johnDoe
Hello!
Last night my computer accidentally shut down because the wire tripped. When I tried loading my steam this morning, it went up till signing in and 'updating steam information' after which there was a blue loading ball over the cursor showing the system is busy but nothing happened after that. Steam didn't load.
In addition to this, there are a couple of more things that are strange.
My Firefox keeps giving exceptions when it tries to load common pages like Google, or whenever I open a webpage for the first time since I installed it. In addition to this my Nvidia Geforce Back-end thingy keeps on crashing. When I tried loading the Ubuntu installer, to state another example of unfathomable behavior, it didn't run. The same blue ball over cursor and nothing happens after.
I have tried a lot of things but to no avail. Tried formatting my hard disk and loading a new windows installation, no avail. Fixed registry errors and swept for viruses, all to no avail.
Its pretty frustrating as I do not understand what is going on. I would really appreciate any help I could get.
My Rig:
Windows 7 Ultimate
Asus p5ql pro
2 gb corsair
Nvidia Geforce 9500
2 HDDs Sata 2 Seagate 500 GB each
It sounds like you're experiencing multiple issues on your Windows 7 Ultimate system, ranging from problems with Steam, Firefox, Nvidia GeForce software, and even running the Ubuntu installer. When you encounter such a variety of issues after a sudden shutdown, it can be challenging to pinpoint the root cause. Here are some troubleshooting steps you can take to address these problems:
Troubleshooting Steps:​
  • Check System Integrity with SFC and DISM:
  • Open Command Prompt as an administrator and run the following commands:
    bash sfc /scannow dism /online /cleanup-image /restorehealth
  • These commands will scan and repair any corrupted system files.
  • Update Drivers:
  • Ensure all your drivers are up to...
  • Update Drivers:
  • Ensure all your drivers are up to date, especially your Nvidia GeForce driver.
  • Check Event Viewer:
  • Use the Event Viewer to check for any system errors or warnings that might give more insight into the issues.
  • Test Hardware:
  • Run diagnostic tests on your RAM and hard drives to check for any hardware failures.
  • Check for Malware:
  • Use reputable antivirus software to perform a full system scan to eliminate the possibility of malware causing these issues.
  • Reinstall Problematic Applications:
  • Uninstall and reinstall applications that are consistently crashing, such as Steam, Firefox, and Nvidia GeForce software.
  • Update Windows:
  • Make sure your Windows 7 system is fully updated to patch any known issues.
System Specifications:​
  • Operating System: Windows 7 Ultimate
  • Motherboard: Asus P5QL Pro
  • RAM: 2 GB Corsair
  • Graphics Card: Nvidia GeForce 9500
  • Storage: 2 HDDs Seagate 500 GB each
Additional Tips:​
  • Ensure your power settings are configured correctly to prevent sudden shutdowns in case of power failures.
  • Check for any loose connections or damaged cables that might be causing hardware issues. Try these steps and see if you notice any improvements or if any specific errors are highlighted during the troubleshooting process. If you encounter any specific error messages or issues while performing these steps, feel free to provide more details for further assistance.
