Linux Kernel fix: AMDGPU userq fence deadlocks solved with irqsave
A subtle but important fix landed in the Linux kernel addressing a lock-warning and potential deadlock in the AMDGPU user-queue fence driver: the amdgpu_userq_fence_driver_process path could acquire a spinlock inconsistently across interrupt and process contexts, triggering kernel lockdep warnings and creating the conditions for hard-to-trace stalls. The problem is fixed by switching from plain spinlock usage to interrupt-safe locking with spin_lock_irqsave/spin_unlock_irqrestore, and the change has been recorded in the CVE registry as CVE-2025-68203.
A stylized Linux kernel illustration with interrupts, spin_lock_irqsave, and an AMDGPU chip.Background​
What part of the stack is affected​
The bug lives in the AMDGPU DRM driver, specifically the userq fence driver code that manages GPU fence objects for user queues. Fence drivers coordinate CPU/GPU synchronization; the userq (user queue) fence driver is involved in notifying completion events and cleaning up fences when GPU work finishes. Because fence processing occurs in multiple contexts — both in interrupt handlers that report end-of-packet (EOP) events and in process/workqueue contexts that clean up or forcibly complete fences — lock discipline must be consistent across those contexts.
Why fences and locks matter​
Fences are synchronization primitives. When the kernel interacts with GPU hardware it must ensure consistent internal state updates while avoiding deadlocks and race conditions. The kernel uses spinlocks in low-level DRM code because some operations are done from interrupt context, where sleeping locks are illegal. However, a spinlock must be acquired with the correct interrupt state depending on whether the caller may already be in hardirq context. Acquiring the same spinlock in different ways from different contexts can trip lockdep detection and cause panics or deadlocks. The CVE entry and the patch both point to this exact mismatch as the root cause.
What went wrong — technical root cause​
Call chains that conflict​
Two call paths lead into the problematic function:
  • Interrupt context: gfx_v11_0_eop_irqamdgpu_userq_fence_driver_process
  • Process/workqueue context: amdgpu_eviction_fence_suspend_workeramdgpu_userq_fence_driver_force_completionamdgpu_userq_fence_driver_process
In the interrupt path the code took a raw spinlock without saving/disabling interrupts; in the process path the same lock could be acquired in a context that would allow interrupts. That discrepancy leaves the kernel’s lock validator (lockdep) to detect statements like “inconsistent {IN-HARDIRQ-W} -> {HARDIRQ-ON-W} usage,” reported in the kernel log during failure. Those log frames are included directly in the vulnerability description.
What the kernel detects​
When the same lock is recorded as taken in a hardirq (interrupt) context and later taken in process context with interrupts enabled, lockdep identifies an inconsistent acquisition ordering or interrupt-state mismatch. The typical kernel diagnostic looks like:
[ 4039.310790] inconsistent {IN-HARDIRQ-W} -> {HARDIRQ-ON-W} usage.
That message indicates a flagged inconsistency in the interrupt-disabled vs. interrupts-enabled state while holding the lock, which can precede deadlocks or stuck worker threads if not corrected. The kernel documentation and the CVE record show the exact stack trace and diagnosis for this case.
The fix — what changed in the code​
Small, correct, and targeted​
The upstream patch modifies drivers/gpu/drm/amd/amdgpu/amdgpu_userq_fence.c to consistently manage interrupt state when taking fence_list_lock. In essence:
  • Introduce an unsigned long flags variable.
  • Replace spin_lock(&fence_drv->fence_list_lock) with spin_lock_irqsave(&fence_drv->fence_list_lock, flags).
  • Replace spin_unlock(&fence_drv->fence_list_lock) with spin_unlock_irqrestore(&fence_drv->fence_list_lock, flags).
That change ensures the lock is always taken with interrupts disabled and restored properly regardless of whether the caller was in IRQ context or process context — a canonical fix for this class of bug. The patch and its diff were posted to the AMD GPU mailing list and the change was cherry-picked into the kernel tree.
Why spin_lock_irqsave​
Using spin_lock_irqsave is the right choice here because:
  • It disables local hard IRQs and saves the prior interrupt state in flags.
