Is it possible to change the default view of the Windows 10 Recycle Bin when it opens? I figure there’s settings in the Registry somewhere. I would like the default to be view by details, sorted by date, descending.
Yup, as neemobeer suggests and the reason why i asked.. Certain scans can remove any settings you've made and it might be worth experimenting. Run the scan and then check your Recycle bin straight after.
