Windows 7 linksys wusb54g wireless usb network adap not working
Amateen
hey guys, just joined couple of minutes ago, how you all doing? i got this problem. i installed windows 7 rc 1 everything went perfect but when i went to the internet it doesn't work. the software does installs correctly but when i unplug and plug the network adapter it says that the driver was not found. i tried going through the control panel and fixing but it still doesn't do anything. i did change the ports as well but nothing happening what shall i do. the network adapter works perfect with vista. if you need to know i am currently using Windows Vista Ultimate since i uninstalled the windows 7. my processor is AMD Athalon 64 x2 Dual Core Processor 4800+ 2.51GHz memory is 4.00Gb and it is 32-bit operating system. Thanks a lot
