Windows 7 Long Term Chronic Seemling Random BSOD Problem
robwdavis
So, after reviewing countless forum posts over the past year plus, I finally decided to post my own problem here with hopes someone smarter than I can determine why my Win7 box has been crashing randomly for some time. Saga below...
Built the box in Dec 2010. Worked like a champ for some time. Started random crashes probably about a year later or so, not sure exactly when. Crashes are sporadic and seemingly random. They didn't happen all that often so I only spent a bit of time trying to troubleshoot. After a while, they started to get a bit more frequent but still not bad. At one point I ran MemTest numerous times and while most times it didn't have any errors, sometimes it did. Last fall I bought a couple of sticks of new RAM (F3-12800CL9D-8GBRL) and it seemed to help for a bit. After the crashes continued, I started to suspect something with the video card...
About half the time it crashes I get a BSOD, the other half the screen just goes all garbled and usually freezes required a hard reboot. In December I turned off the auto overclocking on my ASUS mobo's (M4A89GTD PRO/USB3) integrated graphics card (Radeon HD 4290), and that really seemed to help. There were only a few crashes over the next couple of months. Then, all hell broke loose mid-March. All of a sudden it was crashing several times a day, all with the same apparent randomness. I've started another battery of MemTest and still clean except once.
Why do I suspect the integrated graphics card? The problem seems to happen more often when there is something more active going on like a game, video, etc. Also, at times it actually has locked up in the BIOS and a couple of times while doing the MemTest (but no errors were reported). The one time there were errors in MemTest it was odd since it wasn't just a couple...it appeared to trigger something and started reporting continual errors until after about 30 seconds it locked up too. I've been testing with FurMark and while it's made it through a couple of times without crashing, most of the time it does crash. I've tried different shared memory settings for the integrated graphics thinking maybe the Sideport memory on the integrated graphics might be bad, but that hasn't been able to isolate the problem either.
So, not sure what else to do before I start buying new components...I'd rather not have to buy a new graphics card, mobo and CPU since the box I have now seems to be more than enough for us. Other details about the machine are below. I've also thought of doing a clean Win7 install, but since the problem appears to happen when I'm not even in Windows, I'd rather not go through that fun unless I have to. Next step is a new graphics card unless someone finds the smoking gun for me!
CPU: AMD Athlon X4 640
Mobo: M4A89GTD PRO/USB3
RAM: 2x F3-12800CL9D-8GBRL (originally 2x F3-12800CL9D-4GBRL)
Primary HDD: OCZ Vertex 2 60 GB (SDD) (have run scandisk several times, no problems)
Seconary HDD: WD 500 GB and an eSATA WD 1 TB
Powersupply: 600W Coolmaster Silent Pro (was replaced once during this ordeal due to a PSU failure, problem happened before and after).
Thanks in advance for your help!
Rob
  • robwdavis.zip
usasma
Fantastic Member
Just FYI - a recent poster (early Nov 2011) states that they were advised by Asus to manually set their memory settings/timings/voltages because of issues with the M4 series of motherboards.
You can get the settings/timings/voltages from the website of your RAM manufacturer.
We've seen a number of BSOD issues with SSD's. Here's the information that I've compiled so far:
There's not a whole bunch available to test SSD's. The "easiest" test is to remove the SSD, install a platter-based hard drive, install Windows and test for stability that way.
Here's some suggestions:
- Update the SSD's firmware to the latest available version (VERY IMPORTANT!!!)
- Update the motherboard controllers drivers to the latest available version from the controller manufacturer (NOT the mobo manufacturer unless you can't find any on the controller manufacturer's website). Be sure to update ALL controllers on the motherboard! I STRONGLY suggest not using controller drivers older than mid-2012 with SSD's.
- Slow the memory (RAM) down to the next slower speed (I've only seen one person who claimed that this worked for them).
- Use any manufacturer's utilities that you may have. If you don't have any, then try this free one (I haven't used it myself): Crystal Dew World
....NOTE: Recently (Nov 2011) we had BSOD issues with the Marvell 91xx controller and an SSD. You may have to switch controllers also.
- Replace the SSD with a platter based hard drive and see if that stops the BSOD's. If it does, then it's likely that there's a problem with the SSD OR an incompatibility with your system.
06 Dec 2011 - This post tends to confirm issues with certain SSD chipsets and certain controllers - [SOLVED] cant find the cause of BSOD F4 - Tech Support Forum
05 Jan 2013 - very interesting post about difficulties with the Marvell controllers even when not connected to the SSD drives: https://www.eightforums.com/bsod-cr...-pc-reboots-when-waking-sleep.html#post169956
27 Feb 2013 - I'm starting to see much better reliability with SSD's using current (mid-2012 and later) storage drivers. I have withdrawn my objections to using these devices in everyday systems.
You have 3 hard drives. What is the make/model/wattage and age of your Power Supply?
You have numerous different error codes (so many that I lost count) The differing error codes are usually symptomatic of a lower level problem within the system. They are usually caused by one of these things:
- borked (broken) hardware (several different procedures used to isolate the problem device)
- BIOS issues (check for updates at the motherboard manufacturer's website)
- overclocking - You'll know if you're overclocking or not. If uncertain we can suggest things to check.
- compatibility issues (3rd party hardware/drivers)
- low-level driver problems
- or even malware (scanned for when we ask for hardware diagnostics from Initial Hardware Diagnostics or Hardware Diagnostics ).
AMD OverDrive (AODDriver2.sys) is either a stand-alone application, or a component of the AMD VISION Engine Control Center. This driver is known to cause BSOD's on some Windows systems.
Please un-install all AMD/ATI video stuff from Control Panel...Programs...Un-install a program
Then, download (but DO NOT install) a fresh copy of the ATI drivers from Global Provider of Innovative Graphics, Processors and Media Solutions | AMD (in the upper right corner of the page)
Use this procedure to install the DRIVER ONLY: ATI video cards - DRIVER ONLY installation procedure - Sysnative Forums
If the device (AODDriver or AODDriver4.01) remains a problem, open Device Manager, select the "View" item.
Then select "Show hidden devices" and scroll down to the Non-Plug and Play Drivers section.
