Random restarts with BSOD, Part 2
View attachment minidump 3-31-11.zip
I started a previous thread. See here. http://windows7forums.com/blue-screen-death-bsod/53822-random-restarts-bsod.html#post187075
I did all that was recommended and everything was working great for a few months. Got greedy, and tried reinstalling Log Me In. Bad idea. BSOD several times. Uninstalled Log Me In, but problem persists. BSOD has appeared several times after Log Me In was uninstalled.
Attached is my mini dump. Please help!!! :)
[B]
BugCheck 1000007E, {ffffffffc0000005, fffff80002a9795f, fffff880031cba78, fffff880031cb2e0}
Probably caused by : ntkrnlmp.exe ( nt!KxStartSystemThread+16 )
[/B]
Uninstall Universal Shield® by Everstrike Software
US40fs64.sys Fri Mar 05 08:03:05 2010
Uninstall LogMeIn/Remotely Anywhere
RaInfo.sys Fri Jan 04 13:57:14 2008
LMIRfsDriver.sys Mon Jul 14 12:26:56 2008
lmimirr.sys Tue Apr 10 18:32:45 2007
You may want to update to the latest:
ATI
atipmdag.sys Wed Mar 10 18:14:05 2010
Realtek Audio and LAN
RTKVHD64.sys Thu Feb 25 04:14:31 2010
Rt64win7.sys Mon Oct 25 05:33:07 2010
CRASH DUMPS
Loading Dump File [F:\DMP\033011-18064-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16695.amd64fre.win7_gdr.101026-1503
Machine Name:
Kernel base = 0xfffff800`02a1a000 PsLoadedModuleList = 0xfffff800`02c57e50
Debug session time: Wed Mar 30 19:54:56.227 2011 (UTC - 4:00)
System Uptime: 0 days 4:42:25.991
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Followup: MachineOwner
2: kd> !analyze -v
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003.  This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG.  This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG.  This will let us see why this breakpoint is
happening.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff80002a9795f, The address that the exception occurred at
Arg3: fffff880031cba78, Exception Record Address
Arg4: fffff880031cb2e0, Context Record Address
Debugging Details:
FAULTING_IP:
nt!ExpWorkerThread+10f
fffff800`02a9795f ffd3            call    rbx
EXCEPTION_RECORD:  fffff880031cba78 -- (.exr 0xfffff880031cba78)
ExceptionAddress: fffff80002a9795f (nt!ExpWorkerThread+0x000000000000010f)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
CONTEXT:  fffff880031cb2e0 -- (.cxr 0xfffff880031cb2e0)
rax=0000000000000001 rbx=b2e0fffff880014d rcx=1b5cfffffa8006a8
rdx=00002b0c00000000 rsi=fffffa8005218040 rdi=1b5cfffffa8006a8
rip=fffff80002a9795f rsp=fffff880031cbcb0 rbp=fffff80002c2f5f8
 r8=000000007f215548  r9=0000000000da7a64 r10=00000000000b1aa1
r11=fffffa8006a8b2e0 r12=fffffa8006a8b2e0 r13=0000000000000001
r14=0000000000000000 r15=0000000000000001
iopl=0         nv up ei pl nz na pe nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010202
nt!ExpWorkerThread+0x10f:
fffff800`02a9795f ffd3            call    rbx {b2e0ffff`f880014d}
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
CURRENT_IRQL:  0
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  ffffffffffffffff
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002cc20e0
 ffffffffffffffff
FOLLOWUP_IP:
fffff800`02a68c26 48c7c10e000000  mov     rcx,0Eh
BUGCHECK_STR:  0x7E
LAST_CONTROL_TRANSFER:  from fffff80002d2d7c6 to fffff80002a9795f
STACK_TEXT:
fffff880`031cbcb0 fffff800`02d2d7c6 : 0000056e`00000000 fffffa80`05218040 00000000`00000080 fffffa80`0518f9e0 : nt!ExpWorkerThread+0x10f
fffff880`031cbd40 fffff800`02a68c26 : fffff880`02f64180 fffffa80`05218040 fffff880`02f6efc0 0000056e`00000000 : nt!PspSystemThreadStartup+0x5a
fffff880`031cbd80 00000000`00000000 : fffff880`031cc000 fffff880`031c6000 fffff880`031cb9f0 00000000`00000000 : nt!KxStartSystemThread+0x16
SYMBOL_STACK_INDEX:  2
SYMBOL_NAME:  nt!KxStartSystemThread+16
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4cc791bd
STACK_COMMAND:  .cxr 0xfffff880031cb2e0 ; kb
FAILURE_BUCKET_ID:  X64_0x7E_nt!KxStartSystemThread+16
Loading Dump File [F:\DMP\033011-20170-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02a54000 PsLoadedModuleList = 0xfffff800`02c91e50
Debug session time: Wed Mar 30 15:11:32.444 2011 (UTC - 4:00)
System Uptime: 1 days 23:39:07.834
BugCheck 1000007E, {ffffffffc0000005, fffff80002ad195f, fffff880031b6a78, fffff880031b62e0}
2: kd> !analyze -v
happening.
