >>> by all devices ?!
but the microphone is always on and there is no mute option, it does not even appear in the "volume mixer". why is that anyway?
and >>> the microphone is always on, i disabled all devices, even the playback devices... i can still hear everything and it is still recording everything... and yes, none of the devices is set to "listen to this device", if i do that, i get a triple echo, pitching up to a high feedback scream.
w7 looks so versatile and flashy, but leaves you almost no choices or options, there is not even a option for "install (unknown) device", it just offers you something out of a list, if its not in there, well, screw you, buy something new, that we want you to buy.
my question is now (to anyone, who is still reading this and listening to my complaints), who do i get the control panel sound (options) to run correctly, how can i get my microphone running as it should be and how can i enable it, without hearing myself talking?
something that has been easy since dr-dos or ms-dos, ye know, green plug in green socket, red plug in red socket and there ye go. ;-)
thanks
thanks