Locate the AODDriver entry, right click on it and select "Un-install". Reboot for changes to take affect.
Sometimes the driver remains and continues to cause BSOD's. If this is the case for you, post back and we'll give further instructions for safely removing it.
If overclocking, please stop. Remove the overclock and return the system to stock/standard values while we're troubleshooting. Once the system is stable again, feel free to resume the overclocking.
GRMNGEN.SYS Thu Apr 30 12:45:26 2009 (49F9D5A6)
Garmin Generic WDM Support Driver
http://www.carrona.org/drivers/driver.php?id=GRMNGEN.SYS
grmnusb.sys Thu Apr 30 12:45:27 2009 (49F9D5A7)
Garmin USB GPS driver
http://www.carrona.org/drivers/driver.php?id=grmnusb.sys
AtiPcie.sys Tue May 5 11:00:22 2009 (4A005486)
ATI PCIE Driver for ATI PCIE chipset or [br] ATI PCI Express (3GIO) Filter[br]Found in my ATI video drivers (I have an Intel chipset)
http://www.carrona.org/drivers/driver.php?id=AtiPcie.sys
nusb3hub.sys Thu Apr 22 21:34:35 2010 (4BD0F92B)
NEC Electronics USB 3.0 Host Controller Driver (previous BSOD issues with 2010 version)
http://www.carrona.org/drivers/driver.php?id=nusb3hub.sys
nusb3xhc.sys Thu Apr 22 21:34:36 2010 (4BD0F92C)
http://www.carrona.org/drivers/driver.php?id=nusb3xhc.sys
As you have time, please start running these free hardware diagnostics also: Hardware Diagnostics This'll give you a head start if the 3rd party drivers aren't the cause.
Analysis:
The following is for informational purposes only.
[FONT=lucida console]**************************Sat Apr  6 19:26:29.953 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040613-50544-02.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].18044.amd64fre.win7sp1_gdr.130104-1431
System Uptime:[B]0 days 1:52:28.608[/B]
Probably caused by :[B]hardware ( Unknown_Module_fffff880`044be570>+5ed1588 )[/B]
BugCheck [B]A, {7fffffd3fb8, 2, 1, fffff8000387f852}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000000A"]IRQL_NOT_LESS_OR_EQUAL (a)[/URL]
Arguments:
Arg1: 000007fffffd3fb8, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
Arg4: fffff8000387f852, address which referenced memory
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID: [B]X64_IP_MISALIGNED[/B]
**************************Sat Apr  6 17:25:32.255 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040613-51605-01.dmp]
System Uptime:[B]0 days 0:07:29.816[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+35084 )[/B]
BugCheck [B]1A, {41790, fffffa8001241970, ffff, 0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000001A"]MEMORY_MANAGEMENT (1a)[/URL]
Arguments:
Arg1: 0000000000041790, A page table page has been corrupted. On a 64 bit OS, parameter 2
    contains the address of the PFN for the corrupted page table page.
    On a 32 bit OS, parameter 2 contains a pointer to the number of used
    PTEs, and parameter 3 contains the number of used PTEs.
Arg2: fffffa8001241970
Arg3: 000000000000ffff
Arg4: 0000000000000000
BUGCHECK_STR:  0x1a_41790
PROCESS_NAME:  dxdiag.exe
FAILURE_BUCKET_ID: [B]X64_0x1a_41790_nt!_??_::FNODOBFM::_string_+35084[/B]
  BIOS Version                  3029
  BIOS Release Date             07/05/2012
**************************Sat Apr  6 16:31:29.054 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040613-50559-02.dmp]
System Uptime:[B]0 days 0:13:56.241[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiKernelCalloutExceptionHandler+e )[/B]
BugCheck [B]1E, {0, 0, 0, 0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000001E"]KMODE_EXCEPTION_NOT_HANDLED (1e)[/URL]
Arguments:
Arg1: 0000000000000000, The exception code that was not handled
Arg2: 0000000000000000, The address that the exception occurred at
BUGCHECK_STR:  0x1E
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]X64_0x1E_nt!KiKernelCalloutExceptionHandler+e[/B]
  BIOS Version                  3029
**************************Sat Apr  6 16:13:31.572 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040613-50606-01.dmp]
System Uptime:[B]0 days 4:59:16.133[/B]
*** WARNING: Unable to verify timestamp for mfehidk.sys
*** ERROR: Module load completed but symbols could not be loaded for mfehidk.sys
Probably caused by :[B]mfehidk.sys ( mfehidk+16869 )[/B]
BugCheck [B]135, {ffffffffc0000005, fffff88007c7eac0, fffff88001301700, fffff8a00027e380}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x00000135"]REGISTRY_FILTER_DRIVER_EXCEPTION (135)[/URL]
Arguments:
Arg1: ffffffffc0000005, ExceptionCode
Arg2: fffff88007c7eac0, Address of the context record for the exception that caused the bugcheck
Arg3: fffff88001301700, The driver's callback routine address
Arg4: fffff8a00027e380, Internal
BUGCHECK_STR:  0x135
PROCESS_NAME:  explorer.exe
FAILURE_BUCKET_ID: [B]X64_0x135_mfehidk+16869[/B]
  BIOS Version                  3029
**************************Sat Apr  6 11:13:08.845 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040613-50981-01.dmp]
System Uptime:[B]0 days 0:03:58.406[/B]
Probably caused by :[B]mfehidk.sys ( mfehidk+48204 )[/B]
BugCheck [B]24, {1904fb, fffff88003df8bf8, fffff88003df8450, fffff8800100d64d}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x00000024"]NTFS_FILE_SYSTEM (24)[/URL]
Arguments:
Arg1: 00000000001904fb
Arg2: fffff88003df8bf8
Arg3: fffff88003df8450
Arg4: fffff8800100d64d
PROCESS_NAME:  services.exe
BUGCHECK_STR:  0x24
FAILURE_BUCKET_ID: [B]X64_0x24_mfehidk+48204[/B]
  BIOS Version                  3029
**************************Sat Apr  6 11:08:04.919 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040613-50559-01.dmp]
System Uptime:[B]0 days 0:04:41.496[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KipFatalFilter+1b )[/B]
BugCheck [B]1E, {ffffffffc0000005, fffff88003118fe0, 0, 0}[/B]
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff88003118fe0, The address that the exception occurred at
BUGCHECK_STR:  0x1E_c0000005_R
FAILURE_BUCKET_ID: [B]X64_0x1E_c0000005_R_nt!KipFatalFilter+1b[/B]
  BIOS Version                  3029
**************************Sat Apr  6 11:02:35.768 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040613-50591-01.dmp]
System Uptime:[B]0 days 0:07:02.344[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!ExReinitializeResourceLite+f2 )[/B]
BugCheck [B]24, {1904fb, fffff88008eb66e8, fffff88008eb5f40, fffff8000386fba2}[/B]
Arguments:
Arg2: fffff88008eb66e8
Arg3: fffff88008eb5f40
