* Bugcheck Analysis *
BugCheck D1, {3bcba, 2, 1, fffff8800813016c}
*** WARNING: Unable to verify timestamp for Netwsw00.sys
*** ERROR: Module load completed but symbols could not be loaded for Netwsw00.sys
Probably caused by : Netwsw00.sys ( Netwsw00+a016c )
Followup: MachineOwner
you have three main groups of dump files. Bugcheck 124 which is a hardware error blaming an AMD processor, Bugcheck 0x7E blaming AMD GPU driver and the above which is blaming a wifi driver.
BiosVersion = V1.9
BiosReleaseDate = 01/13/2010
Your Bios has updates. Please make sure you follow the instructions and I have the correct motherboard:
atikmdag.sys Fri Mar 29 02:27:04 2013: AMD GPU driver. Please remove using this application which will also remove any old bits of previous driver installation:
Install the latest version for your card:
Your new card needs a PSU of around 600W as well as being of a reputable make, can you post which PSU you have?
dtsoftbus01.sys Fri Jan 13 13:45:46 2012: Daemon Tools driver. Possible BSOD issues in Win7 uninstall to test.
Netwsw00.sys Thu Apr 18 15:31:35 2013: Intel® Wireless WiFi Link Adapter. Please run the Intel driver update utility to check for updates:
npf_devolo.sys Fri Feb 02 09:24:05 2007: WinPcap by CACE Technologies please update:
https://www.winpcap.org/install/
Rt64win7.sys Thu Feb 16 05:39:50 2012: Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet please update:
RTKVHD64.sys Tue May 08 10:42:27 2012: Realtek High Definition Audio Function Driver please update:
Check for firmware updates for the SSD.
Post any new dump files after updating the above.