  • When the lock is released, spin_unlock_irqrestore restores the saved interrupt state.
  • It is safe from both hardirq and process contexts and prevents lockdep’s inconsistent interrupt-state warnings.
This is a standard kernel technique to make a spinlock safe for mixed-context acquisition.
Scope, impact, and exploitability​
Who is affected​
  • Any system using the AMDGPU driver variant that includes the affected amdgpu_userq_fence implementation is a candidate for exposure.
  • This specifically affects Linux kernels with the vulnerable code path that preceded the upstream fix; downstream distributions that cherry-picked the patch or released an updated kernel will be protected once the patched kernel is deployed.
Impact severity and exploitation potential​
  • The vulnerability is a local kernel bug that can lead to deadlock or worker thread stalls, producing hangs or degraded graphics responsiveness.
  • It is not documented as a remote code-execution vector; the fix addresses a locking correctness issue rather than a memory corruption or privilege escalation primitive. Some vulnerability catalogs mark it as non-remote-exploitable. This means threat actors would need local code execution (or to trigger race conditions through local workloads) to reliably reproduce the failure.
Real-world signals​
Community bug reports and forum threads over the past months have discussed AMGPU instability, hangs, and pageflip timeouts. While such reports are noisy and not every display freeze maps to this exact lock bug, the presence of real users reporting amdgpu-related freezes, pageflip timeouts, and kernel error dumps reinforces the practical importance of correctness fixes in the driver stack. Administrators and users running AMD graphics on Linux should take these fixes seriously.
How to detect if you are affected​
  • Check your running kernel:
  • Run uname -r to see the kernel release. If your distribution has published a kernel update that includes the patch, the vendor changelog will typically mention the fix. If not, you may still be on an unpatched kernel.
  • Search the kernel log for the lockdep warning:
  • dmesg | grep -i "inconsistent {IN-HARDIRQ-W}" or journalctl -k | grep -i "inconsistent {IN-HARDIRQ-W}".
  • Look for stack traces containing amdgpu_userq_fence_driver_process or gfx_v11_0_eop_irq.
  • Inspect the amdgpu source in your kernel tree:
  • If you build kernels locally, open drivers/gpu/drm/amd/amdgpu/amdgpu_userq_fence.c and search for the locking pattern. An unpatched file will show spin_lock(&fence_drv->fence_list_lock)/spin_unlock(&fence_drv->fence_list_lock); the patched file will use spin_lock_irqsave(... and spin_unlock_irqrestore(.... The official patch and diff are available on the public kernel mailing archive.
Remediation and mitigation​
Recommended immediate actions​
  • Apply vendor kernel updates as soon as they are available for your distribution. This is the simplest and safest remediation. Major Linux distributions and the upstream kernel have the fix recorded; keep an eye on distro advisories for package updates.
  • If you cannot immediately update the kernel:
  • Consider rebooting into a known-good kernel (an earlier or later kernel version recommended by your vendor) if you observe hangs or repeated lockdep warnings.
  • Where possible, avoid workloads that aggressively stress the GPU user queues until you can patch.
Backporting the fix manually​
For administrators maintaining long-lived custom kernels or embedded kernels, the change is small and can be backported manually:
  • Apply the change to amdgpu_userq_fence.c:
  • Add unsigned long flags; in the local scope where the lock is used.
  • Rebuild the kernel or module and test carefully:
  • Edit the source in your kernel tree.
  • Recompile and install the kernel or the amdgpu module.
  • Boot the new kernel or reload the module (reloading a GPU module is often not feasible in a running desktop environment; a reboot is usually required).
  • Monitor dmesg for warnings and test GPU workloads under controlled conditions.
This manual approach is effective but carries the usual risks of custom kernel changes: ABI mismatches, build failures, and stability regressions. Only perform backports with adequate testing in non-production systems first. The authoritative patch and its diff are posted on the AMD GPU mailing list and were cherry-picked into stable kernel trees.
