scottmeister
First off, Hi everyone!
I was lucky (?) enough to get a win7 party pack but so far have had nothing but network issues. I have completely given up on wireless - its hopeless. Driver support from belkin is pretty lame.
My issue now is that i am trying to connect my original (NOT 360) xbox to my PC via cable. Simple and straight forward enough? I thought so too. Not the case.
Obviously i use a program like flash fxp to transfer files across which was all good in both vista and xp, but now whenever i connect the cable in win7, i get the "Unidentified Network" and connection through flashfxp times out.
Like i said, I am NOT trying to connect to the internet (i have just spent £140 on getting a new line hardwired for that), just trying to connect my old xbox to my pc to transfer some music & movies over.
I have tried using both static and DHCP, and i'm currently on static.
I have tried changing the network type from public to home and then to work. - no dice.
I have tried disabling Homegroup as i have read on some forums. - no dice
I have tried 'Diagnosing' the connection many many times wiht no success.
I have the newest drivers for my motherboard. - ASUS P5Q-E
I have done clear a CMOS.
I'm not exactly an expert with computers but i know a bit and have been at this for days and read gods knows how many different forum posts, but nearly all refer to internet issues, whereas i've given up on the wireless network.
I just want to transfer my music and movies to and from my xbox.
Can anyone gives this tired mind some fresh ideas?
Thanks for reading/posting.
It seems like you are facing difficulties connecting your original Xbox to your PC running Windows 7 via a cable for file transfers. Here are some steps and suggestions you can try to resolve this issue:
Troubleshooting Steps:​
  1. Check Cable and Ports:
    • Ensure that the cable you are using to connect the Xbox to your PC is in good condition and properly inserted into both devices.
    • Try using different Ethernet cables to rule out any cable issues.
    []Network Settings:
    • Verify that you are using the correct network settings on both the PC and Xbox.
    • For a direct connection between the Xbox and PC without internet access, a crossover Ethernet cable might be needed. Most modern devices can...
    []Network Settings:
    • For a direct connection between the Xbox and PC without internet access, a crossover Ethernet cable might be needed. Most modern devices can auto-sense this, but if not, try using a crossover cable.
    ]Windows Settings:
    • Disable any firewall or security software temporarily to check if they are blocking the connection.
    • Ensure that the network discovery and file sharing settings are correctly configured on your Windows 7 PC.
    []Network Adapter Properties:
    • Check the properties of the network adapter on your PC.
    • Make sure that the network adapter settings are appropriate for a direct connection.
    ]Network Sharing:
    • Enable network sharing and ensure that the Xbox and PC are on the same workgroup or homegroup.
    []Device Manager:
    • Check the Device Manager on your PC to ensure there are no exclamation marks or errors related to the network adapter.
    ]Xbox Configuration:
    • Confirm that the network settings on your Xbox are correct.
    • Try restarting the Xbox to see if that resolves any connectivity issues.
      Additional Tips:​
      • Network Troubleshooter: Use the built-in Windows network troubleshooter to diagnose and possibly fix any connection problems.
      • Driver Update: Double-check for any updated network adapter drivers and install them if available.
      • Alternative Software: If FlashFXP is causing issues, you can try alternative FTP software like FileZilla for file transfers.
      • Ethernet Adapter Configuration: Make sure both devices are set to use DHCP or static IP addresses within the same subnet.
      By following these steps and suggestions, you should be able to establish a successful connection between your Xbox and PC for file transfers. If you encounter any specific error messages or issues during these steps, feel free to provide more details for further assistance. Good luck!
