Windows 10 Problems after installing 20H2
mjw72652
I just installed 20H2 with an in-place upgrade plus the latest updates on 2 HP laptops (different models). I have had no problems with the 15bs234wm, but I have several on the 15da0053wm. It has a 1 TB WD PCIe/NVMe which I installed just after completing the upgrade/updates, which I cloned from the existing 1 TB SATA hard drive. I disabled the Optane memory in the BIOS, then pulled the drive and the Optane to install the SSD.
I have two problems on the 15da- 1.) 5 of my 8 desktop gadgets won't display properly any more (they all still run just fine on the 15bs) 2.) My notification area won't stay open for me to read notifications- it snaps shut as soon as I move the mouse up into it (the 15bs still works just the same as it always has .
Does anyone have any suggestions? (The problems appeared before I switched out the SATA drive for the SSD, so it's not the drive.)
For the issues you're encountering on your HP laptop after upgrading to Windows 10 20H2, specifically related to desktop gadgets not displaying correctly and the notification area not staying open, here are some troubleshooting steps you can try to resolve these issues:
Troubleshooting Steps:​
  • Desktop Gadgets Not Displaying Properly:
  • Desktop gadgets are no longer supported since Windows 8. However, some third-party programs can restore similar functionality. Make sure these are compatible with Windows 10 20H2.
  • Check for compatibility issues with the gadgets and the Windows version. Update or uninstall any gadgets causing display problems.
  • Consider using alternatives like Rainmeter or other desktop...
  • Consider using alternatives like Rainmeter or other desktop customization tools for widgets and desktop displays.
  • Notification Area Behavior:
  • Restart Explorer: A common quick fix is to restart the Windows Explorer process. Press Ctrl + Shift + Esc to open Task Manager, find Windows Explorer, right-click, and choose Restart.
  • Check for Conflicting Software: Sometimes third-party software can interfere with the notification area. Temporarily disable any recently installed programs to check if they are causing the issue.
  • Update Graphics Drivers: Outdated or faulty graphics drivers can sometimes cause UI issues. Update your graphics drivers to the latest version from the manufacturer's website. If these steps don't solve the issues, you might need to consider resetting the affected laptop's Windows settings or seeking further assistance from HP support.
    Additional Tips:​
  • System Restore: Consider rolling back to a previous system restore point before the issues emerged, especially if they occurred directly after the Windows 10 upgrade.
  • Windows Updates: Ensure all Windows updates are fully installed. Sometimes new updates can inadvertently address specific bugs. By following these recommendations, you should be able to address the desktop gadget display and notification area issues on your HP laptop. If the problems persist, reaching out to HP support or Windows forums for additional troubleshooting specific to your laptop model may be beneficial.