Arg4: fffff8000386fba2
BUGCHECK_STR:  0x24
FAILURE_BUCKET_ID: [B]X64_0x24_nt!ExReinitializeResourceLite+f2[/B]
  BIOS Version                  3029
**************************Sat Apr  6 10:53:40.143 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040613-50544-01.dmp]
System Uptime:[B]0 days 0:43:35.719[/B]
*** WARNING: Unable to verify timestamp for Unknown_Module_00000000`00000000
Probably caused by :[B]ntkrnlmp.exe ( nt!AlpcpProcessSynchronousRequest+366 )[/B]
BugCheck [B]3B, {c0000005, fffff80003be1119, fffff8800a7abfe0, 0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000003B"]SYSTEM_SERVICE_EXCEPTION (3b)[/URL]
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff80003be1119, Address of the instruction which caused the bugcheck
Arg3: fffff8800a7abfe0, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
BUGCHECK_STR:  0x3B
FAILURE_BUCKET_ID: [B]X64_0x3B_nt!AlpcpProcessSynchronousRequest+366[/B]
**************************Sat Apr  6 09:58:20.702 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040613-50622-01.dmp]
System Uptime:[B]0 days 0:24:38.263[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+4518f )[/B]
BugCheck [B]50, {fffff88007496eb5, 8, fffff88007496eb5, 0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x00000050"]PAGE_FAULT_IN_NONPAGED_AREA (50)[/URL]
Arguments:
Arg1: fffff88007496eb5, memory referenced.
Arg2: 0000000000000008, value 0 = read operation, 1 = write operation.
Arg3: fffff88007496eb5, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000000, (reserved)
BUGCHECK_STR:  0x50
FAILURE_BUCKET_ID: [B]X64_0x50_BAD_IP_nt!_??_::FNODOBFM::_string_+4518f[/B]
  BIOS Version                  3029
**************************Sat Apr  6 09:32:47.896 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040613-51012-01.dmp]
System Uptime:[B]0 days 0:03:24.082[/B]
Probably caused by :[B]hardware ( nt! ?? ::FNODOBFM::`string'+487ed )[/B]
BugCheck [B]1E, {ffffffffc0000005, fffff8000389d6d3, 1, c000005c}[/B]
Arguments:
Arg2: fffff8000389d6d3, The address that the exception occurred at
Arg3: 0000000000000001, Parameter 0 of the exception
Arg4: 00000000c000005c, Parameter 1 of the exception
PROCESS_NAME:  McSvHost.exe
  BIOS Version                  3029
**************************Sat Apr  6 09:28:50.155 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040613-14008-01.dmp]
System Uptime:[B]0 days 0:12:52.716[/B]
*** WARNING: Unable to verify timestamp for atikmpag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmpag.sys
Probably caused by :[B]dxgmms1.sys ( dxgmms1!VidSchiVerifyDriverReportedFenceId+ad )[/B]
BugCheck [B]119, {1, f0e4, e4, e4}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x00000119"]VIDEO_SCHEDULER_INTERNAL_ERROR (119)[/URL]
Arguments:
Arg1: 0000000000000001, The driver has reported an invalid fence ID.
Arg2: 000000000000f0e4
Arg3: 00000000000000e4
Arg4: 00000000000000e4
BUGCHECK_STR:  0x119
FAILURE_BUCKET_ID: [B]X64_0x119_dxgmms1!VidSchiVerifyDriverReportedFenceId+ad[/B]
  BIOS Version                  3029
**************************Fri Apr  5 20:52:10.432 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040513-50996-01.dmp]
System Uptime:[B]0 days 0:03:45.008[/B]
*** ERROR: Module load completed but symbols could not be loaded for partmgr.sys
*** ERROR: Module load completed but symbols could not be loaded for volmgr.sys
*** ERROR: Module load completed but symbols could not be loaded for volsnap.sys
*** ERROR: Module load completed but symbols could not be loaded for Fs_Rec.sys
Probably caused by :[B]partmgr.sys ( partmgr+3512 )[/B]
BugCheck [B]C2, {7, 109b, 30676863, fffffa8007990010}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x000000C2"]BAD_POOL_CALLER (c2)[/URL]
Arguments:
Arg1: 0000000000000007, Attempt to free pool which was already freed
Arg2: 000000000000109b, (reserved)
Arg3: 0000000030676863, Memory contents of the pool block
Arg4: fffffa8007990010, Address of the block of pool being deallocated
BUGCHECK_STR:  0xc2_7
PROCESS_NAME:  WUDFHost.exe
FAILURE_BUCKET_ID: [B]X64_0xc2_7_partmgr+3512[/B]
  BIOS Version                  3029
**************************Fri Apr  5 20:47:49.695 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040513-51199-01.dmp]
System Uptime:[B]0 days 0:06:03.256[/B]
Probably caused by :[B]CLASSPNP.SYS ( CLASSPNP!TransferPktComplete+1ce )[/B]
BugCheck [B]D1, {6a00, 2, 8, 6a00}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x000000D1"]DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)[/URL]
Arguments:
Arg1: 0000000000006a00, memory referenced
Arg3: 0000000000000008, value 0 = read operation, 1 = write operation
Arg4: 0000000000006a00, address which referenced memory
BUGCHECK_STR:  0xD1
FAILURE_BUCKET_ID: [B]X64_0xD1_CODE_AV_BAD_IP_CLASSPNP!TransferPktComplete+1ce[/B]
  BIOS Version                  3029
**************************Fri Apr  5 19:26:13.785 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040513-51979-01.dmp]
System Uptime:[B]0 days 0:08:27.346[/B]
BugCheck [B]119, {1, ef00, 7d, 7d}[/B]
Arguments:
Arg2: 000000000000ef00
Arg3: 000000000000007d
Arg4: 000000000000007d
BUGCHECK_STR:  0x119
  BIOS Version                  3029
**************************Fri Apr  5 19:00:29.108 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040513-51121-01.dmp]
System Uptime:[B]0 days 0:01:12.669[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiDeliverApc+187 )[/B]
BugCheck [B]A, {0, 2, 1, fffff800038cf617}[/B]
Arguments:
Arg1: 0000000000000000, memory referenced
Arg4: fffff800038cf617, address which referenced memory
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID: [B]X64_0xA_nt!KiDeliverApc+187[/B]
  BIOS Version                  3029
**************************Thu Apr  4 17:53:14.830 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040413-59639-01.dmp]
System Uptime:[B]0 days 0:02:37.001[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+27911 )[/B]
BugCheck [B]34, {49d, ffffffffc0000420, 0, 0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x00000034"]CACHE_MANAGER (34)[/URL]
Arguments:
Arg1: 000000000000049d
Arg2: ffffffffc0000420
BUGCHECK_STR:  0x34
FAILURE_BUCKET_ID: [B]X64_0x34_nt!_??_::FNODOBFM::_string_+27911[/B]
  BIOS Version                  3029
**************************Mon Apr  1 16:03:22.230 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040113-52728-01.dmp]
System Uptime:[B]0 days 6:27:14.401[/B]