Arguments:
Arg2: fffff80002ad195f, The address that the exception occurred at
Arg3: fffff880031b6a78, Exception Record Address
Arg4: fffff880031b62e0, Context Record Address
Debugging Details:
FAULTING_IP:
fffff800`02ad195f ffd3            call    rbx
EXCEPTION_RECORD:  fffff880031b6a78 -- (.exr 0xfffff880031b6a78)
ExceptionAddress: fffff80002ad195f (nt!ExpWorkerThread+0x000000000000010f)
NumberParameters: 2
CONTEXT:  fffff880031b62e0 -- (.cxr 0xfffff880031b62e0)
rax=0000000000000001 rbx=d2e0fffff8800148 rcx=9c34fffffa8006a6
rdx=0001b3c600000000 rsi=fffffa8005201040 rdi=9c34fffffa8006a6
rip=fffff80002ad195f rsp=fffff880031b6cb0 rbp=fffff80002c695f8
 r8=00000000e63c4e20  r9=0000000000da7a64 r10=000000000004ced3
r11=fffffa8006a6d2e0 r12=fffffa8006a6d2e0 r13=0000000000000001
cs=0010  ss=0000  ds=002b  es=002b  fs=0053  gs=002b             efl=00010202
fffff800`02ad195f ffd3            call    rbx {d2e0ffff`f8800148}
CURRENT_IRQL:  0
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002cfc0e0
 ffffffffffffffff
FOLLOWUP_IP:
fffff800`02aa2c26 48c7c10e000000  mov     rcx,0Eh
BUGCHECK_STR:  0x7E
LAST_CONTROL_TRANSFER:  from fffff80002d677c6 to fffff80002ad195f
STACK_TEXT:
fffff880`031b6cb0 fffff800`02d677c6 : 00000000`00000000 fffffa80`05201040 00000000`00000080 fffffa80`0518f9e0 : nt!ExpWorkerThread+0x10f
fffff880`031b6d40 fffff800`02aa2c26 : fffff880`02f63180 fffffa80`05201040 fffff880`02f6dfc0 00000000`00000000 : nt!PspSystemThreadStartup+0x5a
fffff880`031b6d80 00000000`00000000 : fffff880`031b7000 fffff880`031b1000 fffff880`031b69f0 00000000`00000000 : nt!KxStartSystemThread+0x16
MODULE_NAME: nt
STACK_COMMAND:  .cxr 0xfffff880031b62e0 ; kb
DRIVERS
fffff880`0493a000 fffff880`04978000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00ee6000 fffff880`00f3d000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02c33000 fffff880`02cbd000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`051dd000 fffff880`051f3000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`05280000 fffff880`053b2000   agrsm64  agrsm64.sys  Tue Jan 26 12:52:20 2010 (4B5F2BD4)
fffff880`01829000 fffff880`01878000   ahcix64s ahcix64s.sys Wed Sep 23 08:52:47 2009 (4ABA1A1F)
fffff880`02de6000 fffff880`02dfb000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`00fd4000 fffff880`00fdf000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`081a1000 fffff880`081ac000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`0650c000 fffff880`0652e000   AtiHdmi  AtiHdmi.sys  Thu Jan 28 20:03:36 2010 (4B6233E8)
fffff880`048b0000 fffff880`048e4000   atikmpag atikmpag.sys Wed Mar 10 17:34:04 2010 (4B981E5C)
fffff880`015f8000 fffff880`01600000   AtiPcie64 AtiPcie64.sys Wed Mar 10 09:33:45 2010 (4B97ADC9)
fffff880`04a34000 fffff880`050a3000   atipmdag atipmdag.sys Wed Mar 10 18:14:05 2010 (4B9827BD)
fffff960`00910000 fffff960`00971000   ATMFD    ATMFD.DLL    Fri Jan 07 00:49:20 2011 (4D26A960)
fffff880`019b8000 fffff880`019bf000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`02c1e000 fffff880`02c2f000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`0557f000 fffff880`0559d000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`006e0000 fffff960`00707000   cdd      cdd.dll      Wed Jan 26 01:31:34 2011 (4D3FBFC6)
fffff880`01954000 fffff880`0197e000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00d16000 fffff880`00dd6000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`00e00000 fffff880`00e30000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00cb8000 fffff880`00d16000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01163000 fffff880`011d6000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`053dd000 fffff880`053ed000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`06eec000 fffff880`06efa000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`02c00000 fffff880`02c1e000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`02dd7000 fffff880`02de6000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`011d6000 fffff880`011ec000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0656b000 fffff880`0658d000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`06f04000 fffff880`06f53000   dump_ahcix64s dump_ahcix64s.sys Wed Sep 23 08:52:47 2009 (4ABA1A1F)
fffff880`06f53000 fffff880`06f66000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`06efa000 fffff880`06f04000   dump_storport dump_storport.sys Mon Jul 12 23:32:05 2010 (4C3BDE35)
fffff880`06ee0000 fffff880`06eec000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`050a3000 fffff880`05197000   dxgkrnl  dxgkrnl.sys  Tue Jan 25 23:22:56 2011 (4D3FA1A0)
fffff880`05197000 fffff880`051dd000   dxgmms1  dxgmms1.sys  Tue Jan 25 23:22:12 2011 (4D3FA174)
