In the ever-evolving world of technology, choosing the right device can be a daunting task. Among the standout options in the 2-in-1 laptop market are Microsoft's Surface Pro series, especially the recently released Surface Pro 8 (model 8PV-00029) alongside the earlier Surface Pro 6 (model KJU-00015). Both devices carry significant features that cater to professionals and casual users alike. This article seeks to compare these two models in detail, focusing on performance specifications, design, usability, and overall value for money.
Two sleek tablets with detachable keyboards displayed on a white surface.
Overview of Specifications​
Before diving into the intricacies of each device, let’s first summarize the key specifications of both the Surface Pro 8 and Surface Pro 6.
Surface Pro 8 (8PV-00029)​
  • Processor: Intel Core i7 11th Gen (1185G7)
  • RAM: 16GB LPDDR4X
  • Storage: 256GB SSD
  • Display: 13 inches, 2880 x 1920 pixels resolution, LED-backlit touchscreen
  • Graphics: Intel Iris Xe Graphics
  • Battery: Li-Ion battery with 3 cells
  • Weight: 2.6 kg
  • OS: Windows 11
  • Price: Approximately ₹1,48,994
Surface Pro 6 (KJU-00015)​
  • Processor: Intel Core i7 8th Gen (8650U)
  • RAM: 8GB DDR4
  • Display: 12.3 inches, 1920 x 1080 pixels resolution, LED-backlit touchscreen
  • Graphics: Intel UHD Graphics 620
  • Weight: 1 kg
  • OS: Windows 10 Home Basic
  • Price: Approximately ₹1,27,990
Performance Analysis​
Central Processing Unit (CPU)​
The Soul of any computing device revolves around its processor. In this aspect, the Surface Pro 8 leaps forward with its 11th generation Intel Core i7 processor (1185G7), featuring a base clock speed of 2.5 GHz, overshadowing the 8th generation Intel Core i7 (8650U) in the Surface Pro 6, which boasts a base clock of 1.9 GHz. The architectural advancements in the 11th Generation chipset not only enhance processing power but also introduce improvements in multitasking. The increased RAM in the Surface Pro 8 (16GB vs. 8GB in Pro 6) allows it to handle intensive applications more efficiently, making it ideal for graphic-intensive tasks like video editing or high-level photography.
Graphics Performance​
The graphics capability is critical especially for users who engage in gaming or graphic design. The Surface Pro 8 incorporates Intel Iris Xe graphics, renowned for its superior performance over the UHD 620 featured in the Surface Pro 6. When tasked with handling 3D graphics and high-definition media, users will notice smoother performance in the newer model, making it a better fit for creative professionals.
Memory (RAM) and Storage​
When comparing memory capabilities, the Surface Pro 8 leads with 16GB RAM, significantly higher than the 8GB RAM in the Surface Pro 6. The increase in RAM is noteworthy for those who multitask heavily, as is often the case when juggling multiple applications. In terms of storage, both devices feature 256GB SSD, allowing for quick data access and boot times, although the performance might not vary significantly in this aspect as both utilize the same SSD type.
Display Features​
Display quality plays a vital role in user satisfaction and usability.
Surface Pro 8​
  • Screen Size: 13 inches
  • Resolution: 2880 x 1920 pixels
  • Type: LED-backlit touchscreen
Surface Pro 6​
  • Screen Size: 12.3 inches
  • Resolution: 1920 x 1080 pixels
  • Type: LED-backlit touchscreen The Surface Pro 8 offers a larger and significantly sharper display, ideal for media consumption, design work, or simply for a more immersive experience, thanks to its high pixel density.
Battery Life​
Battery performance is essential for users who rely on mobility. Both devices house a three-cell Li-Ion battery, yet the longevity may differ based on usage patterns and device optimization. The Surface Pro 8 is expected to deliver superior longevity owing to its efficiency in processor and possible advancements in battery technology.
Build and Design​
The physical design is another area where Microsoft's Surface Pro series excels.
Surface Pro 8​
  • Weight: 2.6 kg
  • Thickness: 0.91 cm
  • Material: Premium sleeker design with a detachable keyboard and adjustable kickstand.
Surface Pro 6​
  • Weight: 1 kg
  • Thickness: 8.5 mm
  • Material: More compact, yet robust enough for daily use. The Surface Pro 6 presents itself as a lightweight alternative, making it more portable than the Surface Pro 8. However, the latter's versatility with a detachable keyboard can turn it into a powerful laptop alternative.
Operating System​
Out of the box, the Surface Pro 8 comes pre-installed with Windows 11, which introduces several new features including enhanced performance, and improved gaming capabilities with DirectStorage technology. In contrast, the Surface Pro 6 ships with Windows 10 Home Basic. The upgrade to Windows 11 makes the Surface Pro 8 a more future-proof option, as it will receive longer software support and updates.
When choosing between the Microsoft Surface Pro 8 (8PV-00029) and Surface Pro 6 (KJU-00015), prospective buyers must weigh their priorities.
Key Considerations:​
