Marios1441
I have Cyta DSL model and want to connect to it a HP Deskjet 4676 printer fax. How should i do it and how to connect the cables and what cables i must put to the wall plug? to have fax send from computer and printer
itself? Explain me in details.
The printer would be an analog connection. If the DSL modem has a RJ-11 connector and supports analog fax conversions then all you should need to do is plug it in. There may also be additional configuration on the modem such as a fax service. Otherwise you will need a separate analog phone line and plug the fax into that.
Please provide more details about your DSL modem. Is it this Modem or a different one?
Do you want to use your HP Deskjet both as a printer and fax or just as printer? As far as I can see it is a wireless printer. If you don't want to use it as a fax then you just connect it to your computer via WiFi. If you need to use the fax then take a look at this. You should also watch this video (the setup is almost the same with every fax machine).