*** WARNING: Unable to verify timestamp for ????????
Probably caused by :[B]ntkrnlmp.exe ( nt!PoIdle+52a )[/B]
BugCheck [B]4E, {99, 1d4ab4, 0, 1d4dc4}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000004E"]PFN_LIST_CORRUPT (4e)[/URL]
Arguments:
Arg1: 0000000000000099, A PTE or PFN is corrupt
Arg2: 00000000001d4ab4, page frame number
Arg3: 0000000000000000, current page state
Arg4: 00000000001d4dc4, 0
BUGCHECK_STR:  0x4E_99
FAILURE_BUCKET_ID: [B]X64_0x4E_99_nt!PoIdle+52a[/B]
**************************Sun Mar 31 21:04:20.090 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\033113-54615-01.dmp]
System Uptime:[B]0 days 1:45:20.588[/B]
Probably caused by :[B]win32k.sys ( win32k!EngRestoreFloatingPointState+2a82 )[/B]
BugCheck [B]50, {fffff900c3b46018, 1, fffff9600012a382, 0}[/B]
Arguments:
Arg1: fffff900c3b46018, memory referenced.
Arg2: 0000000000000001, value 0 = read operation, 1 = write operation.
Arg3: fffff9600012a382, If non-zero, the instruction address which referenced the bad memory
    address.
BUGCHECK_STR:  0x50
PROCESS_NAME:  ViewNX2.exe
FAILURE_BUCKET_ID: [B]X64_0x50_win32k!EngRestoreFloatingPointState+2a82[/B]
  BIOS Version                  3029
**************************Mon Apr  1 09:35:34.027 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040113-53414-01.dmp]
System Uptime:[B]0 days 0:01:05.198[/B]
Probably caused by :[B]Pool_Corruption ( nt!ExDeferredFreePool+a53 )[/B]
BugCheck [B]19, {3, fffffa80066902b0, fffffa80066908c0, fffffa80066902b0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x00000019"]BAD_POOL_HEADER (19)[/URL]
Arguments:
Arg1: 0000000000000003, the pool freelist is corrupt.
Arg2: fffffa80066902b0, the pool entry being checked.
Arg3: fffffa80066908c0, the read back flink freelist value (should be the same as 2).
Arg4: fffffa80066902b0, the read back blink freelist value (should be the same as 2).
BUGCHECK_STR:  0x19_3
PROCESS_NAME:  svchost.exe
FAILURE_BUCKET_ID: [B]X64_0x19_3_nt!ExDeferredFreePool+a53[/B]
  BIOS Version                  3029
**************************Mon Apr  1 09:30:54.711 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040113-53601-01.dmp]
System Uptime:[B]0 days 12:23:53.881[/B]
Probably caused by :[B]USBPORT.SYS ( USBPORT!USBPORT_Core_iCompleteDoneTransfer+45f )[/B]
BugCheck [B]A, {fffffa880b947000, 2, 0, fffff80003deb3da}[/B]
Arguments:
Arg1: fffffa880b947000, memory referenced
Arg3: 0000000000000000, bitfield :
Arg4: fffff80003deb3da, address which referenced memory
BUGCHECK_STR:  0xA
PROCESS_NAME:  MSMONEY.EXE
FAILURE_BUCKET_ID: [B]X64_0xA_USBPORT!USBPORT_Core_iCompleteDoneTransfer+45f[/B]
  BIOS Version                  3029
**************************Wed Mar 27 22:04:57.939 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032713-53991-01.dmp]
System Uptime:[B]0 days 0:01:45.499[/B]
Probably caused by :[B]storport.sys ( storport!StorPortGetScatterGatherList+1fd )[/B]
Arguments:
BUGCHECK_STR:  0x1E
FAILURE_BUCKET_ID: [B]X64_0x1E_storport!StorPortGetScatterGatherList+1fd[/B]
  BIOS Version                  3029
**************************Wed Mar 27 22:02:27.314 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032713-53024-01.dmp]
System Uptime:[B]0 days 1:50:25.875[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+48de1 )[/B]
BugCheck [B]18, {0, fffffa8009b451e0, 2, ffffffffffffffff}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x00000018"]REFERENCE_BY_POINTER (18)[/URL]
Arguments:
Arg1: 0000000000000000, Object type of the object whose reference count is being lowered
Arg2: fffffa8009b451e0, Object whose reference count is being lowered
Arg3: 0000000000000002, Reserved
Arg4: ffffffffffffffff, Reserved
    The reference count of an object is illegal for the current state of the object.
