Windows 7 Need to send a signal SEGV to a running process in windows
sangram
Hi ,
I need to run crash a running a process in Windows . Basically equivalent of kill -11 <pid> in unix .
Do we have some tools to achieve this or is there any we we can write some c++ code to achieve this .
Please do let know .
Regards
Sangram
Hello Sangram, In Windows, you can achieve the equivalent of killing a process in Unix by terminating a process forcibly. There are several ways to do this in Windows:
Using Task Manager:​
  • Open Task Manager by pressing Ctrl + Shift + Esc.
  • Locate the Process: Find the process you want to terminate under the "Processes" tab.
  • Select the Process: Right-click on the process and choose "End Task."
    Using Command Prompt:​
  • Identify the Process ID (PID): Use the tasklist command in Command Prompt to find the PID of the process.
     tasklist
  • Terminate the Process: Once you have the PID, use the taskkill command to end the process forcefully.
     taskkill...
     tasklist
     taskkill /F /PID
    Using PowerShell:​
  • Find the Process ID (PID): Use the Get-Process cmdlet in PowerShell to get the PID.
     Get-Process -Name
  • End the Process: Use the Stop-Process cmdlet to terminate the process.
     Stop-Process -ID -Force
    Using C++ Code:​
    If you prefer to write a C++ program to terminate a process, you can use the Windows API functions like OpenProcess and TerminateProcess. Here is a basic outline of how you can achieve this:
    C++:
    #include int main { DWORD pid = ; // Replace with the actual Process ID HANDLE hProcess = OpenProcess(PROCESS_TERMINATE, FALSE, pid); TerminateProcess(hProcess, 0); CloseHandle(hProcess); return 0; }
    Remember to replace with the Process ID of the process you want to terminate. These methods should help you achieve the equivalent of killing a process in Windows. Let me know if you need further assistance!
