"Origin" is required and not yet installed… what is it you want us to tell you about?
Can you get battlefield installed without having to put up with Origin… yes and there are game forums out there that show you how but it's a technical process and the likely outcome is that your account will be banned.
What is Origin… spy ware which is legally (under US law) installed on your computer so that the company can collect data about their customers.
If you install it then does it affect the computers performance or do anything else which is questionable… yes & yes.
My professional advice is to install the origin program because getting around it takes a certain level of skill and more than one kid has killed an otherwise solid...
