- Thread Author
- #1
Ok I got a problem but can;t figure out, I used 2 different headphones from 2 different brands and the problem remained.
The problem is when I speak via skype the other end hears what I hear.
I already set it to independant and to redirected and nothing worked (the headphones are connected via front pannel).
I attatched the pic of my current configurations.
U can see the speaker is configured as default but that;s only because it is currently set to redirected headphones.
Configuring in skype to work through headphones didn;t solve the problem...
The problem was solved though , by configuring the headphones as independant, and plugging the mic on the back pannel, and another headphones in the front ...
BUT then when I set skype to work via headphoens the sound was as if coming from the bathroom....
And it's not just a skype thing I tired it on music, all sounds sounded like that.
I dunno what to do anymore -.-;
Tried playing with the mic boost, no use.
For some reason my friend can hear what I 'hear' perfectly, EVEN when I am on really low sound....
Not sure about when I am on mute....I think it happens then too.