fffff880`010f1000 fffff880`01105000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`010a5000 fffff880`010f1000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`0122b000 fffff880`01235000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`00c5c000 fffff880`00c96000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`01000000 fffff880`0104a000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`02a0b000 fffff800`02a54000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`04a00000 fffff880`04a24000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`06f9d000 fffff880`06fb6000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`06fb6000 fffff880`06fbe080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`06f8f000 fffff880`06f9d000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`054b7000 fffff880`0557f000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`014c3000 fffff880`014cc000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`04a24000 fffff880`04a33000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`06fe9000 fffff880`06ff7000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00bc8000 fffff800`00bd2000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`0484a000 fffff880`0488d000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`01200000 fffff880`0121a000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01460000 fffff880`0148b000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`0658d000 fffff880`06592200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`06c44000 fffff880`06c59000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`053ed000 fffff880`053f4000   lmimirr  lmimirr.sys  Tue Apr 10 18:32:45 2007 (461C108D)
fffff880`05488000 fffff880`0549b000   LMIRfsDriver LMIRfsDriver.sys Mon Jul 14 12:26:56 2008 (487B7E50)
fffff880`06c00000 fffff880`06c23000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c97000 fffff880`00ca4000   mcupdate mcupdate.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`053b4000 fffff880`053c3000   modem    modem.sys    Mon Jul 13 20:10:48 2009 (4A5BCD08)
fffff880`06f81000 fffff880`06f8f000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`0483b000 fffff880`0484a000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`06fdc000 fffff880`06fe9000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00fba000 fffff880`00fd4000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`0197e000 fffff880`019af000   MpFilter MpFilter.sys Tue Sep 14 20:19:28 2010 (4C901110)
fffff880`05471000 fffff880`05481000   MpNWMon  MpNWMon.sys  Tue Sep 14 20:19:30 2010 (4C901112)
fffff880`0559d000 fffff880`055b5000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`055b5000 fffff880`055e2000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`05400000 fffff880`0544e000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`0544e000 fffff880`05471000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`01235000 fffff880`01240000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f46000 fffff880`00f50000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01105000 fffff880`01163000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`02dcc000 fffff880`02dd7000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`014b1000 fffff880`014c3000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`014cc000 fffff880`015be000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`053f4000 fffff880`05400000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`0499c000 fffff880`049cb000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`064f7000 fffff880`0650c000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02d31000 fffff880`02d40000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02cbd000 fffff880`02d02000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01400000 fffff880`01460000   NETIO    NETIO.SYS    Thu Apr 08 22:43:59 2010 (4BBE946F)
fffff880`08067000 fffff880`0807c000   NisDrvWFP NisDrvWFP.sys Tue Sep 14 20:20:25 2010 (4C901149)
fffff880`013ec000 fffff880`013fd000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02dc0000 fffff880`02dcc000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02a54000 fffff800`03031000   nt       ntkrnlmp.exe Tue Oct 26 22:43:09 2010 (4CC791BD)
fffff880`01249000 fffff880`013ec000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`019af000 fffff880`019b8000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`02d0b000 fffff880`02d31000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00f90000 fffff880`00fa5000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00f50000 fffff880`00f83000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`0121a000 fffff880`0122b000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`080b1000 fffff880`08157000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`0652e000 fffff880`0656b000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00ca4000 fffff880`00cb8000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`05481000 fffff880`05488000   RaInfo   RaInfo.sys   Fri Jan 04 13:57:14 2008 (477E818A)