    Each time a driver uses a pointer to an object the driver calls a kernel routine
    to increment the reference count of the object. When the driver is done with the
    pointer the driver calls another kernel routine to decrement the reference count.
    Drivers must match calls to the increment and decrement routines. This bugcheck
    can occur because an object's reference count goes to zero while there are still
    open handles to the object, in which case the fourth parameter indicates the number
    of opened handles. It may also occur when the object?s reference count drops below zero
    whether or not there are open handles to the object, and in that case the fourth parameter
    contains the actual value of the pointer references count.
BUGCHECK_STR:  0x18
PROCESS_NAME:  iexplore.exe
FAILURE_BUCKET_ID: [B]X64_0x18_OVER_DEREFERENCE_nt!_??_::FNODOBFM::_string_+48de1[/B]
  BIOS Version                  3029
**************************Tue Mar 26 22:07:01.610 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032613-54007-01.dmp]
System Uptime:[B]0 days 5:54:04.202[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!CmpKcbCacheLookup+1de )[/B]
BugCheck [B]3B, {c0000005, fffff80003b5430e, fffff8800b836720, 0}[/B]
Arguments:
Arg2: fffff80003b5430e, Address of the instruction which caused the bugcheck
Arg3: fffff8800b836720, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
PROCESS_NAME:  OUTLOOK.EXE
FAILURE_BUCKET_ID: [B]X64_0x3B_nt!CmpKcbCacheLookup+1de[/B]
  BIOS Version                  3029
**************************Tue Mar 26 14:51:24.978 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032613-53071-01.dmp]
System Uptime:[B]0 days 14:09:27.165[/B]
Probably caused by :[B]Unknown_Image ( ANALYSIS_INCONCLUSIVE )[/B]
Arguments:
BUGCHECK_STR:  0x1E
**************************Mon Mar 25 23:07:21.773 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032513-92586-01.dmp]
System Uptime:[B]0 days 0:03:27.334[/B]
*** WARNING: Unable to verify timestamp for amd_xata.sys
*** ERROR: Module load completed but symbols could not be loaded for amd_xata.sys
Probably caused by :[B]hardware ( amd_xata+8c16 )[/B]
BugCheck [B]D5, {fffff9801a680fb0, 1, fffff88001196c16, 0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x000000D5"]DRIVER_PAGE_FAULT_IN_FREED_SPECIAL_POOL (d5)[/URL]
Arguments:
Arg1: fffff9801a680fb0, memory referenced
Arg3: fffff88001196c16, if non-zero, the address which referenced memory.
BUGCHECK_STR:  0xD5
DEFAULT_BUCKET_ID: [B][COLOR=RED]VERIFIER_ENABLED_VISTA_MINIDUMP[/COLOR][/B]
FAILURE_BUCKET_ID: [B]X64_IP_MISALIGNED_amd_xata.sys[/B]
  BIOS Version                  3029
**************************Mon Mar 25 21:23:38.418 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032513-53913-01.dmp]
System Uptime:[B]0 days 0:01:49.979[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!ExAllocatePoolWithTag+537 )[/B]
BugCheck [B]C5, {8, 2, 1, fffff800039fc147}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x000000C5"]DRIVER_CORRUPTED_EXPOOL (c5)[/URL]
Arguments:
Arg1: 0000000000000008, memory referenced
Arg3: 0000000000000001, value 0 = read operation, 1 = write operation
Arg4: fffff800039fc147, address which referenced memory
BUGCHECK_STR:  0xC5_2
FAILURE_BUCKET_ID: [B]X64_0xC5_2_nt!ExAllocatePoolWithTag+537[/B]
**************************Sat Mar 23 23:58:21.531 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032313-52962-01.dmp]
System Uptime:[B]0 days 0:00:59.092[/B]
Probably caused by :[B]amd_xata.sys ( amd_xata+1d06 )[/B]
BugCheck [B]D1, {760, 2, 0, fffff880010e8c1d}[/B]
Arguments:
Arg1: 0000000000000760, memory referenced
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff880010e8c1d, address which referenced memory
BUGCHECK_STR:  0xD1
FAILURE_BUCKET_ID: [B]X64_0xD1_amd_xata+1d06[/B]
  BIOS Version                  3029
**************************Sat Mar 23 23:56:12.449 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032313-52899-01.dmp]
System Uptime:[B]0 days 0:08:22.010[/B]
*** ERROR: Module load completed but symbols could not be loaded for cdd.dll
Probably caused by :[B]cdd.dll ( cdd+599b )[/B]
BugCheck [B]1000007E, {ffffffffc0000094, fffff9600078599b, fffff880069c3778, fffff880069c2fd0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x1000007E"]SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)[/URL]
Arguments:
Arg1: ffffffffc0000094, The exception code that was not handled
Arg2: fffff9600078599b, The address that the exception occurred at
Arg3: fffff880069c3778, Exception Record Address
Arg4: fffff880069c2fd0, Context Record Address
BUGCHECK_STR:  0x7E
PROCESS_NAME:  csrss.exe
FAILURE_BUCKET_ID: [B]X64_0x7E_cdd+599b[/B]
  BIOS Version                  3029
**************************Sat Mar 23 18:59:32.947 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032313-51558-01.dmp]
System Uptime:[B]0 days 1:57:20.133[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiDoubleFaultAbort+b2 )[/B]
BugCheck [B]7F, {8, 80050031, 6f8, fffff80003886f24}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000007F"]UNEXPECTED_KERNEL_MODE_TRAP (7f)[/URL]
Arguments:
Arg1: 0000000000000008, EXCEPTION_DOUBLE_FAULT
Arg2: 0000000080050031
Arg3: 00000000000006f8
Arg4: fffff80003886f24
BUGCHECK_STR:  0x7f_8
FAILURE_BUCKET_ID: [B]X64_0x7f_8_nt!KiDoubleFaultAbort+b2[/B]
  BIOS Version                  3029
**************************Fri Mar 22 22:42:58.624 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032213-53586-01.dmp]
System Uptime:[B]0 days 0:02:53.185[/B]
BugCheck [B]119, {1, c301, 1, 1}[/B]
Arguments:
Arg2: 000000000000c301
Arg4: 0000000000000001
BUGCHECK_STR:  0x119
PROCESS_NAME:  CCC.exe
  BIOS Version                  3029
**************************Fri Mar 22 15:03:38.544 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032213-52837-01.dmp]
System Uptime:[B]0 days 3:57:42.105[/B]
Probably caused by :[B]SCSIPORT.SYS ( SCSIPORT!DllInitialize+3eed )[/B]
BugCheck [B]A, {8, 2, 1, fffff80003817bbe}[/B]
Arguments:
Arg4: fffff80003817bbe, address which referenced memory
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID: [B]X64_0xA_SCSIPORT!DllInitialize+3eed[/B]
  BIOS Version                  3029
**************************Thu Mar 21 22:45:33.802 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032113-53399-01.dmp]
System Uptime:[B]0 days 0:02:13.362[/B]
Probably caused by :[B]Pool_Corruption ( nt!ExDeferredFreePool+100 )[/B]
BugCheck [B]50, {ffffffffffffffff, 0, fffff800039bb9bc, 0}[/B]
Arguments:
Arg1: ffffffffffffffff, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff800039bb9bc, If non-zero, the instruction address which referenced the bad memory
    address.
