[No Sound- workaround solution] After Win10 OEM69.inf update
MorrisLu
*Pls Microsoft update STOP to destroy the sound function of ASUS Laptop w/ Realtek ALC 256
Hi All,
#No sound #OEM69.inf #Update #Win10
here comes a workaround solution to restore the sound function if you pc laptop no sound after windows updates
Can someone tell MS update to stop this update, thanks millions
[Investigation]
No sound check sound mixer >> OMG
Check Screenshot-1
An image from '[No Sound- workaround solution] After Win10 OEM69.inf update'. Steps showing how to fix sound issues by uninstalling the OEM69.inf driver on Windows.
[Workaroud solution]
Uninstall OEM69.inf
Check ScreenShot-2,3,4
It seems like you have encountered a common issue where Windows updates affect the sound functionality on ASUS laptops with Realtek ALC 256 audio drivers. The workaround solution you provided involves uninstalling the OEM69.inf driver to restore sound functionality. Here are some additional steps and information you may find helpful: 1. Driver Compatibility: Windows updates can sometimes cause conflicts with existing drivers, leading to issues like loss of sound. It's essential to ensure that the drivers installed on your system are compatible with the Windows version you are using. 2. Rollback Feature: In cases where a specific driver update is causing issues, you can use the Device Manager to roll back to the previous...
It seems like you have encountered a common issue where Windows updates affect the sound functionality on ASUS laptops with Realtek ALC 256 audio drivers. The workaround solution you provided involves uninstalling the OEM69.inf driver to restore sound functionality. Here are some additional steps and information you may find helpful: 1. Driver Compatibility: Windows updates can sometimes cause conflicts with existing drivers, leading to issues like loss of sound. It's essential to ensure that the drivers installed on your system are compatible with the Windows version you are using. 2. Rollback Feature: In cases where a specific driver update is causing issues, you can use the Device Manager to roll back to the previous driver version. This can help restore sound functionality while avoiding problematic updates. 3. Driver Updates: Check the ASUS support website for updated Realtek audio drivers that are compatible with your laptop and Windows version. Installing the latest drivers can often resolve sound-related issues caused by outdated or incompatible drivers. 4. System Restore: If you are unable to resolve the issue through driver updates or rollbacks, you can consider using System Restore to revert your system to a previous point before the Windows update that caused the sound problem. 5. Feedback to Microsoft: If this issue persists despite your efforts, providing feedback to Microsoft through the Windows feedback hub can help highlight the issue and potentially lead to a resolution in future updates. 6. Community Forums: Engaging in ASUS or Microsoft community forums can also provide insights from other users facing similar issues and offer additional solutions to restore sound functionality on your ASUS laptop. It's recommended to regularly check for driver updates and monitor Windows updates for any known issues that may impact your system's functionality. Following these steps can help address sound issues caused by Windows updates and ensure a smoother experience on your ASUS laptop.