fffff880`04978000 fffff880`0499c000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`049cb000 fffff880`049e6000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`04800000 fffff880`04821000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`04821000 fffff880`0483b000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`02d6f000 fffff880`02dc0000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`01810000 fffff880`01819000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01819000 fffff880`01822000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`019f2000 fffff880`019fb000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`015be000 fffff880`015f8000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`06c59000 fffff880`06c71000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`05200000 fffff880`05265000   Rt64win7 Rt64win7.sys Mon Oct 25 05:33:07 2010 (4CC54ED3)
fffff880`06cb5000 fffff880`06edf100   RTKVHD64 RTKVHD64.sys Thu Feb 25 04:14:31 2010 (4B863F77)
fffff880`08157000 fffff880`08162000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`014a9000 fffff880`014b1000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`06400000 fffff880`06496000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`08000000 fffff880`08067000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`08162000 fffff880`0818f000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`01878000 fffff880`018da000   storport storport.sys Mon Jul 13 20:01:18 2009 (4A5BCACE)
fffff880`0527d000 fffff880`0527e480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01603000 fffff880`01800000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`0818f000 fffff880`081a1000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`011ec000 fffff880`011f9000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`00fdf000 fffff880`00ffd000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02d5b000 fffff880`02d6f000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00550000 fffff960`0055a000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`00dd6000 fffff880`00dfc000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`0488d000 fffff880`0489f000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`0148b000 fffff880`014a9000   US40fs64 US40fs64.sys Fri Mar 05 08:03:05 2010 (4B910109)
fffff880`06fbf000 fffff880`06fdc000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`053b2000 fffff880`053b3f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`053c3000 fffff880`053d4000   usbehci  usbehci.sys  Sat Oct 24 00:27:33 2009 (4AE28235)
fffff880`05270000 fffff880`0527d000   usbfilter usbfilter.sys Wed Oct 07 03:44:08 2009 (4ACC46C8)
fffff880`0649d000 fffff880`064f7000   usbhub   usbhub.sys   Sat Oct 24 00:28:24 2009 (4AE28268)
fffff880`05265000 fffff880`05270000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`048e4000 fffff880`0493a000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`06c82000 fffff880`06c8e000   usbprint usbprint.sys Mon Jul 13 20:38:18 2009 (4A5BD37A)
fffff880`06c71000 fffff880`06c82000   usbscan  usbscan.sys  Mon Jul 13 20:35:32 2009 (4A5BD2D4)
fffff880`06f66000 fffff880`06f81000   USBSTOR  USBSTOR.SYS  Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`00f83000 fffff880`00f90000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`019bf000 fffff880`019cd000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`019cd000 fffff880`019f2000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00fa5000 fffff880`00fba000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`0104a000 fffff880`01096000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`02d40000 fffff880`02d5b000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`01800000 fffff880`01810000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e33000 fffff880`00ed7000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00ed7000 fffff880`00ee6000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02d02000 fffff880`02d0b000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00010000 fffff960`00320000   win32k   win32k.sys   Tue Jan 04 22:59:44 2011 (4D23ECB0)
fffff880`053d4000 fffff880`053dd000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00f3d000 fffff880`00f46000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`06c23000 fffff880`06c44000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`0807c000 fffff880`080ad000   WUDFRd   WUDFRd.sys   Mon Jul 13 20:06:06 2009 (4A5BCBEE)
Unloaded modules:
fffff880`018da000 fffff880`0194b000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`018da000 fffff880`018e8000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`018e8000 fffff880`018f2000   dump_storpor
    Checksum:  00000000
    ImageSize:  0000A000
fffff880`018f2000 fffff880`01941000   dump_ahcix64
    Checksum:  00000000
    ImageSize:  0004F000
fffff880`01941000 fffff880`01954000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
