- Thread Author
- #1
At EVERY start up on my Dell Inspiron 1545 that came preloaded w/ Windows 7 Home Premium I get the following error message. If I hit "continue" on the warning box everything seems to work just fine. But I'd like to fix the problem, but don't really understand the JIT fix at the bottom and how exactly to implement it.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Cannot anchor balloon at position '{X=1203,Y=768}.' The point is not contained within the visible bounds of any screen.
Parameter name: point
Actual value was {X=1203,Y=768}.
at Rilling.Common.UI.Forms.BalloonWindow.MoveAnchorTo(Point point, Point pivot)
at Rilling.Common.UI.Forms.BalloonWindow.MoveAnchorTo(Point point)
at Rilling.Common.UI.Forms.BalloonWindow.Show(Point pt)
at Swapdrive.Client.Screens.FormMain.ShowCustomBalloon(CustomBalloonType balloonType)
at Swapdrive.Client.Screens.FormMain.OnTimer(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
DataSafeOnline
Assembly Version: 1.1.0.8998
Win32 Version: 1.1.0.8998
CodeBase: file:///C:/Program%20Files%20(x86)/Dell%20DataSafe%20Online/DataSafeOnline.exe
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
SdbShared
CodeBase: file:///C:/Program%20Files%20(x86)/Dell%20DataSafe%20Online/SdbShared.DLL
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
BalloonWindow
Assembly Version: 1.2.0.0
Win32 Version: 1.2.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Dell%20DataSafe%20Online/BalloonWindow.DLL
SdbUI
CodeBase: file:///C:/Program%20Files%20(x86)/Dell%20DataSafe%20Online/SdbUI.DLL
System.Web.Services
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
SdbShared.XmlSerializers
CodeBase: file:///C:/Program%20Files%20(x86)/Dell%20DataSafe%20Online/SdbShared.XmlSerializers.DLL
lllf1dsu
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
