aboka
Well-Known Member
hi, i cant make port forward working for a program. it needs port 31400-31409 for it to work. i hv done the thing below, but the program is not working. i try check if the port is open with online 'port open checking' but it say port is not open. here is what i hv done
-set fix ip for the pc to 192.168.1.188
-add port forward in router
-disable firewall
-check that im using a public ip from the isp(180.74.x.x)
im running Windows 10 Pro and using the isp default router - Fiberhome SR120-A. hv run out of ideas, pls advice. thank you,
p/s- the second port 80 is added afterward. i setup IIS and try if thats working, but same, its not open.... i hv check IIS is working as it could be connect from another pc in the LAN with its local ip:80
