Computergandalf2014
- Joined
- Feb 1, 2014
Hi!
I have tryed everything now, i cant get rid of this problem since i installet windows 7 on my new samsung SSD.
My last system was windows xp on the same Hardware (exept the samsung ssd) an i never had so massive problems with BSOD.
The BSOD only happens , if i start up my pc after it was powerd off for a longer time. If i do so, the BSOD comes just bevore the Windows login comes.
i made it to let the pc create a minidump file and i debugget it.
Please can anyon halp me with reading this file:
Microsoft (R) Windows Debugger Version 6.2.9200.20512 AMD64
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Summary Dump File: Only kernel address space is available
Symbol search path is: srv*c:\symbols* http://msdl.microsoft.com/download/symbols;Set _NT_SYMBOL_PATH = symsrv*symsrv.dll*f:\localsymbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: 7601.18247.amd64fre.win7sp1_gdr.130828-1532
Machine Name:
Kernel base = 0xfffff800`02a5b000 PsLoadedModuleList = 0xfffff800`02c9e6d0
Debug session time: Sat Feb 1 11:58:12.062 2014 (UTC + 1:00)
System Uptime: 0 days 0:00:28.359
Loading Kernel Symbols
Loading User Symbols
* Bugcheck Analysis *
BugCheck 7E, {ffffffffc0000005, fffff80002af6150, fffff880031b4f38, fffff880031b4790}
*** ERROR: Module load completed but symbols could not be loaded for atikmpag.sys
Probably caused by : atikmpag.sys ( atikmpag+2bf03 )
Followup: MachineOwner
0: kd> !analyze -v
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED (7e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff80002af6150, The address that the exception occurred at
Arg3: fffff880031b4f38, Exception Record Address
Arg4: fffff880031b4790, Context Record Address
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - Die Anweisung in 0x%08lx verweist auf Speicher 0x%08lx. Der Vorgang %s konnte nicht im Speicher durchgef hrt werden.
FAULTING_IP:
nt!MiReplenishPageSlist+c0
fffff800`02af6150 f00fba6b1000 lock bts dword ptr [rbx+10h],0
EXCEPTION_RECORD: fffff880031b4f38 -- (.exr 0xfffff880031b4f38)
ExceptionAddress: fffff80002af6150 (nt!MiReplenishPageSlist+0x00000000000000c0)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
CONTEXT: fffff880031b4790 -- (.cxr 0xfffff880031b4790)
rax=fffffa8005b96080 rbx=fffef28112c21800 rcx=0000058000000000
rdx=0000000000000047 rsi=0000000000000002 rdi=0000000000000005
rip=fffff80002af6150 rsp=fffff880031b5170 rbp=fffffa8005b99080
r8=fffff80002d0b500 r9=fffffa8006900000 r10=fffffa8006900de0
r11=fffff80002c4be80 r12=fffff80002d0b500 r13=2aaaaaaaaaaaaaab
r14=fdffffffffffffff r15=0000058000000000
iopl=0 nv up ei pl nz na pe nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010202
nt!MiReplenishPageSlist+0xc0:
fffff800`02af6150 f00fba6b1000 lock bts dword ptr [rbx+10h],0 ds:002b:fffef281`12c21810=????????
Resetting default scope
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: 2
ERROR_CODE: (NTSTATUS) 0xc0000005 - Die Anweisung in 0x%08lx verweist auf Speicher 0x%08lx. Der Vorgang %s konnte nicht im Speicher durchgef hrt werden.
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: ffffffffffffffff
READ_ADDRESS: ffffffffffffffff
FOLLOWUP_IP:
atikmpag+2bf03
fffff880`0182bf03 33d2 xor edx,edx
BUGCHECK_STR: 0x7E
LOCK_ADDRESS: fffff80002cd4be0 -- (!locks fffff80002cd4be0)
Resource @ nt!PiEngineLock (0xfffff80002cd4be0) Exclusively owned
Threads: fffffa8006a48040-01<*>
1 total locks, 1 locks currently held
PNP_TRIAGE:
Lock address : 0xfffff80002cd4be0
Thread Count : 1
Thread address: 0xfffffa8006a48040
Thread wait : 0x717
LAST_CONTROL_TRANSFER: from fffff80002e412b4 to fffff80002ad0bc0
STACK_TEXT:
fffff880`031b5170 fffff800`02af490f : fffffa80`06900dc0 00000000`00000058 fffffa80`05ba8080 00000000`00000058 : nt!MiReplenishPageSlist+0xc0
fffff880`031b51e0 fffff800`02a904c0 : fa80071b`db6004c0 00000000`00000000 00000000`000000b0 00000000`00000000 : nt!MiRemoveAnyPage+0x24f
fffff880`031b5300 fffff800`02e96f6f : fffffa80`077f4010 fffffa80`00000000 fffffa80`06a48040 fffff8a0`005f2400 : nt!MiPfPutPagesInTransition+0x7c7
fffff880`031b5470 fffff800`02eac093 : fffff8a0`005f2400 00000000`00000000 fffffa80`077f4010 fffff880`031b5878 : nt!MiPrefetchControlArea+0x6f
fffff880`031b54c0 fffff800`02eac40c : ffffffff`80000074 fffffa80`08000000 00000000`00140000 ffffffff`8000006c : nt!MmCheckSystemImage+0xe3
