Windows 7 random bsod, need help with the minidump
rukia
so i just got a bsod and i found the minidump file but i cannon read it, so i hope one of you lads can do so for me and tell me what went wrong
BugCheck D1, {0, 2, 0, fffff88004855c9b}
*** WARNING: Unable to verify timestamp for L1C62x64.sys
*** ERROR: Module load completed but symbols could not be loaded for L1C62x64.sys
Probably caused by : L1C62x64.sys ( L1C62x64+6c9b )
Followup: MachineOwner
another...
BugCheck A, {fffff8800b3d26c0, 2, 0, fffff8000347ec40}
Probably caused by : L1C62x64.sys ( L1C62x64+70cc )
it looks like your Atheros Lan driver is either corrupt or something is causing it to crash. There is a later version on the Gigabyte support page here:
http://www.gigabyte.com/products/product-page.aspx?pid=4144#dl
I also noticed this:
xusb21.sys Thu Aug 13 23:10:17 2009: XBox USB wireless controller BSOD issues in Win7 with 2009 driver please update:
If the bsods continue after making the above changes try removing AVG as thats also known to cause issues on occasion. Install MSE in it's place as thats ultra stable:
http://windows.microsoft.com/en-GB/windows/security-essentials-download
Post any new dump files
i got the latest one , but my mobo is rev 1.1 ive removed the controller as i rarely use it didnt have a driver for it all
Can you post the dump file please. Also did you try removing AVG?
another driver related dump file blaming Atheros driver. I would definitely try removing AVG if you haven't already.
I also notice you use the Chrome browser. Please ensure this is the latest version (which also updates the flash player version) by opening the settings tab and clicking 'About Google Chrome'.
Run the Intel driver update utility:
GPU-Z.sys Wed Oct 06 17:14:37 2010: Latest version of GPU-Z can be found here:
http://www.techpowerup.com/gpuz/
It may also help if you tried uninstalling the atheros driver and then reinstalling the lan driver again:
Check for any corruption by running the system file checker. Right click on command prompt, choose properties then run as admin. Type:
sfc /scannow
Press enter and await results.
Post any new dump files.
i removed the lan driver and reinstalled it.
i removed avg and switched to microsofts own.
now we'll wait
