- Thread Author
- #1
Hi all. I have installed Windows 10 with very few problems (other than the learning curve), however, the free space on the hard drive is now 20GB smaller than before the upgrade from Windows 8.1.
Poking around, I discovered that there is what appears to be a "backup" folder of 20GB within the windows folder. Is this normal, and what happens if I remove that folder?
Snowflake24694
Member
- Joined
- Aug 7, 2015
- Messages
- 56
Yes, it's normal. If you type 'storage' into your Search you will find exactly how much space on the disk each program hold. At the end of the list you will see 'Temporary files'. When you click on it you will see that 20GB is a backup of the previous version of your Windows OS (Windows 8.1) and it says you can delete it right away or it will be deleted in a month. It's there just in case if you change your mind and want to go back to your previous OS.
- Joined
- May 22, 2012
- Messages
- 4,466
- Thread Author
- #5
Besides your image backup stays available for much longer (until you delete it) than the 30 day restore option the W10 update provides.That is what I thought, and thanks for the response. I think I may do a backup image "just in case".
Similar threads
- Replies
- 0
- Views
- 91
- Replies
- 0
- Views
- 425
- Replies
- 0
- Views
- 638
- Replies
- 0
- Views
- 170
