Windows 7 Partitioning Drive for Optimum Performance
Mat
1. if i put my page file swap file temp folder on its own partition, is it best to use fat32? if i remember right fat 32 is fastest just isnt the best for space usage.
2. does reinstalling windows after time (1-2 years) create better performance? im not sure what it is but windows xp and under always seemed to slow down after years (even with proper maintenance)
3. if i create one partition for windows and one for EVERYTHING else, can i reinstall windows and when i boot up everything will be exactly the same? (considering i dont format the partition during windows setup) ?
thanks so much everyone.
heres my other post on this if you're curious
sevenforums [dot com] /performance-maintenance/63015-partitioning-drive-optimum-performance-2.html#post575431
by the way im on windows 7 now (probably keeping it, idk). just because this might be an issue i heard trying to use fat32 with it (so PLEASE if u answer any/all of these questions, post whether or not u know if this is a problem due to windows 7. i really dont want to mess up my machine.)