BUGCHECK_STR:  0x50
FAILURE_BUCKET_ID: [B]X64_0x50_nt!ExDeferredFreePool+100[/B]
  BIOS Version                  3029
**************************Thu Mar 21 22:41:45.790 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032113-52915-01.dmp]
System Uptime:[B]0 days 7:55:40.351[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KeReleaseSemaphore+137 )[/B]
BugCheck [B]A, {fffff880009fdb08, 2, 1, fffff800038a0327}[/B]
Arguments:
Arg1: fffff880009fdb08, memory referenced
Arg4: fffff800038a0327, address which referenced memory
BUGCHECK_STR:  0xA
PROCESS_NAME:  mfefire.exe
FAILURE_BUCKET_ID: [B]X64_0xA_nt!KeReleaseSemaphore+137[/B]
  BIOS Version                  3029
**************************Wed Mar 20 21:49:00.797 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032013-53898-01.dmp]
System Uptime:[B]0 days 10:05:03.358[/B]
Probably caused by :[B]tcpip.sys ( tcpip!IppInspectLocalDatagramsOut+88 )[/B]
BugCheck [B]D1, {13, 2, 0, fffff88001889b68}[/B]
Arguments:
Arg1: 0000000000000013, memory referenced
Arg4: fffff88001889b68, address which referenced memory
BUGCHECK_STR:  0xD1
FAILURE_BUCKET_ID: [B]X64_0xD1_tcpip!IppInspectLocalDatagramsOut+88[/B]
  BIOS Version                  3029
**************************Wed Mar 20 11:43:04.159 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032013-52899-01.dmp]
System Uptime:[B]0 days 0:11:47.720[/B]
*** ERROR: Module load completed but symbols could not be loaded for usbohci.sys
Probably caused by :[B]usbohci.sys ( usbohci+2a45 )[/B]
BugCheck [B]FE, {5, fffffa8007e971a0, 10024397, fffffa80077c4258}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x000000FE"]BUGCODE_USB_DRIVER (fe)[/URL]
Arguments:
Arg1: 0000000000000005, USBBUGCODE_INVALID_PHYSICAL_ADDRESS The host controller is
    using a physical memory address that was not allocated by
    the USBport driver.
Arg2: fffffa8007e971a0, Device extension pointer of the host controller
Arg3: 0000000010024397, PCI Vendor,Product id for the controller
Arg4: fffffa80077c4258, Pointer to Endpoint data structure
BUGCHECK_STR:  0xFE
FAILURE_BUCKET_ID: [B]X64_0xFE_INVALID_PHYSICAL_ADDR_usbohci+2a45[/B]
  BIOS Version                  3029
**************************Tue Mar 19 19:59:58.266 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031913-52884-01.dmp]
System Uptime:[B]0 days 0:04:45.842[/B]
Probably caused by :[B]hardware ( nt!KiInterruptDispatch+22 )[/B]
BugCheck [B]A, {ffffda802fc8f485, 2, 1, fffff80003876952}[/B]
Arguments:
Arg1: ffffda802fc8f485, memory referenced
Arg4: fffff80003876952, address which referenced memory
BUGCHECK_STR:  0xA
  BIOS Version                  3029
**************************Tue Mar 19 10:21:28.740 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031913-52244-01.dmp]
System Uptime:[B]0 days 0:04:22.926[/B]
BugCheck [B]119, {1, fc77, 77, 77}[/B]
Arguments:
Arg2: 000000000000fc77
Arg3: 0000000000000077
Arg4: 0000000000000077
BUGCHECK_STR:  0x119
  BIOS Version                  3029
**************************Sat Mar 16 10:20:37.876 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031613-51776-01.dmp]
System Uptime:[B]0 days 9:48:45.437[/B]
Probably caused by :[B]win32k.sys ( win32k!EngFntCacheLookUp+6a5e )[/B]
BugCheck [B]A, {8, 2, 1, fffff8000387b61a}[/B]
Arguments:
Arg4: fffff8000387b61a, address which referenced memory
BUGCHECK_STR:  0xA
PROCESS_NAME:  iTunes.exe
FAILURE_BUCKET_ID: [B]X64_0xA_win32k!EngFntCacheLookUp+6a5e[/B]
  BIOS Version                  3029
**************************Sat Mar 16 00:28:46.826 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031513-11746-01.dmp]
System Uptime:[B]0 days 6:29:38.997[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiPageFault+260 )[/B]
BugCheck [B]A, {4bd5, 2, 0, fffff8000387ac8a}[/B]
Arguments:
Arg1: 0000000000004bd5, memory referenced
Arg4: fffff8000387ac8a, address which referenced memory
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID: [B]X64_0xA_nt!KiPageFault+260[/B]
  BIOS Version                  3029
**************************Fri Mar 15 17:58:26.930 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031513-50715-01.dmp]
System Uptime:[B]0 days 22:04:45.101[/B]
Probably caused by :[B]mfehidk.sys ( mfehidk+e8c4 )[/B]
BugCheck [B]50, {fffffa800de00000, 0, fffff800038d6cbb, 2}[/B]
Arguments:
Arg1: fffffa800de00000, memory referenced.