Where to get the patch and confirmation​
  • The upstream patch was posted to the AMD-GFX mailing list and included in kernel commits that were referenced in the official CVE/NVD entries. Look for those commits or the short patch on the kernel mailing list archives to verify the exact lines changed before applying.
Operational guidance for different audiences​
Desktop Linux users and gamers​
  • Watch for distribution kernel updates; apply them during your normal update cycle.
  • If you experience sudden freezes, pageflip timeouts, or repeated kernel log warnings referencing amdgpu or inconsistent {IN-HARDIRQ-W}, prioritize rebooting into an updated kernel or rolling back to a vendor-recommended kernel. Community reports indicate that regressions and freezes attributed to amdgpu occur in the wild and can be disruptive.
System administrators and servers with AMD GPUs​
  • Although this CVE is not directly a remote code execution risk, kernel deadlocks can cause service outages; schedule kernel updates through standard maintenance windows.
  • Use kernel livepatching solutions only if they support the affected area and if your vendor provides a livepatch for this specific fix; otherwise, plan for a reboot to a patched kernel.
Kernel maintainers and integrators​
  • The fix is deliberately minimal and targets correct interrupt-state handling. When backporting, ensure the patch is applied to the correct kernel version and that surrounding code context matches. Tests should include both interrupt-driven workloads (to exercise the EOP IRQ path) and process/workqueue-driven eviction/completion flows.
Risk analysis and caveats​
Strengths of the fix​
  • The change is conservative: it preserves intended behavior while making the lock usage consistent across contexts.
  • The fix uses a standard kernel pattern (irqsave/irqrestore) that kernel reviewers understand and trust. It is small, easy to audit, and low-risk compared to invasive redesigns.
Residual risks​
  • The underlying race scenario depends on call timing between IRQ and worker contexts; even after fixing the spinlock usage, other race conditions in the userq/fence codebase could manifest under different hardware/driver combinations.
  • Distributions that delay kernel updates or hold back patches because of backport/testing policies may continue to expose systems to this hang risk until the patched kernel is rolled out. Administrators should track distro advisories and maintain a patch plan.
Verification difficulty​
  • Diagnosing this issue from user reports alone can be tricky: a display freeze could be caused by other amdgpu bugs, Mesa regressions, or userspace components. Kernel log entries (lockdep warnings, stack traces referencing amdgpu_userq_fence_driver_process) are the most reliable indicator that this specific bug is involved.
Quick reference — commands and checks​
  • Check your kernel version:
  • uname -srm
  • Search kernel logs for the signature message:
  • sudo journalctl -k | grep -E "inconsistent {IN-HARDIRQ-W}|amdgpu_userq_fence_driver_process"
  • If you build kernels:
  • Inspect the code: grep -nR "amdgpu_userq_fence_driver_process" /usr/src/linux/drivers/gpu/drm/amd -n
  • Validate the locking pattern contains spin_lock_irqsave and spin_unlock_irqrestore.
  • Apply vendor updates (example for Debian/Ubuntu):
  • sudo apt update && sudo apt full-upgrade
  • Reboot into the updated kernel.
  • For manual backport:
  • Apply the exact three-line change shown in the public patch; rebuild kernel following your distro’s recommended build procedure. Test on a non-production system first.
Final thoughts​
CVE-2025-68203 is a textbook example of a correctness problem that can have outsized operational impact: a small inconsistency in how a spinlock is acquired across contexts can generate lockdep warnings, block worker threads, and produce user-facing hangs. The good news is the fix is straightforward and aligns with long-standing kernel locking practices. Administrators and users of systems with AMD GPUs should prioritize rolling out the patched kernel from their vendor or apply the minimal backport where appropriate, while monitoring kernel logs for any residual lockdep messages.
Note: the Microsoft Security Response Center page linked publicly for CVE lookup may require interactive features or vendor-specific entries; authoritative technical details for this CVE are present in the Linux kernel commit history and public kernel mailing-list patch archives and are summarized in public vulnerability databases. For production systems, prefer vendor-supplied kernel updates and official distro advisories over manual edits unless you maintain your own kernel builds.