fffff880`031b55f0 fffff800`02eac627 : ffffffff`80000074 fffff800`00000001 00000000`00000000 00000000`00000000 : nt!MiCreateSectionForDriver+0xcc
fffff880`031b56a0 fffff800`02eb820d : 00000000`00000000 00000000`00000000 fffffa80`06a48040 00000000`00000000 : nt!MiObtainSectionForDriver+0xd7
fffff880`031b5700 fffff800`02ebaead : fffff880`031b5878 00000000`00000000 00000000`00000000 00000000`00000000 : nt!MmLoadSystemImage+0x23d
fffff880`031b5820 fffff800`02ebb865 : fffff800`024040c4 00000000`00000000 fffff880`0183583c fffffa80`06a48040 : nt!IopLoadDriver+0x44d
fffff880`031b5af0 fffff800`02f4f70b : 00000000`00000000 ffffffff`800000fc 00000000`00000000 fffff8a0`005e0a70 : nt!IopLoadUnloadDriver+0x55
fffff880`031b5b30 fffff800`02acfe53 : fffffa80`06a48040 00000000`0000000a fffff880`031b5bf0 fffff880`031b5bf0 : nt!NtLoadDriver+0x189
fffff880`031b5be0 fffff800`02acc410 : fffff880`0182bf03 00000000`000000fc fffffa80`06a39040 fffff8a0`00001a50 : nt!KiSystemServiceCopyEnd+0x13
fffff880`031b5d78 fffff880`0182bf03 : 00000000`000000fc fffffa80`06a39040 fffff8a0`00001a50 00000000`000000fc : nt!KiServiceLinkage
fffff880`031b5d80 fffff880`0182c085 : fffffa80`077d7e70 fffff880`031b5ee0 fffff800`02c4be80 fffffa80`077e0000 : atikmpag+0x2bf03
fffff880`031b5de0 fffff880`018594e4 : fffffa80`077d7e70 fffffa80`077e0000 fffffa80`077e0000 ffffffff`800000fc : atikmpag+0x2c085
fffff880`031b5fb0 fffff800`02ebb467 : fffffa80`077d7e70 00000000`0000000d 00000000`00000000 00000000`000007ff : atikmpag+0x594e4
fffff880`031b6280 fffff800`02f4f190 : 00000000`00000001 00000000`00000000 fffff880`031b6828 ffffffff`80000108 : nt!IopLoadDriver+0xa07
fffff880`031b6550 fffff800`02d8b76e : 00000000`00000001 00000000`00000000 fffff8a0`005c97d0 00000000`00000000 : nt!PipCallDriverAddDeviceQueryRoutine+0x390
fffff880`031b6650 fffff800`02d8b47e : ffffffff`80000118 00000000`00000000 fffff880`031b6860 fffff880`031b6828 : nt!RtlpCallQueryRegistryRoutine+0x106
fffff880`031b66d0 fffff800`02ebe73c : fffffa80`06a0f6e0 00000000`00000000 00000000`c0000034 fffff880`031b6828 : nt!RtlQueryRegistryValues+0x17e
fffff880`031b67a0 fffff800`02ebfed2 : fffffa80`06a00310 fffffa80`06a0f6e0 00000000`00000002 fffff8a0`0000004c : nt!PipCallDriverAddDevice+0x45c
fffff880`031b6950 fffff800`02ec036c : fffff800`02cd2500 00000000`00000000 00000000`00000000 00000000`00000000 : nt!PipProcessDevNodeTree+0x2b2
fffff880`031b6bc0 fffff800`02bd3802 : 00000001`00000003 00000000`00000000 00000000`32706e50 00000000`00000084 : nt!PiProcessStartSystemDevices+0x7c
fffff880`031b6c10 fffff800`02ada261 : fffff800`02bd3500 fffff800`02dc7101 fffffa80`06a48000 00000000`00000000 : nt!PnpDeviceActionWorker+0x302
fffff880`031b6cb0 fffff800`02d6d2ea : 00000000`00000000 fffffa80`06a48040 00000000`00000080 fffffa80`06a39040 : nt!ExpWorkerThread+0x111
fffff880`031b6d40 fffff800`02ac18e6 : fffff880`02f64180 fffffa80`06a48040 fffff880`02f6efc0 00000000`00000000 : nt!PspSystemThreadStartup+0x5a
fffff880`031b6d80 00000000`00000000 : fffff880`031b7000 fffff880`031b1000 fffff880`031b3d80 00000000`00000000 : nt!KxStartSystemThread+0x16
SYMBOL_STACK_INDEX: d
SYMBOL_NAME: atikmpag+2bf03
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: atikmpag
IMAGE_NAME: atikmpag.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 517f30ef
STACK_COMMAND: .cxr 0xfffff880031b4790 ; kb
FAILURE_BUCKET_ID: X64_0x7E_atikmpag+2bf03
0: kd> !analyze -v
Arguments:
Debugging Details:
FAULTING_IP:
NumberParameters: 2
CURRENT_IRQL: 2
FOLLOWUP_IP:
atikmpag+2bf03
BUGCHECK_STR: 0x7E
PNP_TRIAGE:
Thread Count : 1
Thread wait : 0x717
STACK_TEXT:
Do i have to throu my Graphiccard out of the window and drive over it?
But why does it work with windows XP?
I dont really think its a Graphiccard hardware issue but i dont have a2nd one to test it. (not now)
Machine Name:
0: kd> !analyze -v
Arguments:
Debugging Details:
FAULTING_IP:
NumberParameters: 2
CURRENT_IRQL: 2
FOLLOWUP_IP:
atikmpag+2bf03
BUGCHECK_STR: 0x7E
PNP_TRIAGE:
Thread Count : 1
Thread wait : 0x717
STACK_TEXT:
0: kd> !analyze -v
Arguments:
Debugging Details:
FAULTING_IP:
NumberParameters: 2
CURRENT_IRQL: 2
FOLLOWUP_IP:
atikmpag+2bf03
BUGCHECK_STR: 0x7E
PNP_TRIAGE:
Thread Count : 1
Thread wait : 0x717
STACK_TEXT:
