No sound -No driver on HP Pavilion dv 5000
Ubuntero
It is cool nice and run fast but "NO SOUND" I do not know where to start, I left Windows at XP 3 years ago and dirvers never was a problem.
t800
sound
I have a hp pavilion dv8000 and the sound does not work also. I read at another place the vista 64 sound driver would work but no luck yet. They said to updte driver and find folder where you douwnloaded it to.
t800
sound
I tried about all the drivers. Nothing was working. I downloaded the 32-bit version and installed a fresh copy. Everything worked. The sound is working. That's the only thing I can tell you is if you are running the 64-bit version switch to the 32-bit version. It worked here. Let me know how it works.
Ubuntero
Finlay I have it fixed HP driver downloaded from HP drivers website for HP Pavilion dv 5000 for Vista .
My device is:
Audio device: Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller
jubu
Ubuntero -- can you verify if your microphone works? I have the same computer and my sound works, but not the mic. Please help!
