Windows 7 Trouble with NetGear WPN111 Adapter on Windows 7: Missing DNIN50.dll Error
wt.pm
I am running a netgear wireless setup, with a WPN111 adapter on the Windows 7 machine, I installed the software from netgear, but when I try to run the program, I get an error msg saying "DNIN50.dll is missing from your computer, please reinstall the program." I have reinstalled twice and keep getting the message, I have even downloaded the update from NetGear, no luck. It has to be that the software is not compatible with 7. Any idea what I can do? I can access the internet, but not my other pc (which I need to).
I have tried dragging a shortcut to the other machine from my XP partition, with no luck. Which if I boot to XP, I can still access the other machine, which is also XP. Or if there is any other way to access the machine, I'll be happy.
It seems like you are encountering compatibility issues with the NetGear software on your Windows 7 machine. Here are a few steps you can take to potentially resolve this issue and access your other XP machine:
Resolving the "DNIN50.dll is Missing" Error:​
  1. Check Compatibility Mode:
    • Right-click on the program shortcut or .exe file.
    • Go to Properties > Compatibility tab.
    • Check the box "Run this program in compatibility mode for:" and select Windows XP from the dropdown.
    • Apply the changes and try running the program again.
    []Manually Register DLL File:
    • If the DLL file is present on your system, you can try registering it manually.
      • Press Win + R, type cmd, and...
      • Press Win + R, type cmd, and press Enter to open the Command Prompt.
      • Type regsvr32 C:\path\to\DNIN50.dll and press Enter to register the DLL file.
        Accessing Your XP Machine from Windows 7:​
    ]Network Sharing:
    • Ensure both machines are on the same network and have sharing enabled.
    • Check the network discovery settings on Windows 7 and ensure file and printer sharing is turned on.
    []Mapping Network Drive:
    • You can map a network drive to access files on the XP machine.
      • Right-click on "Computer" or "This PC" and select "Map network drive."
      • Enter the XP machine's IP address or hostname and specify the shared folder.
    ]Remote Desktop Connection:
    • You can use Remote Desktop to access the XP machine from Windows 7 if Remote Desktop is enabled on the XP machine. By following these steps, you should be able to mitigate the software compatibility issue and access your other XP machine from your Windows 7 system. Let me know if you need further assistance with any of these steps!
