itguy9103
I've installed twice and have the same issue. I can navigate to many pages using IE, but cannot connect to sites such as the default home page, google, or even myspace...just to name a few. Any help would be great :confused: also cannot navigate away from microsoft.com I DO have connectivity and can navigate to some sites, but most are unreachable.
I had the same problem and I found out it was a problem with the vista drivers for my gigabit network card. If you're having these problems and you have a Marvel Yukon Gigabit ethernet controller you need to download the drivers directly from the Marvell site as the drivers vista installs don't work.
just go here:
Marvell: Consumer Driver Search
and run a search based on the platform you're using. should solve your problems if you have a gigabit ethernet controller
Let me know how it goes
I fixed the internet connection problem by uninstalling and reinstalling the network adapter, now I'm back to the original problem. I can only go to a few websites like yahoo and even then none of the links work.
I fixed mine with these instructions.
Click on Start orb
Right-click on Computer
Click on Manage
Click Continue
Select Device Manager on the left
Expand Network adapters on the right
Right-click the network adapter
Click on Properties
Click on Advanced
Select TCP Checksum Offload (IPv4) on the left
Set value to Disabled
Click OK, and clock the Device Manager
just go here:
the driver install worked. I thought Vista had the latest drivers but apparently not...the easiest solution, in this case, was the correct solution. Thanks :)
glad i could help. It's little bugs like this that stop people from giving vista a good workout.