Arg3: fffff800038d6cbb, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000002, (reserved)
BUGCHECK_STR:  0x50
PROCESS_NAME:  mcshield.exe
FAILURE_BUCKET_ID: [B]X64_0x50_mfehidk+e8c4[/B]
  BIOS Version                  3029
**************************Thu Mar 14 15:17:40.410 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031413-53087-01.dmp]
System Uptime:[B]3 days 2:22:30.987[/B]
Probably caused by :[B]win32k.sys ( win32k!EngRestoreFloatingPointState+d1bf )[/B]
BugCheck [B]3B, {c0000005, fffff96000124abf, fffff880029a60c0, 0}[/B]
Arguments:
Arg2: fffff96000124abf, Address of the instruction which caused the bugcheck
Arg3: fffff880029a60c0, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
FAILURE_BUCKET_ID: [B]X64_0x3B_win32k!EngRestoreFloatingPointState+d1bf[/B]
  BIOS Version                  3029
**************************Sat Mar  9 23:17:36.939 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030913-51183-01.dmp]
System Uptime:[B]0 days 1:47:47.110[/B]
BugCheck [B]119, {1, 683f, 63f, 63f}[/B]
Arguments:
Arg2: 000000000000683f
Arg3: 000000000000063f
Arg4: 000000000000063f
BUGCHECK_STR:  0x119
  BIOS Version                  3029
**************************Sat Mar  9 20:59:51.862 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030913-52868-01.dmp]
System Uptime:[B]0 days 0:06:39.048[/B]
Probably caused by :[B]memory_corruption ( nt!MiGetNextNode+15 )[/B]
BugCheck [B]3B, {c0000005, fffff800038a9001, fffff88006e3bd90, 0}[/B]
Arguments:
Arg2: fffff800038a9001, Address of the instruction which caused the bugcheck
Arg3: fffff88006e3bd90, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
FAILURE_BUCKET_ID: [B]X64_0x3B_nt!MiGetNextNode+15[/B]
  BIOS Version                  3029
**************************Sat Mar  9 20:52:27.386 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030913-52525-01.dmp]
System Uptime:[B]0 days 0:08:37.120[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!ObLogSecurityDescriptor+c2 )[/B]
BugCheck [B]3B, {c0000005, fffff80003bcab51, fffff8800acf0db0, 0}[/B]
Arguments:
Arg2: fffff80003bcab51, Address of the instruction which caused the bugcheck
Arg3: fffff8800acf0db0, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
FAILURE_BUCKET_ID: [B]X64_0x3B_nt!ObLogSecurityDescriptor+c2[/B]
  BIOS Version                  3029
**************************Sat Feb 16 07:10:15.984 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\021613-14866-01.dmp]
System Uptime:[B]0 days 8:50:52.545[/B]
*** WARNING: Unable to verify timestamp for RTKVHD64.sys
*** ERROR: Module load completed but symbols could not be loaded for RTKVHD64.sys
Probably caused by :[B]RTKVHD64.sys ( RTKVHD64+2e96 )[/B]
BugCheck [B]A, {0, 2, 1, fffff800038e0750}[/B]
Arguments:
Arg4: fffff800038e0750, address which referenced memory
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID: [B]X64_0xA_RTKVHD64+2e96[/B]
  BIOS Version                  3029
**************************Fri Feb 15 21:45:39.516 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\021513-53024-01.dmp]
System Uptime:[B]1 days 21:34:46.520[/B]
Probably caused by :[B]memory_corruption ( nt!MiSectionDelete+3f )[/B]
BugCheck [B]3B, {c0000005, fffff80003ba6417, fffff88009236fa0, 0}[/B]
Arguments:
Arg2: fffff80003ba6417, Address of the instruction which caused the bugcheck
Arg3: fffff88009236fa0, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
FAILURE_BUCKET_ID: [B]X64_0x3B_nt!MiSectionDelete+3f[/B]
  BIOS Version                  3029
**************************Mon Feb  4 01:06:55.639 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\020313-51246-01.dmp]
Built by: [B]7601[/B].17944.amd64fre.win7sp1_gdr.120830-0333
System Uptime:[B]1 days 6:20:05.992[/B]
*** ERROR: Module load completed but symbols could not be loaded for usbhub.sys
*** ERROR: Module load completed but symbols could not be loaded for usbccgp.sys
*** ERROR: Module load completed but symbols could not be loaded for usbaudio.sys
Probably caused by :[B]usbaudio.sys ( usbaudio+26e1 )[/B]
BugCheck [B]C5, {fffffa800d747978, 2, 1, fffff800039bd617}[/B]
Arguments:
Arg1: fffffa800d747978, memory referenced
Arg4: fffff800039bd617, address which referenced memory
PROCESS_NAME:  audiodg.exe
FAILURE_BUCKET_ID: [B]X64_0xC5_2_usbaudio+26e1[/B]
  BIOS Version                  3029
**************************Sun Jan 20 16:40:13.566 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012013-19952-01.dmp]
System Uptime:[B]1 days 2:50:49.724[/B]
Probably caused by :[B]dxgmms1.sys ( dxgmms1!VIDMM_SEGMENT::TrimAllProcesses+14e )[/B]
BugCheck [B]3B, {c0000005, fffff8800433557a, fffff8800935db70, 0}[/B]
Arguments:
Arg2: fffff8800433557a, Address of the instruction which caused the bugcheck
Arg3: fffff8800935db70, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
PROCESS_NAME:  dwm.exe
FAILURE_BUCKET_ID: [B]X64_0x3B_dxgmms1!VIDMM_SEGMENT::TrimAllProcesses+14e[/B]
