Windows 10 RAID on Asus X370 Prime Pro
ollihold
Hi
I have Win 10 and 4 Drives:
1x SSD 500GB (Windows System)
1x HHD 3TB (Backup)
2x HHD 5TB (Data)
I need to create RAID 1 with the two 5TB drives. For this I am doing the following steps:
Go in to BIOS:
Advanced --> Sata Mode: Raid
Boot --> CSM --> Launch CSM: disabled
Advanced --> RAIDXpert2 Configuration Utility --> Array Management --> Create Array (Option is greyed out!)
Why can't I click this option?
Also the mainboard manual is telling the following thing:
Due to chipset limitation, when SATA ports are set to RAID mode, all SATA ports run at
RAID mode together.
Does this mean I have to run my system and backup also on RAID and get two more drives?
Many thanks and best regards
RAID mode together.
If I am right it tells you that all connected drives will become one RAID drive. And again if I am right, your SSD and HDD's together can't be combined into one RAID drive. And combining 3TB and 5 TB into one RAID drive is not a sensible thing to do.
Do you really need that RAID?
Thank you, then this mainboard is really not good.
I need something to be save in case a hard drive crashes again.
Maybe I will use Genie Timeline. It is a nice backup tool.
I think Bochane is correct; RAID 1 won't work on secondary drives only without including the System Drive (C: drive). :ohno:That's because drive Mirroring was designed to backup your boot drive should that drive crash due to mechanical or electrical failure, and of course with no boot drive, you have no Windows.:eek:
Better solutions would be to purchase a 2nd SSD 500GB drive, install that as your secondary drive and attempt to use your Mobo's RAID implementation there. I'm not sure how well SSD's do with RAID, as I have not experimented with them due to their high cost.:scratch: Some of the other guys here might be able to chime in if they have personal experience with that however. But there are lots of articles out there. Since you mentioned you wanted to do RAID with your 2 large 5TB drives, I'm guessing you have lots of data that needs to be backed up and protected that won't fit on a small 500GB boot drive *by the way, that's what I have on my Dell desktop here* as my main production machine.
My Mobo is a Dell OEM and is 8-1/2 yrs. old and it's not capable of doing RAID 1. I can do automatic software RAID1 mirroring using my Macrium Reflect. (I did this when my PC was still running Vista). But, my 2nd 500GB drive is failing and it needs to be replaced; so I'm not currnently running in automatic mode; I do manual Clones to that 2nd drive quarterly.
My solution for large capacity (larger than 1TB) was to purchase a NAS setup, the WD Cloud Mirror solution, which uses 2 drives in a Raid 5+1 or Raid 6 setup. It sits on my home network (LAN) and I can access from any of my 10 computers via the network whenever I need to upload backups or download them for rebuilds.:) My primary storage is to keep Customer Image Backup files so I can rebuild their computers much faster if I've previously rebuilt them and they crash due to HDD failure or they scramble them with a nasty Ransomware virus like NEMUCOD, or Cryptolocker. These files vary is size from about 9GB to 260GB and thus take up scads of room. The NAS is a perfect low-cost solution.:up: And you don't have to buy a new Mobo to use it; so the money you spend on a NAS to work with your existing Mobo and setup is not much more than buying a more expensive Mobo that includes RAID5 or 10 capability; not to mention you might have to upgrade your PSU, RAM sticks, Cooler, etc. and other components to work with a new Mobo.o_O
I paid about $400 for my WD MYCLOUD NAS a few months ago and I love it! :trueluv: It's 8TB (2x4TB drives); as is close to what you are looking for. Their next size up is a 12TB (2x6TB drives) which should cover your requirement (5TB), and it's really easy to swap out a drive if you lose one, with the easy eject setup. Here's a link for you: Amazon.com: WD 12TB My Cloud Mirror Personal Network Attached Storage - NAS - WDBWVZ0120JWT-NESN: Computers & Accessories
This link is for the 12TB NAS, mine is the 8TB NAS, but you can go bigger if you want, they have a 16TB NAS on the same link page for a bit more, and I believe if you step up to their 4 drive NAS, you can go to 64TB NAS; which should be plenty of capacity for you.
You can always use those stand-alone 5TB's somewhere else, on another computer, or sell on ebay and get some money to help pay to purchase your NAS.;) They are not as good as SANs *which I used to help build*, but for home use they are really nice!
P.S. I like the specs on your ASUS Prime Mobo. Looks like a good board.:D I'm looking at Mobos as I'm building a new Gaming PC with my son.:computer:
Best of luck,:encouragement:
<<<<BIGBEARJEDI>>>>
Another thing:
Disk mirroring is NOT a backup!!
(because any infection will be mirrored onto the 2nd disk)
Backups should be kept off-line and if possible outside the building.
Most of the onboard RAIDS are really only software RAIDS and are generally all or none. Just go into disk management in Windows and convert them to Dynamic and create the mirror there. The performance hit is minor at best. The other option is go into Control Panel > Storage Spaces and create a SS. Work the same as a RAID but with better data resiliency and snap shots etc.
