mazielinski07
- Joined
- Jun 22, 2009
- Messages
- 6
- Thread Author
- #1
I've been using Windows 7 for about 3 weeks now on a new computer that I put together. For some reason, in the last week I've encountered a major issue. When using explorer on the internet, seemingly at random, I will receive a message near the top of the browser that says, "Your current security settings put your computer at risk. Click here to change your setting..." and then not only do I have problems making the browser work in different ways, but if I try to open regular file folders on the computer, I am unable to do so. I have McAfee anti-virus and Malwarebytes to prevent virus issues and according to the programs, the computer is clean.
In order to make the computer work regularly again, I must restart it and even then it sometimes requires 2-3 restarts. I have also noticed that when it does happen, I also note that physical memory usage starts at that time (after hitting ctrl+alt+del) but there was never any prior use of physical memory prior to this.
If anyone knows what's going on or how to fix it, I would greatly appreciate the help!
Thanks!
M
Thanks!
M