  BIOS Version                  3029
[/FONT]
3rd Party Drivers:
[COLOR=RED][B]AtiPcie.sys                 Tue May  5 11:00:22 2009 (4A005486)[/B][/COLOR]
amdsata.sys                 Wed Oct  7 16:13:09 2009 (4ACCF655)
amdxata.sys                 Wed Oct  7 16:13:10 2009 (4ACCF656)
PxHlpa64.sys                Tue Oct 20 14:08:42 2009 (4ADDFCAA)
jraid.sys                   Mon Jan 11 06:28:18 2010 (4B4B0B52)
mfehidk.sys                 Wed Oct  6 15:55:49 2010 (4CACD445)
amd_sata.sys                Wed Apr 11 10:40:24 2012 (4F8597D8)
amd_xata.sys                Wed Apr 11 10:40:27 2012 (4F8597DB)
GEARAspiWDM.sys             Mon May 18 08:17:04 2009 (4A1151C0)
[COLOR=#000000]ASACPI.sys                  Wed Jul 15 23:31:29 2009 (4A5E9F11)
[/COLOR]RTKVHD64.sys                Fri Jan 29 01:48:35 2010 (4B6284C3)
amdiox64.sys                Thu Feb 18 10:17:53 2010 (4B7D5A21)
[COLOR=RED][B]nusb3hub.sys                Thu Apr 22 21:34:35 2010 (4BD0F92B)[/B][/COLOR]
[COLOR=RED][B]nusb3xhc.sys                Thu Apr 22 21:34:36 2010 (4BD0F92C)[/B][/COLOR]
fowp64.sys                  Fri Aug 13 05:20:34 2010 (4C650E62)
mfewfpk.sys                 Wed Oct  6 15:56:04 2010 (4CACD454)
mfenlfk.sys                 Wed Oct  6 15:56:13 2010 (4CACD45D)
mfeapfk.sys                 Wed Oct  6 15:56:26 2010 (4CACD46A)
mfeavfk.sys                 Wed Oct  6 15:56:49 2010 (4CACD481)
mfefirek.sys                Wed Oct  6 15:59:47 2010 (4CACD533)
cfwids.sys                  Wed Oct  6 16:00:36 2010 (4CACD564)
Rt64win7.sys                Fri Jun 10 02:33:15 2011 (4DF1BAAB)
ALSysIO64.sys               Sat Jul  9 20:27:45 2011 (4E18F201)
AtihdW76.sys                Thu Feb 23 07:30:12 2012 (4F463154)
[COLOR=RED][B]AODDriver2.sys              Tue Mar  6 04:55:00 2012 (4F55DEF4)[/B][/COLOR]
usbfilter.sys               Tue Aug 28 21:27:12 2012 (503D6FF0)
point64.sys                 Tue Sep 18 06:18:08 2012 (50584A60)
dc3d.sys                    Tue Sep 18 06:18:24 2012 (50584A70)
atikmpag.sys                Fri Nov 16 14:39:13 2012 (50A69661)
atikmdag.sys                Fri Nov 16 15:18:02 2012 (50A69F7A)
S3XXx64.sys                 Fri Dec  7 05:50:27 2012 (50C1C9F3)
lvbflt64.sys                Wed Jan 18 01:39:53 2012 (4F166939)
lvrs64.sys                  Wed Jan 18 01:40:36 2012 (4F166964)
lvuvc64.sys                 Wed Jan 18 01:41:08 2012 (4F166984)
mferkdet.sys                Wed Oct  6 15:57:05 2010 (4CACD491)
nusb3hub.sys                Thu Jan 21 22:22:18 2010 (4B5919EA)
nusb3xhc.sys                Thu Jan 21 22:22:21 2010 (4B5919ED)
[COLOR=RED][B]GRMNGEN.SYS                 Thu Apr 30 12:45:26 2009 (49F9D5A6)[/B][/COLOR]
[COLOR=RED][B]grmnusb.sys                 Thu Apr 30 12:45:27 2009 (49F9D5A7)[/B][/COLOR]
atikmpag.sys                Tue Apr 19 21:22:32 2011 (4DAE3558)
atikmdag.sys                Tue Apr 19 21:53:29 2011 (4DAE3C99)
atikmpag.sys                Wed Jul  4 01:10:55 2012 (4FF3D05F)
atikmdag.sys                Wed Jul  4 01:16:13 2012 (4FF3D19D)
S3XXx64.sys                 Thu Jun 21 06:06:44 2012 (4FE2F234)
[/FONT]
http://www.carrona.org/drivers/driver.php?id=amdsata.sys
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=PxHlpa64.sys
http://www.carrona.org/drivers/driver.php?id=jraid.sys
http://www.carrona.org/drivers/driver.php?id=mfehidk.sys
http://www.carrona.org/drivers/driver.php?id=amd_sata.sys
http://www.carrona.org/drivers/driver.php?id=amd_xata.sys
http://www.carrona.org/drivers/driver.php?id=GEARAspiWDM.sys
http://www.carrona.org/drivers/driver.php?id=ASACPI.sys
http://www.carrona.org/drivers/driver.php?id=RTKVHD64.sys
http://www.carrona.org/drivers/driver.php?id=amdiox64.sys
fowp64.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=mfewfpk.sys
http://www.carrona.org/drivers/driver.php?id=mfenlfk.sys
http://www.carrona.org/drivers/driver.php?id=mfeapfk.sys
http://www.carrona.org/drivers/driver.php?id=mfeavfk.sys
http://www.carrona.org/drivers/driver.php?id=mfefirek.sys
http://www.carrona.org/drivers/driver.php?id=cfwids.sys
http://www.carrona.org/drivers/driver.php?id=Rt64win7.sys
http://www.carrona.org/drivers/driver.php?id=ALSysIO64.sys
http://www.carrona.org/drivers/driver.php?id=AtihdW76.sys
http://www.carrona.org/drivers/driver.php?id=AODDriver2.sys
http://www.carrona.org/drivers/driver.php?id=usbfilter.sys
http://www.carrona.org/drivers/driver.php?id=point64.sys
http://www.carrona.org/drivers/driver.php?id=dc3d.sys
http://www.carrona.org/drivers/driver.php?id=atikmpag.sys
http://www.carrona.org/drivers/driver.php?id=atikmdag.sys
http://www.carrona.org/drivers/driver.php?id=S3XXx64.sys
http://www.carrona.org/drivers/driver.php?id=lvbflt64.sys
http://www.carrona.org/drivers/driver.php?id=lvrs64.sys
http://www.carrona.org/drivers/driver.php?id=lvuvc64.sys
http://www.carrona.org/drivers/driver.php?id=mferkdet.sys
Top Bottom
