Windows 8 One of my Hard Drive went missing.
amirzubair
Active Member
Hi there guys. I have Asus G750js laptop. Today when i started my laptop everything was fine. Then after sometime i restarted my laptop my second HD is not showing anymore take a look
When i select MBR error appears
The disk is not being displayed in Bios also.
Is there any hope to bring it back? Thanks
Guessing it's a usb SATA drive (either mechanical or SSD). I'd download SEATOOLS from Seagate.com and run both short and long tests on it. If SEATOOLS reports any errors or can't read the drive, it must be replaced as ussnorway suggested.
It would also be helpful to know the exact make/model of the missing drive.
<<<BIGBEARJEDI>>>
<<<BIGBEARJEDI>>>
Thanks for letting us know mate... happy it worked out for you with Asus stepping up.
p.s. We keep drumming it in but get some good backup software BEFORE the shit happens again.
