My Laptop had been screwed up.. needs help
ZeraX
Hi everybody
recently my laptop acting very weird.
1- GTA Vice City, the game i play from 2003 till now, suddenly won't run for the first time ever in my life.
i did uninstalled it completely and re-install, still won't run.
2- when i run Vice city and getting a "not responding" the cursor shows the time glass indefinitely, and i found that there's a "rundll32.dll" process invading the windows task manager invading the processes tab, there's was 12 or so of it.
i realized there's a virus, i run AVAST free AV (found a keylogger), run Anti-Malware (found none)
run a HouseCall (found none), bitdefender online scanner found none too.
i even went to kaspersky online file scanner selected rundll32.dll from system32 folder and they reported no infected file.
3- i have a NFS Underground 2 game, in my laptop i CAN'T host nor join a game, i just copy/paste it from my laptop to my friend's laptop, so we play it over wire-less lan,
he was able to do both, but me no.
note that we both have TOSHIBA laptops.
i even turned off the firewall and avast , not no result.
i planned to format it, but i will lost all the programs that came with TOSHIBA, and if i did a recovery everything well be lost, even i made a 2nd partition, the recovery will delete it..
so is there any idea how to fix all of these ???
thank you in advance
Windows 7 Ultimate (upgraded from Home Premium) 64-bit
4 GB DDR3 Ram
ATI Mobility HD Radeon 4200
ZeraX
i used it it didn't find anything...
all the scanners didn't find anything even the online ones.
