Rasheed Saeed
- Joined
- May 14, 2011
- Messages
- 6
- Thread Author
- #1
Well out of the blue my computer started to crash and stuff so I turned it off. I switch it back and it can pick up my OS(Vista) for some unknown reason. Is there a way(I don't know if it's possible) for my computer to pick up windows again?
ERROR:
Intel UNDI, PXE-2.1 (build 082)
Copyirght (C) 1997-2000 Intel Coropration
For realtel RTL8101E/8102E PCI-E Ethernet Conroller v1.07 (080320)
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting PXE ROM.
No BOOTABLE DEVICE - INSERT boot disk and press any key
I got an XP disk but that doesn't seem to work, errors when window is about to start. As for the Vista disk nothing came with the comp.
Thanks.
ERROR:
Thanks.
